Why do hidden variables imply linear correlation in Bell's theorem?
428 replies · 61K views
lugita15 said:
Again, I don't quite understand what you're saying here, and I don't know why you're associating T_a + T_b with putting on shoes then socks, rather than just the time to put on shoes plus the time to put on socks.
Because to calculate the time required to put on shoes and then socks, I have to add the time required to put on shoes to the time required to put on socks.
T_b is just a fixed number, just like 5. Whether you put it on its own in a statement (with physical significance or not), or whether you put it in a statement (with physical significance or not) which also has T_a in it, doesn't it still retain its value?
No. T_b is just a fixed number like 5 in the physical situation in which you are only putting on socks. T_b is just a fixed number like 8, in the physical situation in which we are putting on shoes and then socks. T_b in in the first physical situation, is not the same value as T_b in the second physical situation, even though in both cases T_b is still the time it takes to put on socks.
I definitely don't disagree with going from P(C|w)= P(A|w)+P(B|w)-2P(AB|w) to P(C|z)= P(A|x)+P(B|y)-2P(AB|w). What do you see wrong with that step?
What I have been explaining all this while, that the probabilities from the "xyz" scenario are not the same as those in the "w" scenario, so it is not correct to substitute them.
This is a rather strange statement. What does it mean for three statements to be true, versus three statement being true simultaneously? Are you operating in some non-classical logic or something?
Nothing strange there at all if you understand degrees of freedom, and probability theory. Like I explained to you using the Bernouli's urn example, the probability of Red on the first draw when considered alone, has a different value from the probability of red on the first draw when considered together with the probability of red on the second draw, already given.
And also, why can't we just sidestep this whole issue, like I did in post #249
Because it is assumed that you want to make sound, consistent and valid arguments rather than just sneaking in paradoxes behind the back door.
George Boole's ‘Conditions of Possible Experience’ and the Quantum Puzzle
ITAMAR PITOWSKY, Br J Philos Sci (1994) 45 (1): 95-125. doi: 10.1093/bjps/45.1.95
Abstract:
In the mid-nineteenth century George Boole formulated his ‘conditions of possible experience’. These are equations and ineqaulities that the relative frequencies of (logically connected) events must satisfy. Some of Boole's conditions have been rediscovered in more recent years by physicists, including Bell inequalities, Clauser Horne inequalities, and many others ...
On page 100:
George Boole is best known as one of the fathers of modern logic. Somewhat less known in his work on the theory of probability, most of it published in his classical book, Boole [1854]. ... Boole's problem is simple: we are given rational numbers which indicate the relative frequencies of certain events. If no logical relations obtain among the events, then the only constraints imposed on these numbers are that they each be non-negative and less than one. If however, the events are logically interconnected, there are further equalities or inequalities that obtain among the numbers. The problem thus is to determine the numerical relations among frequencies, in terms of equalities and inequalities, which are induced by a set of logical relations among the events. The equalities and inequalities are called 'conditions of possible experience'.
On page 105 it says:
One thing should be clear at the outset: none of Boole's conditions of possible experience can ever be violated when all the relative frequencies involved have been measured in a single sample. The reason is that such a violation entails a logical contradiction. For example, suppose that we sample at random a hundred balls from an urn. Suppose, moreover that 60 of the balls sampled are red, 75 are wooden and 32 are both red and wooden. We have p1=0.6, p2= 0.75, p12 = 0.32. But then p1+p2-p12 > 1. This clearly represents a logical impossibility, for there must be a ball in the sample (in fact three balls) which is 'red', is 'wooden', but not 'red and wooden'; absurd.
Similar logical absurdities can be derived if we assume a violation of any of the relevant conditions, no matter how complex they appear to be. This is the reason for the title 'conditions of possible experience'. In case we deal with relative frequencies in a single sample, a violation of any of the relevant Boole's conditions is a logical impossibility.
But sometimes, for various reasons, we may choose or be forced to measure the relative frequencies of (logically connected) events, in several distinct samples. In this case a violation of Boole's conditions may occur.
So, No, I'm not using any alternate logic. I'm reasoning the situation as prescribed by one of the fathers of logic, and explaining to you that you are not reasoning logically about the situation.
see for example, https://www.physicsforums.com/showpost.php?p=3856772&postcount=125
billschnieder said:
We have an urn with 2 balls, 1 white and 1 red, we pick two balls in sequence without replacement.
