Why Do Different Terms Arising From An Electron Configuration Differ In Energy?
  • Context: Graduate
  • Thread starter Thread starter Repetit
    Atomic Symbols Term
The discussion centers around the differences in energy levels of various terms arising from specific electron configurations, particularly in multi-electron atoms. Participants explore the underlying reasons for energy variations among terms like 3P, 1D, and 1S for configurations such as carbon (1s²2s²2p²) and others involving d and f orbitals.
  • One participant asks why different terms from the same electron configuration have different energies, specifically referencing carbon's 1s²2s²2p² configuration.
  • Another participant notes that the energy differences arise from the various spin configurations of electrons in the p-orbital.
  • A follow-up question addresses the situation in an f-shell with three electrons, questioning how multiple terms can arise when spins are fixed.
  • Discussion includes the role of relativistic effects and spin-orbit coupling in determining energy levels, with one participant explaining how these factors contribute to energy splitting.
  • A participant expresses confusion about energy differences between terms (3F and 3P) in a specific configuration ([Ar]3d²) when assuming both electrons are spin-up.
  • Another participant clarifies that without spin-orbit coupling, single electron states with the same principal quantum number have the same energy, suggesting that multi-electron systems simply sum these energies.
  • Interest is expressed in worked examples of calculating allowed states and their term symbols.
Participants exhibit a mix of understanding and confusion regarding the energy differences among terms, with some agreeing on the role of spin and angular momentum while others remain uncertain about specific configurations and their implications.
Some participants highlight the complexity of calculating energy levels without considering spin-orbit coupling, indicating that assumptions about electron spins and configurations may not fully account for energy differences.
This discussion may be of interest to those studying atomic physics, particularly in the context of multi-electron atoms and the effects of electron configurations on energy levels.
Repetit
Can someone explain to me why different terms arising from a particular electron configuration have different energies? For example, for carbon in the configuration [tex]1s^22s^22p^2[/tex] three terms arise, 3P 1D and 1S. These three terms have different energies but I don't understand why. The electron configuration is given, so what changes between the three terms? How can they have different energies?
There are 2 electrons occupying the p-orbital. There are only 3 spin configurations the electrons can have.
spin up-spin up
spin down-spin down
spin up-spin down
These configurations are different in energy.
Thanks for the reply! But, in an f-shell with 3 electrons for instance, even if we assume that the 3 electrons all have spin up we still get several atomic terms. How can that be, what degrees of freedom are left when the configuration is locked and the spins of the electron is also locked. The distribution of electrons within the f-shell maybe? But the [tex]m_l[/tex] quantum number of the electrons in the shells shouldn't matter for the energy should it?
I'm not entirely sure from your post, but I think you're talking about the energy levels in the LS or Russell-Saunders coupling scheme for multi-electron atoms. The basic idea is that apart from the electrostatic attraction from the nucleus and repulsion of electrons from each other, the next greatest contributing factor is the relativistic effect of spin-orbit coupling. Loosely speaking, an electric field in one frame turns into something involving a magnetic field in another frame --- the moving electron actually sees a magnetic field. This magnetic field interacts the spin magnetic moment of the electron, to produce a further splitting between certain orbitals --- the fine structure. The term is proportional to [tex]\hat{L}\cdot\hat{S}[/tex] so [tex]\hat{J}[/tex] commutes with the Hamiltonian, where the L, S and J refer to the total angular momentum of the respective type, summed over all the electrons. Thus we can label the atomic (i.e. multi-electron states) with the term symbols [tex]^{2S+1}L_J[/tex]. Thus we need to calculate all the allowed states of S and L for a given set of electrons. It's slightly simplified as we only need to think about the electrons not in a full subshell. However, it's slightly complicated by the need to consider exchange antisymmetry.
So the answer to your question is that different alignments of spin and angular momentum give different energies.
If you want, I can work through some examples of calculating the allowed states, their term symbols and their relative energies (qualitatively).
That makes sense to me... Thank you. :) And yes, I am talking about energy levels for multielectron atoms in the Russel-Saunder coupling scheme.
But, what I am basically trying to do is to calculate the energy of excited states of some atoms without the effect of spin-orbit. Now, let's say I have an atom with the configuration [tex][Ar]3d^2[/tex] so that the two outermost electrons are d electrons and the only shell which is not full is this d shell. If the two electrons are assumed to be spin-up electrons, I get two different terms, a 3F term and a 3P term. Now, there's some energy difference between these two terms right? I just don't understand why, because the electron configuration is given and I assumed that the electrons are both spin-up electrons. So how can these two terms differ in energy? Maybe I've misunderstood something.
Without spin-orbit coupling, single electron states with the same n number have the same energy, and multi-electron systems just have the sum of the energies. So yes, you're absolutely correct --- the energies would be the same. No amount of changing spins or orbital angular momentum orientation (m_l values) would change the energy.
genneth i would love to see your worked examples, especially concerning
L = l1+ l2, l1+ l2 -1, l1+ l2 -2,… |l1- l2|.
[tex]L = l_1+ l_2, l_1+ l_2 -1, l_1+ l_2 -2,… |l_1- l_2|.[/tex]
  • · Replies 43 ·
