Why does a red metal bucket turn dark when heated?
  • Context: Undergrad
  • Thread starter Thread starter Awwtumn
    Color Metal
35 replies · 5K views
Awwtumn
This is the color of the metal bucket when it's not hot. But whenever it is hot, the red changes to dark, and then back to red again when it is not hot. See the following youtube where I just threw the fake money at the bucket (see background below). Can you explain how the phenomenon work? Maybe related to Blackbody Radiation or something?
In the bucket, I'm burning fake money at the cemetery which our family does a few times a year. In this particular time, it's middle of so called Ghost month. The Chinese tradition believes that during certain period in a year, there is loosening of barrier between our world and the dark world (although they didn't say dark matter world).
Of course, we Newtonians can just scoff at the idea, we can prove with our nut and bolts machine that there is no dark world or something.
Looks like thermochromism of the coating of the bucket, but I couldn't say exactly what's happening at the molecular level or anything.
Thermochromic pigments indicate temperature by changing their structure at a particular temperature. The different structures have different optical properties and so have different colours.
https://en.wikipedia.org/wiki/Thermochromism
Low temperature thermochromic pigments use organic molecules.
This example changes at 31°C, when warmed by the body.
https://www.ebay.com.au/itm/125358953763?
High temperature thermochromic pigments are usually inorganic minerals.
https://en.wikipedia.org/wiki/Thermochromism#Inorganic_materials
The metal bucket is just cheap. Did they intentionally put thermochromic pigments in the paint or is it usually un-intentional?
The fact that the change is high temperature and reversible suggests it was intentional.
The material goes black when hot, which is unusual. It may be that the pigment becomes transparent when hot, which allows a black base to show through. If you scratch the outer paint, you will be able to see the base layer. What is that colour?
Red haematite, Fe₂O₃, is rust red and changes to black magnetite, Fe₃O₄, when heated. The recovery takes weeks when cooled, because it requires oxygen from the atmosphere.
  • Love
The base material is black (see above photo). The red paint turns transparent when hot? What particular pigment is that? Haven't encountered it before.
I was initially thinking of blackbody radiation that interacts with the paint. But the metal could melt if it reaches the temperature that could interact with the red to produce black, isn't it.
While black body radiation is typified by a substance "glowing red hot", red paint not so much. A quick google turned up a chroma-paint which has the attributes you're looking for (also available in blue and green), but the change was at 31C, somewhat lower than what you want.
In the above video. I lit a lighter just below the red cover. The coating changed to dark hue. But notice it didn't become transparent because you can clearly distinguish the coating and black base underneath. So what material or coating is it which changes to dark color when heated and return to original red color when cooled as you can clearly see at the end of the video? Is it still thermochromic pigments? But notice the pigments didn't turn invisible.
What happens to the atomic levels in the above demonstration?
In the above video. I poured boiling water over the alleged thermochromic paint. It didn't change color or become transparent. Such paints are supposed to change color instantly with hot water applied.
So it's not a thermochromic paint.
When you applied lighter flame from below the metal. The metal was not supposed to glow because it was not heated to melted molten. So how did the red color change to dark when heat was applied? What other phenomenon could explain?
Perhaps its a thermochromatic paint that doesn't change color until well above the boiling point of water?
Could the effect be an optical illusion due to the index of refraction of air at very high temperatures? Perhaps something akin to a mirage?
No, mirages don't work like that. They won't change the color of an object in this manner, and certainly wouldn't turn the bucket brown/black from red.
I didn't mean exactly a mirage but some optical effect especially the index of refraction at very high temperatures?
Nope. Any such effect would severely distort the image of the bucket, which isn't seen.
What brand is the burner? Have you asked the maker?
It's just a cheap generic metal bucket from Chinatown. No brand, manufacturer unknown.
After knowing about the existence of thermochromic stuff. I bought a so called magic mug (see above video )where you can put any pictures or images on it, and once you pour hot water, the images will come out.
It's cool. This seems to be activated below boiling point of water. But for those thermochromic metal that can be activated only with temperature of flame. Isn't there a product where this is used as some kind of fire detector (imagine a laser shining on the black paint, and when it becomes transparent from heat from flame, it will reflect back full blast and sound off the alarm).
Also it seems in high temperature thermochromism. Some form of phase transition or charge transfer mechanism occurs.