*) The probability of the first ball being Red, R1
*) The probability of the first ball being Red, R3, given that the second ball was revealed to be Red R2.
According to your no-conspiracy condition, R1 = R3 which is false. R1 = 1/2 and R3 = 0. As I hope you appreciate, the underlined statements (R2) place restrictions on what we are allowed to say about R3. By ignoring this part of your argument, it has obscured your ability to see the error.
Not only do we have results for the actually measured angle y, we are also using it jointly in the same expression as the results at angle x.
billschnieder said:
To summarize:
1) There are two scenarios/physical sittuations involved in this discussion:
Scenario "xyz", involving the three probabilities:
P(A|x) = what we would get if we measure system "x" at angles (a,b)
P(B|y) = what we would get if we measure system "y" at angles (b,c)
P(C|z) = what we would get if we measure system "z" at angles (a,c)​
Scenario "w", involving the three probabilities:
P(A|w) = what we would get if we measure system "w" at angles (a,b)
P(B|w) = what we would have gotten had we measured system "w" at angles (b,c) instead of (a,b)
P(C|w) = what we would have gotten had we measured system "w" at angles (a,c) instead of (a,b)​
2) Scenario "xyz" is different from Scenario "w". The three probabilities in "w" are not equal to the three probabilities from "xyz".
3) Bell's inequalities are derived for scenario "w" ONLY. A similar inequality cannot be derived for scenario "xyz".
4) The predictions of QM are for scenario "xyz" only, not "w"
5) Experimental results are for scenario "xyz" only
6) Using probabilities from "xyz" in an expression derived for "w", amounts to introducing an assumption that the probabilities are all equal. It is this assumption that should be rejected when a violation results.
So what part of this argument don't you understand, or do understand but disagree with and why?
Bill, I think you’re lost in the ‘Bayesian jungle’... can’t see the forest for the trees...
You and lugita could probably continue this discussion for 100 years without agreement, because you are discussing two different things.
I have some simple Yes/No -questions that will hopefully reveal the root of bafflement:
  1. Do you understand that Bell's theorem is mainly about correlations (not probabilities)? Yes/No:
  2. Do you understand that for a single entangled photon, the measurement probability outcome according to QM is always 100% random (50/50 +1/-1) no matter what you do or what angle you set? Yes/No:
  3. Do you realize that when you write P(A|x) you are talking about statistical correlations for the relative angle (a - b), for hundreds or thousands of entangled pairs? Yes/No:
  4. Do you realize that above is also always true for any other settings, i.e. P(B|y), P(C|z), etc? Yes/No:
  5. Do you understand that it’s completely meaningless to talk about probabilities/correlations for a single photon/pair (except when perfectly aligned)? Yes/No:
  6. Do you understand that P(A|x) says absolutely nothing about the properties of a single photon before measurement? Yes/No:
  7. Do you accept the experimental outcome/statistics of EPR-Bell test experiments? Yes/No:
  8. Do you admit that to set an upper limit for ‘classical’ Local Realism, we must operate according to these ‘classical’ rules only, i.e. not according to the rules of QM? Yes/No:
  9. Do you acknowledge that that the definite property of LHV in Local Realism unconditionally leads to Counterfactual definiteness (CFD)? Yes/No:
  10. Do you acknowledge that LHV & CFD must naturally be included in the test of Local Realism, in from of Bell's inequality? Yes/No:
  11. Do you acknowledge that classical propositional logic do not work satisfactory in QM systems before measurement and the transition to [macroscopic] statistics? Yes/No:
  12. Are you aware of that your “Bayesian/logical investigation” on QM states before measurement is erroneous and that Quantum Logic is still ‘under development’? Yes/No:
  13. Do you understand that to use Bayesian probability theory in QM, you are forced to deal with measurements and [macroscopic] statistics, and that any “pre-measurement probability/states” is [yet] out of the question? Yes/No:
  14. Do you admit that if QM violates Bell's inequality – it violates Bell's inequality – no matter if it’s “Little Green Men” running an “intergalactic-non-local-signaling-system” or what, it is violated, okay? Yes/No:
Appreciate if you could answer these 14 simple questions with Yes/No – it will save us a lot of time.
