arevolutionist
- 60
- 0
What causes a boomerang return?
Because there's a torque on it. The aerodynamic force exerted on each blade is not equal, since the blades move through the air with different speeds. (While one blade rotates forward, another rotates backward.)giordano bruno said:Yes but what i wonder is whys that the boomerang precess since is a case of balanced gyroscope
I though it was actually a cloverleaf i.e. 4 lobes.Jeff Reid said:Not only do boomerangs return, but some shapes will fly in a figure 8 pattern, if you don't catch it on the initial return, it will fly by and circle in the opposite direction and return again.
The point pretty much is that the thing isn't balanced. One arm is longer than the other, so the centre of rotation is offset from the radius of the bend.giordano bruno said:Yes but what i wonder is whys that the boomerang precess since is a case of balanced gyroscope
I answered that in post #5--there's a torque on the boomerang! (By "unbalanced" gyro I assume you mean a gyro with an unbalanced torque acting on it--that's what causes precession.)giordano bruno said:So my question is if precession only happens only on unbalance gyros how comes it appears in a boomerang that is a balanced one being the COG and axe in the same point
giordano bruno said:The wiki doenst talk too much on the physics of it
Intuitivile you may consider than when it is spinned around its center of gravity there's more mass on one side of the boomerang than in the other but this is false by definition of center of gravity
On the other hand i had a boomerang which was regular not with wind shape and still worked
Danger said:The point pretty much is that the thing isn't balanced. One arm is longer than the other, so the centre of rotation is offset from the radius of the bend.