Light is normally scattered at the incidence angles but in a mirage it is bent like in this image so if you were looking from above you might see less incident light being reflected and perhaps notice a slightly dimmed surface. For the bucket if the hot spot refracts incident light along the bucket surface then an outside observer might see a dark spot.
There's no reason for a dark spot to appear, as light from somewhere else would be deflected into your eye and you would see a distorted image of whatever object that light came from.
I gave my friend a thermochromic mug but she refused to drink from it. I can't find reference what would happen if the thermochromic dye in the mug got hot and interaction with skin. My friend said she was afraid the invisible dye may slowly sip into her lips and she saw Hollow Man once and didn't want her lips to turn become transparent showing her teeth.
In mugs, how do they exactly print it, won't an ordinary ink seep into your lips when the mug is hot with coffee?
Lastly, would ordinary paint and thermochromic paint have same toxicity profile? Thousands of thermochromic mugs exist worldwide so we ought to this aspect of it. Thank you.
  • Wow
No, the coating shouldn't wash off. And even if it did, it wouldn't turn your lips transparent. It's the coating itself that changes colors or becomes transparent, not the underlying material, so that even if you coated your own lips with a fresh layer, all someone would see is your regular lips once the coating got hot enough to change. Just imagine wearing lipstick that turned transparent. It would just look like you weren't wearing any lipstick, you wouldn't be able to see through your lips.
I can't say. There are thousands of different types of paint. Some are harmful, some are not. I expect the same is true of thermochromic paints as well. Presumably the ones used to make mugs are not harmful.
The web marketplace is now flooded with low-temperature, polymer-based thermochromic pigments. Those pigments have been selected to change for body heat, or hot water. The pigments are bound in a clear paint, so they will not flow like a wet ink.
Unfortunately, the plethora of gimmicks available on the web, makes it hard to search and find the higher temperature pigments on the web.
When thermochromic paint got heated and become invisible. What part of the spectrum is it hiding? In the infrared maybe?
Why are there no natural physical objects that only exist in the infrared or other frequencies and hence invisible to the naked eye? Or since I remember infrared is heat. Why do objects only occur in visible wavelength?
You mean like glass ?
There are plenty of objects that are transparent to visible light. Glass, some types of plastic, wings of insects, water, air, etc. Similarly, there are objects that are transparent in infrared but not in visible light, such as plastic trash bags.
I don't see the following explanation anywhere.
Can we say the covalent and ionic bonds of atoms correspond to energy levels of the visible wavelength of photons? (except those of glasses, some types of plastic, wings of insects, etc.).
And to change those normally visible object to transparent, you have to adjust the covalent and ionic bonds of those solids to say that of glass? And this is not possible without shredding the objects electrons?
Something like that, yes. For a coating that turns transparent, the electronic energy levels of the molecules are altered by the increased temperature such that they no longer correspond to visible wavelengths, much like glass.
Electrons cannot be shredded, for they are fundamental particles and can't be subdivided into anything else.
Did you mean to say shedding instead of shredding?
There are very many different mechanisms that result in thermochromism.
Find a copy of this 220 page book: Lötzsch, Detlef; Seeboth, Arno; Thermochromic and Thermotropic Materials - Pan Stanford (2013).
On page 204.
“Energy efficiency calculations were also carried out for thermochromic windows based on vanadium dioxide [11]. … … The investigated vanadium dioxide based coated thermochromic films possesses switching temperatures of 38.5°C (VO2 + TOAB), 43°C (VO2 + gold), 45.5 (VO2 + gold + TOAB) and 59°C (VO2). As an outcome of the calculations, the energy-saving performance of the vanadium dioxide based thermochromic films mainly depends on the switching temperature”.
[ TOAB = surfactant, tetraoctylammonium bromide ]
Zinc Oxide: New Insights into a Material for All Ages - By Amir Moezzi.
PhD Dissertation. University of Technology. Sydney. 2012
https://opus.lib.uts.edu.au/bitstream/10453/20439/2/02Whole.pdf
“Crystalline ZnO is thermochromic, changing from white to yellow when the temperature is increased to >300°C [24] and then from yellow to white upon cooling. This is probably because of the formation of crystal lattice defects due to a loss of oxygen and the formation of the non-stoichiometric Zn₁+xO, with x increasing with temperature”.