Thanks
DA
Somehow I doubt it. :biggrin:
[*]Do you understand that Bell's theorem is mainly about correlations (not probabilities)? Yes/No
Have you stopped beating your wife? Yes/No. I understand that that Bell's theorem can be about both. In the other thread which was closed, we discussed correlations, in this thread, we are discussing about probabilities. Do you understand that?
[*]Do you understand that for a single entangled photon, the measurement probability outcome according to QM is always 100% random (50/50 +1/-1) no matter what you do or what angle you set?
huh? That is a nonsensical statement. As I have explained to you 100 times previously, each specific single photon, when measured, gives a definite outcome. QM says absolutely nothing and can say absolutely nothing about this single outcome. What appears random is the SERIES of outcomeS from a SERIES of similarly prepared photons. It is for this SERIES that QM makes predictions. Obviously you do not understand this.
[*]Do you realize that when you write P(A|x) you are talking about statistical correlations for the relative angle (a - b), for hundreds or thousands of entangled pairs?
P(A|x) is a probability of mismatch when the set of photon pairs "x" is measured at the angle pair (a,b). P(A|x) is NOT a correlation.
etc ...
etc ...
I encourage you to go back and re-read this thread from page 15, carefully, because you obviously have not, as your "yes/no" wife-beater-type questions indicate. I'm not willing to attempt to correct all your misconceptions here, especially those that have already been corrected in excruciating detail in this very thread since page 15.
Rather it would save us time if you could state clearly what part of the argument in post #270 (which you quoted) you disagree with and why exactly.
In the other thread, when I asked the questions:
billschnieder said:
1) Do you agree that there are two scenarios involved in this discussion:
Scenario X, involving the three correlations:
C(a,b) = correlation for what we would get if we measure (a,b)
C(b,c) = correlation for what we would get if we measure (b,c)
C(a,c) = correlation for what we would get if we measure (a,c)
Scenario Y, involving the three correlations:
C(a,c) = correlation for what we would have gotten had we measured (a,c) instead of (a,b)
C(b,c) = correlation for what we would have gotten had we measured (b,c) instead of (a,b)
2) Do you agree that Scenario X is different from Scenario Y?
3) Do you agree that the correlations in Bell's inequalities correspond to Scenario Y NOT Scenario X?
4) Do you agree that correlations calculated from QM correspond to Scenario X not Scenario Y?
5) Do you agree that correlations measured in experiments correspond to Scenario X not Scenario Y?
Your answers there were
1) Yes, of course
2) Yes, of course
3) Yes, of course
4) Yes, of course
5) Yes, of course
DA said:
Scenario X => QM theory => EPR-Bell experiments => what actually works
Scenario Y => assumptions of Local Realism => definite values all the time => CFD => not working
For clarity we exchange Scenario X = QM theory and Scenario Y = Local Realism, and then it’s easy to see where it goes wrong.
Yes of course, it’s big difference between QM theory and Local Realism.
Yes of course, Bell's inequalities sets the upper limit for what any model of Local Realism can achieve.
Yes of course, calculated correlations of QM theory naturally will correspond to QM theory.
Yes of course, when we perform QM experiments in form of EPR-Bell test experiments, it will naturally correspond to QM theory.
lugita15 said:
You completely missed the point which was to show you that the value of T_a, T_b in the expression T_a + T_b, will be different from the value of just T_a or T_b separately.
I have no idea what this sentence means. Can you explain it different words?
I will let Bell answer this in his own words:
Page 449 in his 1966 Paper "On the problem of Hidden variables in Quantum mechanics", Reviews of Modern Physics, Vol 38 (3), 1966.
John S Bell said:
The essential assumption can be criticized as follows. At first sight the required additivity of expectation values seems very reasonable, and it is rather the non-additivity of allowed values (eigenvalues) which requires explanation. Of course the explanation is well known: A measurement of a sum of noncommuting observables cannot be made by combining trivially the results of separate observations on the two terms.
On page 451 of the same article Bell says
John S Bell said:
The danger in fact was not in the explicit but in the implicit assumptions. It was tacitly assumed that measurement of an observable must yield the same value independently of what other measurements may be made simultaneously. Thus as well as P(Φ3) say, one might measure either P(Φ2) or P(ψ2), here Φ2 and ψ2 are orthogonal to Φ3 but not to one another. These different possibilities require different experimental arrangements; there is no a priori reason to believe that the results for P(Φ3) should be the same.
Okay, then you don’t understand Bell's theorem.
