Why Do We Use Integrating Factors in Solving First Order Linear ODEs?
4 replies · 8K views · last reply
Saladsamurai
Hello all! :smile: I through a section in my text (by https://www.amazon.com/dp/0133214311/?tag=pfamazon01-20) on 1st Order linear ODEs. I am understanding the derivation of the integrating factor method pretty well; however, there are some aspects of the mathematics that I am getting hung up on. I have an "engineering" background in calculus and hence I get slowed down by the details sometimes.
In order to find the solution to an ODE of the form:
[tex]y' + p(x)y = q(x)\qquad(1)[/tex]
we first consider the homogeneous case; i.e.,
[tex]y' + p(x)y = 0\qquad(2)[/tex]
After some hootenanny, we arrive at the solution to (2) given by
[tex]y(x) = Ae^{-\int p(x)\,dx}\qquad(3)[/tex]
Now, in order to solve for the constant 'A' given the initial condition y(a) = b, it says that
"...it is convenient to re-express (3) as
[tex]y(x) = Ae^{-\int_a^x p(\xi)\,d\xi}\qquad(4)[/tex]
which is equivalent to (3) since [itex]\int p(x)\,dx \text{ and } \int_a^x p(\xi)\,d\xi[/itex] differ at most by an additive constant, say D, and the resulting [itex]e^D[/itex] can be absorbed into the arbitrary constant A.
Question 1:
I am not sure why he even brought this up? Why would changing the dummy variables cause the two integrals to differ *at all* ?
Moving on to the homogeneous case:
Basically we wish to multiply (2) by some function of x, say [itex]\mu(x)[/itex] giving
[tex]\mu(x) y' + \mu(x)p(x)y = \mu(x)q(x)\qquad(5)[/tex]
so that the left-hand-side of (5) is a derivative. After much more hootenanny, we arrive at the solution
[tex]y(x) = e^{-\int p(x)\,dx}\left(\int e^{\int p(x)\,dx}q(x)\,dx + C\right)\qquad(6)[/tex]
Now again, if we wish to solve for the constant 'C' given the initial condition y(a) = b, we are again advised to use a different expression of (6), namely
[tex]y(x) = e^{-\int_a^x p(\xi)\,d\xi}\left(\int_a^x e^{\int_a^\xi p(\zeta)\,d\zeta}q(\xi)\,d\xi + C\right)\qquad(7)[/tex]
This is just too much changing of dummy variables for my feeble mind to handle :redface: .
Question(s) 2:
There are 3 dummy variables being used here:
[tex]e^{-\int_a^x p(\xi)\,d\xi}\qquad(8)[/tex]
[tex]e^{\int_a^\xi p(\zeta)\,d\zeta}\qquad(9)[/tex]
[tex]q(\xi)\,d\xi\qquad(10).[/tex]
I am not really sure what is happening here. They are using [itex]\xi[/itex] in (8) and (10) as dummy variables and in (9) as an endpoint of the integral.
I don't expect anyone to answer all of this at once, but i would love to start a discussion about it so that I can solidify my understanding of the derivation. It's not enough anymore for me to just be able *to use* the integrating factor, but instead to *understand it.*
Thanks,
Casey
Anyone have any thoughts or comments? Thanks :smile:
Question 1:
Changing the dummy variables doesn't change anything and that's not what they are saying. The important change is the limits of integration.
[tex]\int p(x)dx[/tex]
without any limits of integration , is the "indefinite integral". If F(x) is an anti-derivative of p(x) then [itex]\int p(x)dx= F(x)+ C[/itex] where C is an arbitrary constant.
[tex]\int_a^x p(\xi)d\xi[/tex]
is an definite integral just with the variable x as an upper limit: with F(x) an anti-dervative as befor, it would be equal to F(x)- F(a). In other words, the "C" is now specifically -F(a).
One good reason for doing that is that a person seeing
[tex]e^{-\int p(x) dx}\int e^{\int p(x)dx}[/tex]
might think, mistakenly, that the two exponentials cancel. They don't of course- you cannot take a function of x "inside" the integral like that.
Question(s) 2:
No, that is not the case. In
[tex]e^{-\int_a^x p(\xi)d\xi[/tex]
[itex]\xi[/itex] is a dummy variable- the integral will be a function of x.
In
[tex]e^{\int_a^\xi p(\zeta)d\zeta[/tex]
[itex]\zeta[/itex] is a dummy variable but [itex]\xi[/itex] is not- this integral will actually be a function of [itex]\xi[/itex] so that it can be integrated with respect to [itex]\xi[/itex] in the outer integral:
[tex]\int_a^x E(\xi)q(\xi) d\xi[/tex]
where "[itex]E(\xi)[/itex]" is the result of the previous calculation,
In that last integral, yes, [itex]\xi[/itex] is a dummy variable- the integration is a function of x.
Thanks,
Casey
I'm learning differential equations, and although I understand the methods I have learned thus far, I often have trouble seeing what is the reasoning behind them.
Take for example, the use of the integrating factor when solving first order linear ODE's. I understand how to use it, but I'm not sure where it came from. In the resources that I'm using there's really not explanation, instead the discussion is limited to: assume there's a function by which we can multiply our differential equation to make it integrable.
Can anybody explain why we use this approach?
thanks,by (Erik006)
thanks,by (Erik006)
I think the key is product rule. namely
(my)'=m'y+my'
Let's say you have a DE
y'+py=q
you want to make it look like product rule by multiplying both sides such that:
my'+mpy=mq
No quite product yet, but if mp=m' then
(my)'=mq
now that y can be solved by integrating both sides. m is very easy to solve given mp=m'.
