Why do solids maintain their individual identity when placed together?
  • Level: High School
  • Thread starter Graeme M
    Solid
80 replies · 11K views · last reply
even if they have similar atomic structure or conform each other.., they(Molecules) have to first break their bonds with neighboring Molecules...to merge with foreign Material .(be it similar or different material).
There is a interesting phenomenon that if sth stuck on the ground for too many years, it would be impossible for u to remove it,or clean away its color.this can be seen in some old house.I think this is because the molecules r in constant motion , and somehow run into each other .
And as they merge the resulting ions freed attempt to find entropy around the surface of the new system.
i think it maybe due to the perfect formed between the particles in the course of time...
like...all known surfaces have atleast some irregularities on the surface and there exists some air between the irregularities and hence a perfect physical contact is not maintained and when 'something' is left on the ground for a longg while.. these irregularities maybe break if necessary and due the course of time come into greater physical contact with each other and the air between them is eliminated...
also note that if there's nothing (vaccum) between two substances , then they stick to each other like Glue. .. :)
Or in the case of Au and Ag they fuse perfectly with virtually no effort at all...
Oh ..Cool..!...i didnt know that...and is it universal..? like...no required conditions at all..?
Lol...just read that like 10 min ago ... :P . ... well didnt read about that Au and Ag though...
Atoms from two metals in contact and diffuse into each other, and this is particularly the case the lower the melting point.
In the normal day to day experience (at what we call room temperature or in the temperature range we normally experience (excluding fire and other forms of heat)), solids tend to retain their shape, but we can load them such that they creep or flow. Flow usually implies internal stresses above the 'yield strength' (YS), while creep occurs below YS. Furthermore, solids become 'less' solid as temperature increases, especially as temperature goes beyond about 1/3 of the melting temperature. As temperature increases, YS decreases and the stress required to produce a given creep strain or flow becomes less.
Some metals for eutectics in which they melt each other at temperatures below the pure element melting temperature, but that's another matter.
http://en.wikipedia.org/wiki/Eutectic_system
Liquids, where interatomic/intermolecular bonds still exist, tend to 'readily' assume the shape of whatever vessel contains them.
On earth, metal surfaces attract and bond to atmospheric molecules creating a barrier. This is not an issue in the vacuum of space, which makes what is called cold welding possible. Google on cold welding for further information. You can even do this on Earth with highly polished surfaces - e.g., wringing of gage blocks or optical flats. They can permanently fuse together if left wrung for too long.
Why solids are solid is explained by the Exclusion Principle. As I understand it, Graeme's question is something along the lines of " if atoms are mostly empty space, why do things feel solid. This is explained but he exclusion principle which was proposed by Wolfgang Pauli. It states that no two fermions of the same kind ( there are two kinds of particles- fermions, which are electrons, protons etc and bosons, which are things like photons and well, the Highs Boson) can occupy the same state.
In a solid, atoms are packed together. So, when we place another solid on it( say our hands) the electrons in our hands and the nuclei of the atins in our hands get close to those of the other solid. Because they can't be in the same state there is a repulsion between the two surfaces. So we feel them to be solid and distinct. In liquids, since the molecules are much further apart, new fluids and even solids can mix without feeling significant repulsion due to the exclusion principle.
Gallium is very good at that, and there are videos how it can destroy the stiffness of other metals.
It's not only highfalutin gallium that produces that sort of effect. Mercury will eat holes in aluminium and, they say, will cause panic if spilled in an aeroplane. Apparently, it alloys with the aluminium, which then oxidises at the surface, releasing more mercury, to carry on the dirty work. Jewellers run a mile when lead turns up because it alloys with hot silver and just won't go away. Lead solder is, of course, banned.
I would take a bit of an issue with the PEP being the 'reason' for solids being solids. Isn't it more just a re-statement of the way they behave?
I would take a bit of an issue with the PEP being the 'reason' for solids being solids. Isn't it more just a re-statement of the way they behave?[/QUOTE]
In what sense is it a re-statement?
In what sense is it a re-statement?[/QUOTE]
What I meant is that the "principle" is just that. It's an observation of the way things behave and the behaviour is observed to occur inside atoms and that behaviour extends to situations involving many atoms. PEP is 'only' (no value judgement here) a statement about the way a lot of particles behave. I guess I was being picky because there is always a temptation to seek and produce 'reasons' for things - which are really only shifting the crux of the explanation further away - and that is only the best we can hope for. This was a Feinman thing. Many of the 'explanations' we come up with are little more than 'bootstrap' arguments. Just why Fermions are like they are is not understood (?) yet.
Isn't that being a bit pedantic? I admit that yes, it isn't the "reason " its just explains it- but isn't that true of all physics? Of all sciences? And true - why fermions behave as they do isn't understood completely yet, but feynman mentions in the Feynman lectures that Pauli did work out a ( complicated) explanation.
I guess so. But my first instinct is to shy away from 'explanations' when the are presented as a 'deeper' truth - rather than what they usually (always?) are.
But sometimes explanations are deep. Look at the PEP- that basic concept- that no two fermions can occupy the same state underlies so many other things in physics and in chemistry.
Absolutely. The PEP applies everywhere. Perhaps I was thinking that the agency through which it manifests itself - i.e. the intermediate step in the explanation is to consider EM forces - is more what is required in the thread. I have to acknowledge that the link to PEP was well worth while stating here, though.
HAHA - I am getting more and more convinced that I was out of order with that comment I made.
This has been used industrially in connecting two metal piece