[my bolding]
Okay, now you’re refuting that most fundamental property of the most successful scientific theory ever, the very same theory that makes your computer compute and your internet connection connect. Grave...
Sorry Bill, you do not understand the basics in Bell's theorem:
Test angles:
a = 45°
b = 22.5°
RELATIVE angle (a - b) => (45° - 22.5°) => (22.5°)
Correlation STATISTICS for HUNDREDS of entangled pairs at RELATIVE angle 22.5°:
cos^2(22.5°) = 85%
And of course, the type of Bell state (Type I or Type II) decides if we are talking match or mismatch. Period.
Oh... did I mention that in the “Bayesian probability system”, built just for this occasion, there was also included Yes/No/Absent? According to the “system estimation” – you have written hundreds of posts, including thousands of words, on this subject – and now you refuse to type 14 simple Yes/No...
I think anybody with normal intelligence can see what the probabilities for this suggest.
Thanks Bill, you’ve just saved us a lot of time, and I will of course bookmark this post, and link as soon as you bring up this terribly erroneous logic on PF, for anyone to inspect! :biggrin:
End of story.
Take care! :-p
billschnieder said:
Because the expression is incorrect to start with. It is incorrect because you have assumed that terms are equal, which are not.
OK, then that's what we need to focus on. Again, I still want to know whether you agree or disagree with the answers to my two questions are always the same. Because if they are always the same, then I can show that P(A|x) must always equal P(A|w).
Let me repeat the basic logic. Consider a photon before it is measured. By counterfactual definiteness, for every angle setting θ1, there exists a definite, predetermined answer to the question "What result would you get if the photon were measured at angle θ1?". Now if the experimenter can freely choose his measurement decision, then the predetermined answer to this question cannot depend on what he is going to do, so it cannot depend on the angle θ2 he is going to measure at, whether θ1=θ2 or θ1≠θ2. Do you agree or disagree with that? (And please answer this question without discussing probabilities, because it has nothing to do with probabilities.)
If you agree, then I can easily show that for any given photon pair, the truth value of A is independent of the angle settings of the two polarizers. And then from there, I can easily show that P(A|w) = P(A|x).
The fact that a genuine expression exists for w, and none exists for xyz, confirms that. In other words, due to the physical situation "w", there is a single joint probability distribution p(ABC|w) from which you can extract P(A|w), P(B|w), and P(C|w) but there is no joint probability distribution p(ABC|xyz) in the physical situation "xyz" from which you can extract P(A|x),P(B|y), and P(C|z).
I'm not sure what you're talking about here. I never use P(A & B & C|w) or P(A & B & C|x,y,z) in my proof at all.
After substituting the probabilities from the physical situation "xyz" into an expression derived for the physical situation "w", the violation you obtain tells you clearly that the probabilities were not the same as you naively assumed.
If we use a bunch of different assumptions to derive a contradiction, then at least one of them is wrong. You think that what's wrong is my equating of terms. But I gave an argument for why I'm equating terms at the beginning of this post, so the question becomes, where do I go wrong in that argument?
And the impossibility of deriving a similar expression directly in physical situation "xyz" without first going through "w" is a big hint that your assumptions are wrong.
Or a hint that counterfactual definiteness is an essential assumption of Bell's theorem.
To summarize:
Scenarios "xyz" and "w" are just (b) and (c) in the notation you were using earlier, right?
Of course this is the part I disagree with. See my argument at the top of this post for why.
Part 2 is where we part ways.
Are you a real person!? Have you read anything I've written in this thread, at all. Do you understand any of it?
I have already shown you that they must not always be equal. I have used several examples, with quotes from Bell himself to explain to you that they are not equal in the two scenarios. Yet you ask me again if I agree that they are always equal.
As far as I can tell the only response you've given to the argument involving the two questions (which I just restated in my previous post) was in post #262, where you give the example of Bernoulli's urn. But as I said, Bernoulli's urn is an illustration of something involving probabilities, and my two questions do not deal with probability at all.
The two Bell quotes above are also irrelevant to this point: one talks about how the sum of two measurements is not the measurement of the sum, and the other quote talks about probability.
If anything else you've said was a response to my two questions, then I must have missed it, so please tell me if there are any other examples or arguments you have against my two questions having the same answer.
