Why Does Inlet Pressure Decrease in a Constant RPM Gas Compressor?
peter9321
I would like to clear out my understanding of gas compressor. If it is moving at constant RPM, is it mean that it can only allow same volumetric flow rate all the time? So the power will remain constant too, (P=VI) then voltage and current will varies. My investigation is to find why there is changes of pressure and flow rate entering the compressor. Could anyone provide me some good explanation please. Thanks. I would like to know why the pressure inlet for gas compressor is decrease and I am wondering is it related to flowrate (in MMSCFD) as the flowrate is increase?
Table of daily process readings for June 13, 14 and 15: V1030 outlet pressure, outlet flowrate, K2430 inlet flowrate, inlet pressure, inlet temperature, outlet pressure, and current to operate the motor, with values in each column.
Process flow diagram of a suction scrubber feeding a first-stage LP compressor K-2430, with a signal selector, control valves, flow and pressure controllers, and an LP separator V-1030 with a flare header line.
I would like to hear a little more about your process and flow monitoring. A quick glance at the data your provided shows a noticeable drop in inlet pressure. A drop in excess of 1 bar would mean a statistically significant reduction in gas flow. You are essentially correct in that the compressor is (or should be) relatively static. This drop in incoming gas would reflect in the outlet.
