Why do contour and image give different results for the same data?
  • Topic: MATLAB
  • Thread starter Thread starter nenyan
    Confusing Matlab
4 replies · 3K views · last reply
nenyan
When I use MATLAB to draw contour and color scale map of an array. The result is weird.
my code:
the first:
b=load('c:\...\b.txt');
contour(b)
the second:
image(b)
The results are very different. I upload the array file and two figures.
  • b.zip
    b.zip
my code:
the first:
contour(b)
the second:
image(b)
I'm not a Matlab user, so I'm only guessing from the on-line documentation, but it may be that Matlab's image is treating your flat matrix as levels in the range 0-255 (or 63535). In which case, they are all to small to be distinguishable from 0. Try normalizing the data first - I've attached a Mathcad image (zoomed in slightly) to show what I mean (Mathcad converts reals to integers and shows a similar effect, which the function normalize overcomes)
Thank you. After nromalization, it is still different.
You can use the imagesc() function instead of normalization. It will automatically set the scale range to the range of your data.