Lugita, you aren’t getting anywhere with this. Check out my post in #274 and Bill’s reply in #275 and you’ll see that Bill can’t keep two balls in the air at once. He – for real – thinks that:
  • QM is wrong.
  • QM measurement outcome is “definite” and “only appears random”.
  • QM measurement of a single entangled photon is not 100% random 50/50 +1/-1.
  • Bell's theorem is not about statistical correlations, but probabilities for a single photon.
  • The cos^2(a - b) rule is not about the relative angle between Alice & Bob.
  • Instead we can apply cos^2(θ) for any single photon/angle outcome.
  • We can use Bayesian probability theory to investigate single photon properties, before measurement.
  • At lot of measurements (hundreds/thousands) is not needed to get the (statistical) correlations.
  • Experimental outcome/statistics of EPR-Bell test experiments is wrong.
  • The definite property of LHV is not obligatory.
  • Bell's inequality is not an upper limit for Local Realism only.
  • To test QM against Bell's inequality, QM needs to posses the same basic properties as Local Realism, otherwise the test is groundless, i.e. Local Realism and QM has to be on the same footing, to be rigorously tested against Bell's inequality.
And AFAIK, Bill seems to think that QM and Local Realism is really the same thing, except for some “mysticism buffoons” [i.e. the rest of the world] who got it all wrong... :smile:
This discussion will take you nowhere.
lugita15 said:
Because if they are always the same, then I can show that P(A|x) must always equal P(A|w)..
Are you for real? You want to argue that two probabilities are always the same, yet you do not want me to mention probabilities when explaining to you that they are not always equal. :eek:
Contrary to your claims, they in fact do because you are using them to claim that two probabilities are the same. Isn't that what this is all about. I don't care about your two statements, I go directly to your claim that the probabilities are equal in the two scenarios and I show you that they are not. Besides, I have given you examples that have nothing to do with probability. For example:
That is because you do not understand the argument. They are very relevant. You are making the same tacit assumption Bell refers to in his second quote, that a measurement being made in one scenario will always give the same result in a different scenario, you naively assume that probabilities from scenario "xyz" can be used in scenario "w". You are making the same error, that Bell talks about in the first quote, because you assume that the sum of two noncommuting observables P(A|w) + P(B|w) can be obtained by combining trivially the results of separate observations on the two terms P(A|x) + P(B|y)
Ok for the last time, please pay attention carefully.
1) You do not have a single angle, you have two angles (a,b) for the photon pair, where your θ1 = (a-b). And you have two angles (a,c) where your θ2 = (a-c).
2) You are not considering each result independtly, you are considering them jointly in the same expression, in fact adding them together "answer_at(a,b) + answer_at(a,c)" ...
3) You are claiming that in the expression you have which includes both answers, the answer at (a,c) can not depend on the answer at (a,b).
However, NOTE: we are talking about the same photon pair measured at (a,b) and counterfactually measured at (a,c). Let us call the photons p1 and p2 where p1 is sent to Bob and p2 is sent to Alice. In the factual measurement at (a,b), Bob measures p1 at angle a, and Alice measures p2 at angle b. Now in the counterfactual measurement, Bob is not doing anything differently that what he already did. ONLY Alice's measurement would have been different because she is now doing the measurement at angle "c" instead of "b" at which she measured previously.
Therefore, contrary to what you naively thought, the result you would have obtained counterfactually at (a,c) does depend on the result you obtained for (a,b) for the simple reason that the same photon can not counterfactually give you something different when measured at "a", than what was already obtained at "a". In other words, Bob's result at "a" for the (a,b) measurement, constraints Bob's result at "a" for the counterfactual measurement (a,c). Get it?
Let us assume that the outcomes for each photon can be either + or -. Let us now replace the angles in the expression "answer_at(a,b) + answer_at(a,c)" with the corresponding answers for the counterfactual situation. If the measurement at (a,b) gave the answer (+,-), we now have "answers(+,-) + answers(+,c)". Do you notice that because we already have the answer for the first term, we therefore already have part of the answer for the second term, since we are talking about the same photon? Do you realize that although the result (a,c) is counterfactual to (a,b), it is in fact only Alice's part of the measurement that is counterfactual? Do you realize that to be consistent, Bob's part of the answer can not change from the factual?
