iamconfused
- Messages
- 9
- Reaction score
- 1
Hi all, I am hoping someone could clear up a concept that doesn't make sense to me. I am thinking in terms of a blackbody diagram, which is "Intensity" on the y-axis and wavelength on the x axis. I understand that when you heat something to a higher temperature, the curves shift to shorter wavelengths and the curves are narrower and also taller (more intense). I know wavelength is inversely proportional to the energy. So the energy of a particular color of light will always be the same for that particular color. And intensity seems to be energy per unit area and time. So just thinking about one particular frequency of light, let's say 500 nm as an example, the energy of 500 nm light should be the same no matter the temperature it's at. So what makes it more intense at a higher temperature? Is it, more photons being released? And if it's more photons per unit area and time, what exactly is making that happen? If you have a higher temperature object emitting light, what about higher temperature makes it release more photons?
To give some context, I'm learning about global warming, and how the atmosphere absorbs IR light. And apparently the blackbody spectrum of the Earth will show colder curves because the atmosphere absorbs IR and reradiates it into space higher in the atmosphere, where it's colder. I'm wondering why, for a particular frequency of light, it being colder will make it's intensity go down. What does the molecule do to it?
