Why does 2 arcsin(√x) + C equal arcsin(2x - 1) + C?
13 replies · 3K views
Crystal037
Integrate 1/(x(1-x))^(1/2)dx
Integral of 1/rt(1-x^2)dx = arcsinx
Let x=t^2
Then dx=2t dt
Integral of 1/(x(1-x))^(1/2)dx
= integral of 2tdt/t(1-t^2) ^(1/2)
= integral of 2dt/(1-t^2) ^(1/2)
= 2 arcsin(t) +c
= 2 arcsin(rt(x)) +c.
But the answer in my book is arcsin(2x-1) +c.
Tell me how
2 arcsin(rt(x) +C= arcsin(2x-1) +c
I know the constant will vary for both the answers and both the answers must come equal after some manipulation. Is my answer correct.
Try to prove that ##2 arcsin(x)-arcsin(2x-1)## is a constant.
Just denote be ##y=arcsin x## and then ##2x-1 = 2\sin y -1##, so you need to show that the following is constant: ##2y-arcsin(2\sin y -1)##, if you denote this by ##u## you get: ##2y-u=arcsin(2\sin y -1)## which means that: ##\sin (2y-u) = 2\sin(y)-1##; from here you need to solve a trig equation like in high school.
Crystal037 said:
Homework Statement:: Integrate 1/(x(1-x))^(1/2)dx
Relevant Equations:: Integral of 1/rt(1-x^2)dx = arcsinx
Let x=t^2
Then dx=2t dt
= 2 arcsin(t) +c
Tell me how
One good thing about doing integration is that you can always check your answer by differentiating it to check you get back the integrand.
I don't understand, however, this variable ##r## that seems to come and go from one line to the next.
There is no variable r I used rt to denote root
Yeah I differentiated it and the answer is correct. Thank you
I am getting LHS as a function of cos2y and sin 2y while RHS only as a function of cos2y. Where am I getting wrong
Crystal037 said:
I am getting LHS as a function of cos2y and sin 2y while RHS only as a function of cos2y. Where am I getting wrong?
The quickest way must be to differentiate, surely? If the derivative is zero, then the function is a constant. And, setting ##x =0## will give you the constant.
Otherwise, you need the double angle formula.
For integrating, even more simple I think just substitution in original x = t + ½ .
Using a graphing calculator you can find that ##\displaystyle 2\arcsin(\sqrt{x}\ ) - \arcsin(2x-1) ## is ##\dfrac{\pi}{2} ## .
This suggests that ##\displaystyle 2\arcsin(\sqrt{x}\ ) - \dfrac{\pi}{2} = \arcsin(2x-1) ##.
Take the sine of the left hand side and you get ##2x-1##, after a bit of manipulation.
Your integral is:
$$\int \frac{1}{\sqrt{x(1-x)}} dx=\int\frac{1}{\sqrt x}\cdot\frac{1}{\sqrt{1-x}} dx$$
Doesn't ##\frac{1}{\sqrt x}## remind you of the derivative of some function? Don't you think that ##x=(\sqrt x)^2##?
Nice one!