Now what about three different photon pairs where the (a,b) measurement is performed on (p1, p2) and the (a,c) measurement is performed on a different pair of photons (p3, p4). In this case, we do not have any counterfactual measurements. Bob's result for p3 is not constrained by Bob's result for p1, because they are different photons which are free to have different results.
In other words, in scenario "xyz", there are no logical relationships between results from the sets of photons "x", "y" and "z" because they are three different sets. However in the scenario "w", we are talking about the same set, and therefore there are logical relationships between measurements on that set.
Obviously, you are wrong and completely off base.
If I understand, the independence lugita15 is talking about is independence between what properties a particle has when it becomes entangled and what measurement we decide to make. Since the LHV theory is that properties of the particles determine measurement outcomes, we can use measurement outcomes as proxy for properties.
Let A+ be the proposition that the particle would measured + in orientation A, and x be the event that we actually measure in orientation A. Let B+ be the proposition that particle would be measured + in orientation B and y be the event that we actually measure orientation B. Let w be the event that we measure the particle at all. Independence says that P(A+|x) = P(A+|y) = P(A+|w). Same for B+.
In the quoted passage, you are talking about P(B+|A+ & x). No one assumes B+ is independent of A+ & x, so your argument here does not undermine lugita15's or Herbert's proofs.
BenjaminTR said:
If I understand, ...
and x be the event that we actually measure in orientation A. ...
Huh? You have completely misunderstood the argument. Please go back and re-read the thread from page 15, carefully in order to understand what we are discussing.
billschnieder said:
Le us represent the sets of photons as one set "w" for scenario (c), and three different sets ("x", "y","z") for scenario (b). The the probabilities for (c) are more accurately represented as P(A|w), P(B|w), P(C|w). ...
However the probabilities for scenario (b) are more accurately represented as P(A|x), P(B|y), P(C|z).
I was talking about individual photons, and then I was going to move to photon pairs. But if you want to start with photon pairs that's fine.
What I'm claiming is that before measurement, the answer you would get at (a,c) is entirely predetermined, and it can't depend on whether you're going to measure at (a,b) or (a,c).
I agree with this.
The thing is, for any given photon pair, both what you would get at (a,b) and what you would get at (a,c) is entirely predetermined beforehand, before you make the measurement at (a,b). Do you agree or disagree with that with that?
The point is, that the predetermined answer to the question "What would you get at (a,c)" can't depend on what you're going to measure later on, because (by assumption) you have free will and can choose to measure anything you want.
Yes, this is all fine.
The point is, for any given photon pair, what you would get at (-30,0) is entirely independent of whether you're actually going to measure at (-30,0) or (0,30), because at the time that the answer to the question "What would you get at (-30,0)?" is determined, the experimenter hasn't yet made up his mind about whether he'll measure at (-30,0) or (0,30).
So the question of what you would get at (-30,0) is independent of whether the photon pair is going to be in set x or set y, and thus the percentage of pairs in set x for which you would get R1 at (-30,0) is the same as the percentage of pairs in set y for which you would get R1 at (-30,0). Do you agree or disagree with that?
I agree with this. I also agree that the outcome of any measurement is predetermined no matter the angle.
I don't think you fully understand the implication of this claim. It is not correct to say the outcome at (a,b) does not depend on the angle (a,b) or the outcome at (a,c) does not depend on the angle (a,c), since those settings are part of the set-up which produces the outcome. Probably what you are trying to say is that the outcome of the single photon measured at angle "a" in the (a,b) pair must be exactly the same as the outcome of the same photon measured at angle "a" in the (a,c) pair. In other words, the outcome for that particular single photon should not change from (a,b) to (a,c) just because it's sibling was measured at "c" in (a,c) instead of "b" in (a,b). So Alice's choice of setting should not influence Bobs outcome for the same setting "a" and the exact same photon. If this is what you mean, then I agree. But if you mean that the outcome at (a,b) can not depend on the angle pair (a,b) then I disagree with that.
I agree.
No. I disagree with that. Just because it is predetermined to produce the result at (a,c) doesn't mean it can produce the result without (a,c). Without the setting (a,c) you will not get the result at (a,c) so how can you say the result obtained at (a,c) does not depend on what you actually choose (a,c)? What is predetermined is the condition that "if you set the device to (a,c), you will obtain such and such result". It doesn't make much sense to say the result you obtain at (a,c) does not depend on the setting, which is required to obtain the result! Free will has nothing to do with it. You are free to choose a different setting, you will get a different result. But whenever you freely choose (a,c) you will get the result predetermined for (a,c). Probably what you are trying to say here is that the result for the single photon measured at angle "a", should not depend on whether you measured the pair at (a,c) or you measured (a,b). Again, that means Bob's result for the same photon measured at the same angle should not depend on what angle Alice chose to measure it's sibling photon at. If this is what you mean, I agree.
