Why does gravitational potential decrease when distance increases if it's negative?
7 replies · 3K views · last reply
Knightycloud
Gravitational potential is always a negative value according to the theory.
As per to the equation V = - [itex]\frac{GM}{r}[/itex]; when the r (distance) increases the potential decreases. But considering the potential at infinity as zero and since this a negative value, on what basis do we consider the potential is decreasing, not increasing (When the distance is increasing)?
No. As r increases, 1/r decreases, but -1/r increases.
i.e. it's less negative.
...or slopes upward (has a positive slope) on a graph of V versus r.
'Everywhere' is the equivalent of 'underground', effectively and up is up, however deep or high you are.
So as the negative value decreases, potential is increasing accordingly?
Let's say that the potential on Earth surface is Va = -[itex]\frac{GM}{R}[/itex] and if we move to a higher place where the distance is twice, the potential is Vb = -[itex]\frac{GM}{2R}[/itex]. But at Vb, the negative value is smaller than Va, Vb has a higher potential. Right? :smile:
It's exactly the same as when you deal with xy co ordinates. Moving tp the right is increasing the x co ordinate, whether you start on the right or to the left of the origin. Just let the Maths work for you.
And you really mean 'magnitude'.
