Why does gravitational Laplace's equation equal zero?
The discussion centers on the application of Laplace's equation in gravitational fields, specifically how it equals zero in empty space. The gravitational potential field is defined as φ = -Gm/r, where φ represents the gravitational potential energy of a unit mass. The divergence of the gravitational field, expressed as ∇·∇φ, leads to Poisson's equation, which simplifies to Laplace's equation (∇²φ = 0) when the density ρ is zero outside a mass. The participant seeks clarification on expressing φ in Cartesian coordinates and calculating the Laplacian correctly, ultimately finding that using spherical coordinates simplifies the process.
  • Understanding of gravitational potential fields and scalar fields
  • Familiarity with vector calculus, specifically divergence and gradient operations
  • Knowledge of Laplace's equation and Poisson's equation
  • Basic proficiency in spherical coordinates and their applications in physics
  • Study the derivation and applications of Laplace's equation in gravitational fields
  • Learn how to convert between Cartesian and spherical coordinates in mathematical expressions
  • Explore the use of computational tools like WolframAlpha for solving differential equations
  • Investigate the physical implications of Poisson's equation in various contexts
Students of physics, mathematicians, and anyone interested in gravitational fields and the mathematical principles governing them.
peter46464
I'm struggling here so please excuse if I'm writing nonsense. I'm trying to understand how, for a gravitational field, Laplace's equation (I think that's the right name) equals zero in empty space.
I understand that the gravitational potential field, a scalar field, is given by \phi=\frac{-Gm}{r} where \phi is the gravitational potential energy of a unit mass in a gravitational field g. The gradient of this is (a vector field) g=-\nabla\phi=-\left(\frac{\partial\phi}{\partial x},\frac{\partial\phi}{\partial y},\frac{\partial\phi}{\partial z}\right) And the divergence of this vector field is \nabla\cdot\nabla\phi=\nabla^{2}\phi=4\pi G\rho and is called Poisson's equation. If the point is outside of the mass, then \rho=0 and Poisson's equation becomes\nabla\cdot\nabla\phi=0 (Laplace's equation). My question is, how do I express \phi=\frac{-Gm}{r} as a function of x,y,z so I can then end up with \nabla\cdot\nabla\phi=0 in empty space? I would have thought that I could write \phi=\frac{-Gm}{r}=\frac{-Gm}{\sqrt{x^{2}+y^{2}+z^{2}}} but when I try to calculate \nabla\cdot\nabla\phi from this, I don't get zero. I do this by assuming (in the simplest case) that both y and z are zero and then taking second derivative of \phi=\frac{-Gm}{r}which should be zero (shouldn't it?) but isn't zero. What am I doing wrong? As simple as possible please.
Thank you
My mistake. Not sure why but I can't simplify like that. The Laplacian of \phi=\frac{-Gm}{r}=\frac{-Gm}{\sqrt{x^{2}+y^{2}+z^{2}}}is (I used the WolframAlpha calculator, which I've only recently discovered - it's very good!)\nabla\cdot\nabla\phi=Gm\left(\frac{2x^{2}-y^{2}-z^{2}+2y^{2}-x^{2}-z^{2}+2z^{2}-x^{2}-y^{2}}{\left(x^{2}+y^{2}+z^{2}\right)^{5/2}}\right)=0
It is much easier to demonstrate this using the representation of the Laplace operator in spherical polar coordinate:
\Delta = \frac{1}{r^2} \frac{\partial}{\partial r} r^2 \frac{\partial}{\partial r}
How does that work?
  • · Replies 19 ·