See explanation above. The results predetermined for a given angle pair can not be independent of the angle pair for which it is predetermined.
No! The same photon can not belong to two different sets. If a specific photon is predetermined to give a result at -30, then obviously the result when that specific photon and it's sibling are measured at (-30, 0) respectively CANNOT CONTRADICT the result when that same photon and it's sibling were instead measured at (-30, 30). In other words, the same photon can not be predetermined to have different results at the same angle, however, two different photons can be predetermined to have opposite results at the same angle. Do you agree with this?
Remember I'm explaining why the results from three different sets "x", "y", "z" are not the same as the results from one single set "w".
Scenario "xyz"
A_x: results from measuring photon set x at angles (a,b)
B_y: results from measuring photon set y at angles (a,c)
C_z: results from measuring photon set z at angles (c,b)
Scenario "w"
A_w: results from measuring photon set x at angles (a,b)
B_w: results from measuring photon set y at angles (a,c)
C_w: results from measuring photon set z at angles (c,b)
Your claim is that the results from Scenario "xyz" are the same as the results from scenario "w", ie, A_x = A_w, B_y = B_w and C_y = C_w.
For scenario "w", the results at angle "a" when measured at the angle pair (a,b) must be the same as the results for angle "a" when measured at angle pair (a,c) and the results for angle "b" when measured at angle pair (a,b) must be exactly the same as the results for angle "b" when measured at angle pair (c,b) etc.. for "c" too. This is the case because we are dealing with the same set of photons "w". There is therefore a cyclic logical relationship between the results at (a,b), (a,c) and (c,b).
However, for scenario "xyz", since each result is obtained from a different set of photons, the results at "a" in the (a,b) pair can be different from the results for "a" in the (a,c) pair and the same for "b", and "c". There is therefore no cyclic logical relationship between the results at (a,b), (a,c) and (c,b) in this scenario.
Note. In all of this explanation, the results for a specific photon measured angle "a" does not depend on the angle at which it's sibling was measured at, and all the results are predetermined.
Another way to look at this is to say that results drawn from a single set "w" have additional constraints between them that results drawn from three different sets "x", "y", "z" do not have. These are the constraints that Boole worked on 150 years ago. So knowing the result (a,b) from "w" give's you insight into the properties of "w" which might be important for the results (a,c) and (c,b). However knowing (a,b) from the set "x", gives you no insight into the properties of "y" which are important for the results (a,c) or the results (c,b) from another set z. Because the sets are all different.
This is why I disagree with your claim is that the results from Scenario "xyz" are the same as the results from scenario "w", ie, A_x = A_w, B_y = B_w and C_y = C_w.
Pretty sweet, you’ve summarized Bell’s theorem in a single line.
And many will draw the logical conclusion that Boole was probably not completely familiar with the life of QM photons (that wasn’t ‘invented’ until 1926), hence Boole’s work will almost certainly say very little (if anything?) about the properties of unmeasured QM photons.
This of course, is just a personal speculation.
As usual, you say much about stuff you know little about. This is not Bell's theorem.
What you do not know is that Bell's inequalities were originally discovered by Boole. Boole found that one of the constraints that properties from a given set must obey to be logically consistent was Bell's inequalities. Bell re-discovered the same rules without knowing that Boole had already discovered them a century earlier. One thing Boole also found out, was that properties from a single set can never violate the inequalities but properties from different sets can.
Remember this article I mentioned earlier:
Bell's inequality is simply one of "Boole's conditions of possible experience".
It occurs to me that when you use the word "depend", you may be assuming causal dependence. You are thinking that since what happens later can not change what happens earlier, it means what happens earlier cannot "depend" on what happens later. But this is just wrong, dependence does not have to mean causation, that is why I gave you the Bernouli urn example. Two events can be causally independent and yet logically dependent.
I didn’t expect you to recognize it.
There’s only one “little” glitch, that you constantly refuse to discuss.
