IsakVern
- Messages
- 8
- Reaction score
- 0
I have some issues understanding the following thought experiment:
Suppose you are standing still, and two balls are moving towards you from opposite direction. From your own reference frame, Ball A is ##10^5## m away from you, moving towards you from the left with speed ##0.8c##, and Ball B is ##10^5## m away from you, moving towards you from the right with speed ##0.8c##. And then (of course), from YOUR reference frame, both balls will hit you at the same time, specifically after
## time = distance/velocity = \frac{10^5 m}{0.8c} = 0.0004167 s = 416.7 μs ##
From the reference frame of Ball A, IT is standing still, and YOU are moving towards it with speed ##0.8c## from the right, and Ball B is moving towards it with speed:
##v_{B} = \frac{0.8c + 0.8c}{1 + (0.8c)^2/c^2} = \frac{1.6c}{1.64c} = 0.97c## .
This means that, from the reference frame of Ball A, YOU collide into Ball A after
##t = \frac{10^5 m}{0.8c} = 416.7 μs## (like we found above)
and Ball B collide into Ball A after
##t = \frac{2 \cdot 10^5 m}{0.97c} = 687.3 μs##,
which means that, from the reference frame of Ball A, the three objects (you, Ball A and Ball B) didn't collide at the same time. And both you AND Ball A would be correct. Is this the accurate way to measure it? Can Ball A (and Ball B for that matter) really claim that the collision didn't occur with all three objects colliding at the same time?
Thanks in advance!
Thanks in advance!
