Why does a Wormhole not look like an hourglass?
The discussion revolves around the visual representation of wormholes, specifically questioning why they do not appear as hourglass shapes. Participants explore the geometry of wormholes, the implications of general relativity, and the nature of the wormhole throat in relation to spacetime. The conversation includes theoretical considerations and visual intuitions about wormhole structures.
  • Exploratory, Technical explanation, Conceptual clarification, Debate/contested
  • Some participants propose that the throat of a wormhole, influenced by negative energy density, would appear as a "fat or bloated cylinder" rather than an hourglass shape due to repulsive forces counteracting gravitational attraction.
  • Others argue that in general relativity, gravity is not a force, and thus thinking in terms of balancing forces is misleading. They reference the Ellis wormhole as an example of a wormhole solution to Einstein's equations.
  • A later reply clarifies that the throat of a wormhole is a minimal spherical surface in a spatial slice, and any hourglass depiction is a coordinate-dependent embedding rather than a physical observation.
  • Participants discuss the nature of spacelike slices of wormholes, noting that they consist of a series of 2-spheres with areas transitioning from infinity to a finite value and back, which could be visualized as an hourglass shape.
  • Some participants express confusion about the visualization of wormholes and the implications of spatial dimensions, with one participant seeking clarification on the terminology used in the discussion.
Participants express multiple competing views regarding the visualization of wormholes and the interpretation of their geometry. There is no consensus on a singular representation, and the discussion remains unresolved regarding the best way to conceptualize wormhole shapes.
Limitations include the dependence on visual intuition and the challenges of accurately representing complex geometrical concepts in general relativity. The discussion also highlights the potential for misunderstandings due to informal language and varying levels of familiarity with the subject matter.
This discussion may be useful for individuals interested in theoretical physics, particularly those exploring concepts in general relativity and the geometry of spacetime. It may also benefit learners seeking to understand the complexities of visualizing higher-dimensional spaces.
Aayush Thakur
TL;DR
In science fiction, we often see wormholes shaped like an hourglass. But what I have learned so far about exotic matter, negative mass density, wormholes and their stability conditions. I came to a conclusion that a wormhole should not look like an hourglass.
A region of negative energy density hints a little towards negative mass. So the throat of wormholes have very powerful attractive gravitational forces. So in order to stabilize a wormhole we think of using a region of negative energy to create a strong repulsive force that can keep the throat open. If we look at a wormhole from outside then it should look like a giant sphere, no hourglass shape. But if we visualise its geometry, like how it would curve the fabric and connect to different points, then its look something like a "fat or bloated cylinder". Something like ( ) not ) ( .
The hourglass shape leans more towards the throat being pinched due to attractive forces but since we have used negative energy region, there are repulsive forces that cause the throat to widen. This is just what I thought of.
Please correct me wherever I am wrong.
Gravity isn't a force in general relativity, so it's a mistake to try to think in terms of balancing forces.
There are wormhole solutions to Einstein's equations. A simple eternal wormhole is the Ellis wormhole, which connects two more or less flat regions of spacetime. Note that they aren't exactly flat, that the spacetime is everywhere filled by exotic matter, and (IIRC) there is no gravitational effect from the wormhole - you can float near it without needing to orbit.
The picture on the wiki page is an equatorial cross-section. The wormhole throat is a circle here (and would be spherical in 3d). I'm not sure what you are attempting to describe - what you would see directly if you were looking would be a spherically symmetric shape, but the equatorial cross section might be described as a (funny shaped) hourglass and this is a reasonable embedding of it.
Thank you, Ibix. I think this was mainly a misunderstanding on my part due to informal language and visual intuition. I now see that thinking in terms of balancing forces isn’t appropriate in GR, and that the correct description involves geodesic focusing and defocusing.
My confusion was really about the visualization rather than the physics. I understand now that the throat is a minimal spherical surface in a spatial slice, and that any “hourglass” picture is just a coordinate-dependent embedding, not something one would physically observe.
So, do you mean that the whormhole throat would be visibile/look as a 2D spherical surface in a spacelike slice of the underlying spacetime solution of EFE ?
Sort of. A spacelike slice of a wormhole is a very strange thing; it is not like the normal space you're used to.
In the normal space you're used to, you can take 3-dimensional space and consider it as a nested series of 2-spheres, with areas going from infinity down to zero.
But the wormhole space is a series of 2-spheres, where the areas go from infinity down to some finite positive value (the area of the throat 2-sphere), and then go back up to infinity on the other side.
The "hourglass" shape is simply what I just described in the previous sentence, with one spatial dimension taken out, so that the series of 2-spheres becomes a series of circles. Note that this means that the surface of the hourglass is the only part that is actually in the model--the interior of the hourglass is not part of the model and is not something you would experience. It's just an artifact of trying to visualize the space as embedded in ordinary 3-dimensional Euclidean space.
There is no easily intuitive way of visualizing what it would be like to be embedded in such a space.
Yes. So if you looked at it (literally) from inside the spacetime, some null curves from/to your eye would cross the minimum radius surface and some wouldn't. Those that do cross reach infinity on the other side of the throat and the rest will reach it on this side. The bundle of rays that do cross the throat will be axially symmetric, and you will see a circular patch on the sky (probably surrounded by some gravitational lensing-type effects) that obscures your side's infinity with a view of the other infinity.
That's distinct from what the spacetime "looks like". I agree an hourglass isn't a daft description of the spatial slices.
Hey cianfa72, appreciate your question. Thank you PeterDonis for such a great explanation. Hope you got your answer with that cianfa72.
BTW, i am just a high school sophomore trying to learn about wormholes (theoretically only), i don't think i would have been able to give a detailed explanation like Peter's.
Thank you PeterDonis. Just one tiny clarification i would like to confirm with you is when you said "one spatial dimension taken out", i think it could've been more precise by saying "spatial (angular) dimension". Though, the meaning is beautifully conveyed. But someone new to GR (like me), "spatial" alone could be misread as radial dimension.
Yes, that's correct; the hourglass visualization represents 2-spheres by circles, so it's taking out one angular (or rotational) dimension.
In more technical language, the topology of a spacelike slice of the wormhole spacetime is ##S^2 \times R## (whereas the topology of ordinary Euclidean 3-space is ##R^3##). The "hourglass" is a representation of the topological space ##S^1 \times R##.
I think you're actually assuming a stationary spacetime where the spacelike slices adapted to the time symmetry are the same (whormholes with the same geometry/topology) and you're literally looking at it "from the within" of the spacetime.
Yes you're right cianfa72. Spacelike slice taken here for the wormhole is symmetrical throughout its asymptotic geometry. They are assuming a stationary spacelike slice (like a screenshot in 3D world).
By Whitney embedding theorem, n=6 as Euclidean space is enough to embed ##S^2 \times R## in. I'm not sure whether there is an embedding of it into ##\mathbb E^4## (note that such embedding is only a matter of topological/differential structures and in general it is not about the metric).
I was trying to visualize ##\mathbb S^2 \times R## as a "block" extending across all 3D euclidean space with a spherical hole inside it. You can take a series of nested spherical shells up to the boundary established by the "spherical hole" within it. Unfortunately, this model fails, since once you reach the smallest sphere, you can't go back to infinity on the other side (you're forced to retrace the sequence of nested spheres you have already encountered/passed through).
  • · Replies 27 ·
  • · Replies 26 ·