We can use classical logic to calculate the properties of unmeasured Local Hidden Variables that acts the classical way, but I sure hope you are not saying that Boole – 150 years ago – developed a “quantum logic” that makes it possible to deal with superposition, entanglement, uncertainty principle, etc??
Besides this erroneous approach – you’re arguing that a single QM photon/pair could give you the correct probabilities/correlations, when we all know that a single QM outcome is always 100% random, no matter what angle. We need hundreds of measured entangled pairs to get the correlations, which you refuse to discuss or admit.
The stochastic nature of QM is fundamental – and absolutely not only “appears random” – to quote your own catastrophic lack of knowledge.
Hence, Boole works excellent for LHV in every instance – before & after measurement – and it even works for a single “LHV photon” outcome, because they must be DEFINITE/PREDETERMINED. However, Boole can’t say anything about QM photons before measurement, and a single QM measurement outcome is always 100% random.
This is what I mean when I say that you can’t keep two balls in the air at once. You refuse to see there’s a BIG difference between unmeasured “LHV photons” and unmeasured QM photons, and not even dear old Boole can help you get them on same footing.
The only thing you can do is to deal with measurement STATISTICS for hundreds/thousands of QM photons, and there goes your “personal theory” down the drain, and this is why you react the way you do.
I’m not expecting any other reaction this time.
There is nothing coherent here to respond to. You probably think you are making a lot of sense but somebody needs to tell you that this is nonsense. It is difficult to discuss with somebody who does not even understand the basics of the topic let alone thinking rationally about any topic.
billschnieder said:
Scenario "w"
What I meant to say here is:
A_w: results from measuring photon set w at angles (a,b)
B_w: results from measuring photon set w at angles (a,c)
C_w: results from measuring photon set w at angles (c,b)
Lugita15, ask Buffalo* Bill exactly what set x and set w represents in terms of number of photons and exactly where in the process – before/after measurement – he perform his magical pet theory.
(and don’t forget to wear raincoat against the flood of personal insults)
*droppings
In Bell-test experiments, to measure the probability of mismatches at angle pair (a,b), the Alice sets her polarizer at angle "a", Bob sets his to angle "b", the source is turned on and hundreds of thousands of photons or even millions of photons go through. Everytime a photon goes through Alice's device she records the detector which fired, either a +1 or a -1 for D+ or D- respectively. At the end of the "run", Alice has a long list consisting of +'s and -'s in random order and Bob has a corresponding list. The lists are brought together and you have something that looks like:
ab
... etc
for as long as there were photon pairs produced, where each row corresponds to results from one single photon pair. It is this list that is used to calculate the C(a,b), or probability of mismatches, or any other statistic you may want to calculate for the angle pair (a,b) in the Bell test experiment. Let us call the set of photons which produced this list "x".
Each photon can only be measured once, being destroyed in the process. Therefore to measure at the angle pair (a,c), a different set of photons has to be used, in a similar manner as above. Let us call this set "y". And similarly, yet a different set "z" is needed to measure at the angle pair (b,c).
Each of the sets "x", "y", "z", is a different set of photons. In other words, no photon belongs to more than one set. No photon is common between those sets because no photon was measured more than once.
An alternative method of doing the experiment involves random switching of the angles by Alice and Bob. However, in the end, to calculate statistics for (a,b), they select only those photons measured when Alice had her device at angle "a" and Bob had his at angle "b". it is this set that we called "x", and the other two are "y" and "z".
Therefore, it should be obvious that for any Bell test experiment the correlations, C(a,b), C(b,c), C(a,c) are each measured on a distinct set of photons. If you prefer, P(A|x), P(B|y), P(C|z) are each measured on a different set of photons. In other words, we have 3 different sets of photons (x, y, z). This is what is referred to in the above discussion as scenario "xyz" and it refers to the way experimental correlations are measured.
The QM predictions are similarly made for separate sets of photons, and not surprisingly, the QM predictions match the experimental results.
billschnieder said:
...The QM predictions are similarly made for separate sets of photons, and not surprisingly, the QM predictions match the experimental results.
That is ALL that a Bell test is. Because Bell says that LR theories cannot match QM results, ergo at least one of QM or LR theories are wrong. It isn't QM, as experiment shows.
Glad to see you finally admit that LR requires that for any photon, the results of a measurement must be predetermined. Now all you have left to do is draw the Bell conclusion, and we will let you join the rest of us.
