Why do different data types change C expression results?
7 replies · 3K views · last reply
Maybe_Memorie
Evaluate the following expressions
(i) 1 - 2/3 + 4 - 5
(ii) 1 - 2/3 + 4.0 - 5
(iii) 1 - 2/3.0 + 4 - 5
(iv) 1 + 4*3/2
(v) 1 + 3/2*4
(vi) 'h' - 'e' + 'l' - 'p'
The answers for each question respectively are
-.666667
I am completely lost here. I have no idea what the differences between the first 3 are or the 4th and 5th. There is nothing about this in my notes.
Any advice is greatly appreciated.
(i) 1 - 2/3 + 4 - 5
(iv) 1 + 4*3/2
(v) 1 + 3/2*4
-.666667
i) All of the numbers in the expression are integers. Since this is so, we confine the result of each calculation to be an integer. 2/3 = 0 by chopping off the decimal.
ii) Since a 4.0 is introduced, you are now working with a float that has two significant figures. After combining the terms, you'll end up with 0.0 instead of 0.
iii) This one I'm not quite sure on. You're performing a division on a float, so after dividing out, you'll be left with a float. I'm not quite sure how many decimal places you keep though.
iv,v) PEMDAS. Perform multiplication/division from left to right. Then addition. Since we're working with all integers again, you should see the answers.
vi) Convert each character to its appropriate ASCII code.
Thanks, I'm still not quite sure on (v) and (iii)
On (v), although I agree the order of operations is PEMDAS, I would think the division in this case is happening before the multiplication because 3/2 = 1 (integer division), so it would yield 1+1*4 = 5.
Hi Maybe_Memorie! :smile:
Have you moved on to C programming?
First C evaluates multiplications and divisions from left to right.
In this case there is only 1 division.
If the arguments of a division are both integers, the result is a truncated integer division.
If either argument (or both) have a point in them (that is, they are "floating point"), the result is floating point.
In this case 2/3.0 = 0.666666666666667
(Usually you will always have 15 significant digits, so gb7nash's remark is off.)
Then C evaluates all additions and subtractions from left to right.
So:
1 - 2/3.0 + 4 - 5
= 1 - 0.666666666666667 + 4 - 5
= 0.333333333333333 + 4 - 5
= 4.33333333333333 - 5
= -0.66666666666667
Maybe_Memorie said:
(v) 1 + 3/2*4
In this case we're looking at integer division, and we evaluate mul together with div left to right.
1 + 3/2*4
= 1 + 1*4
= 1 + 4
And then additions and subtractions left to right:
1 + 4 = 5
It does. In PEMDAS, you do multiplication/division left to right. The division sign occurs before the multiplication sign like you said, so you would end up getting 1+1*4 = 5
I learned something new today.
Hey Maybe_Memorie! :smile:
Are you satisfied with the answers?
(I always like to feel a thread was finished satisfactorily before moving on to new problems. :wink:)
Thank you very much! :)
(Sorry for taking so long to reply, I don't always have internet access :redface: )
