Why Does \(\ln \frac{(x+1)}{(x-1)} \geq 0\) Imply \(x > 1\)?
The discussion revolves around the inequality \(\ln \frac{(x+1)}{(x-1)} \geq 0\) and its implications for the variable \(x\). Participants explore the conditions under which this logarithmic inequality holds true, particularly focusing on the relationship between the expressions involved.
  • Participants discuss the transformation of the logarithmic inequality into a fraction and the implications of multiplying by expressions that may change the direction of the inequality. Questions arise regarding the validity of these transformations and the conditions under which they hold.
There is an active exploration of the properties of logarithms and inequalities, with some participants suggesting alternative methods to approach the problem. The discussion includes considerations of the domain of the logarithmic function and the conditions necessary for the inequality to be valid.
Participants note the importance of specifying restrictions on \(x\) due to the domain of the logarithmic function, particularly that \(x\) must be greater than 1 for the original inequality to be defined. There is also mention of the need to consider cases where the numerator and denominator of the fraction have the same sign.
Cosmophile
[tex]\ln \frac{(x+1)}{(x-1)} \geq 0[/tex]
[tex]\ln \frac {a}{b} = \ln a - \ln b[/tex]
[tex]\ln \frac {(x+1)}{(x-1)} = \ln (x+1) - \ln (x-1)[/tex]
[tex]\ln (x+1) \geq \ln (x-1)[/tex]
[tex]e^{\ln (x+1)} \geq e^{\ln (x-1)}[/tex]
[tex](x+1) \geq (x-1)[/tex]
According to Wolfram, the solution is ##x > 1##, but my skills with logs and exponentials are clearly very rusty.
This seems reasonable, but unfortunately, isn't valid.
Your original inequality is equivalent to ##\frac{x + 1}{x - 1} \ge 1##, which you can get in one step. If the log of something is >= 0, then the something has to be >= 1.
If you multiply both sides by x - 1, you get what you show in the last line, above. The problem is that you don't know whether x - 1 is positive or negative (or zero), so it's impossible to say whether the direction of the inequality stays the same or is reversed.
To get around this problem, multiply instead by ##(x - 1)^2##. You should also explicitly note what values of x are allowed.
I see how you got ##\frac {x+1}{x-1} \geq 1##. Why am I okay to multiply by ##(x-1)^2##, and why is this necessary? Thank you for the help as always!
Also, "if the log of something is > 0, then the something has to be >1" Why? This is where my understanding of logarithms (or lack thereof) is on full display.
You can multiply both sides of an inequality by any positive number, without changing the direction of the inequality. ##(x - 1)^2## is positive, provided that ##x \neq 1##.
##\ln a \ge 0##
##\Leftrightarrow e^{\ln a} \ge e^0 = 1##
##\Leftrightarrow a \ge 1##
Of course, in the above, a must be positive.
So, are you multiplying both sides of the inequality by ##(x-1)^2## then?
Yes. Multiply both sides of ##\frac{x + 1}{x - 1} \ge 1## by ##(x - 1)^2##. Be sure to specify any restrictions on possible values of x, keeping in mind what the domain of the ln() function is (which the original inequality involves).
In your attempt at a solution, you get ln (x + 1) >= ln (x - 1). From here you need to think about two things: (1) When is the ln function defined? (2) When is ln (a bigger number) >= ln (a smaller number)? Thinking about these should get you the solution.
Look at the plot of the log function y = ln (z) for z > 0. You will see that for 0 < z < 1 we have ln z < 0, but for z > 1 we have ln z > 0.Anyway, you want ##(x+1)/(x-1) \geq 1##. You do not need to multiply by ##(x-1)^2##; that is not the only way to do it. An alternative is to recognize that we need the numerator and denominator to have the same sign, so there are two cases.
(1) If the numerator and denominator are both > 0 the inequality equivalent to ##x+1 > x-1##; but we also have ##x-1 > 0##. Altogether, this just says that ##x > 1##.
(2) If the numerator and denominator are both < 0 the inequality is equivalent to ##x+1 \leq x-1##, with ##x < -1## (note the reversal from '>' to '<'). However, this is clearly impossible., so we cannot obey the desired inequality when ##x < -1##.
This is not so much a problem in logarithm manipulation as it is a problem in inequality manipulation.
Alternatively, [tex]\frac{x+1}{x-1} = \frac{(x - 1) + 2}{x-1} = 1 + \frac{2}{x-1}.[/tex] Thus, since [itex]2 > 0[/itex], we have [itex]\frac{x+1}{x-1} \geq 1[/itex] when [itex]x - 1 > 0[/itex].
It's obvious at this point that I desperately need to work on my conceptual understanding of logs, exponentials, and inequalities. Do any of you have recommendations on places to start? I'm reading through Lang's calculus text, and I know he has a section on logs and exponentials. He starts the book with inequalities, but it apparently doesn't cover all that I need to know on the topic.
Should I be concerned that a multiplication by the square of the denominator was not obvious, or is that simply a trick you learned along the way? Also, the only restriction I see is that ##x > 1##, as ## \ln x## is defined ##\forall x \in \mathbb{R} | x >0##. Is this all I needed to observe from the beginning? Thanks for the assistance so far!
(1) ##\ln(x)## is defined ##\forall x \in \mathbb{R} | x>0##.
(2) ##\ln(n) > \ln(m)## is always true for ##n > m##, is it not? ##\ln(x)## is always increasing.
Right, I see now why the thing I'm taking the log of must be >= 1 if the log is > 0. Now, for your first case, you say:
"(1) If the numerator and denominator are both > 0 the inequality equivalent to ##x+1 > x-1##; but we also have ##x-1 > 0##. Altogether, this just says that ##x > 1##."
How did you gather that ##x+1 > x-1## and ##x-1 > 0## together say ##x > 1##? This is another great example of my blatant ignorance and inexperience with inequalities, so I appreciate the assistance. Of course, I can see immediately from ##x -1 > 0## that ##x>1##; I'm simply confused as to how you get the same result from ##x + 1> x-1##. This inequality holds true for all x (which is why the second case is clearly impossible if I'm not mistaken).
Oh, this is a pretty neat way to approach it. This works because ##1 + \frac {2}{x-1} > 0 \quad \forall x > 1##, correct?
What you need to remember while solving inequalities is, simply this - unless you are sure that a particular function is always positive, or negative, for that matter, you can not just simply cross multiply across an inequality.
For example, if you had ( x+1 )/( x2+1 ) <= 1, you could cross multiply ( Why ? ).
An alternative solution would be to simply bring all quantities to one side of the inequality, and taking LCM, form the intervals for which that inequality is positive and negative.
Hope this helps.
I don't think you have taken my meaning, but maybe I worded it badly. I am looking at the case where both the numerator and denominator are > 0, so that says ##x-1 > 0## and ##x+1 > 0##. The second of these adds nothing new, so we just have ##x > 1##. The ratio constraint implies that the numerator is > the denominator. This is true automatically in this case, so adds no new restrictions to the simple one ##x > 1## that we have already.
The case where both numerator and denominator are < 0 is similar, but now the numerator must be < the denominator; for example, (-5)/(-4) = 5/4 > 1, but (-5) < (-4).
(Why don't I get a normal font in this reply?)
Ray Vickson said:
Cosmophile said:
It's obvious at this point that I desperately need to work on my conceptual understanding of logs, exponentials, and inequalities. ...
... This inequality holds true for all x (which is why the second case is clearly impossible if I'm not mistaken).*****************************************
I don't think you have taken my meaning, but maybe I worded it badly. ...
Ray,
You didn't get a "normal" font, because you replied inside of the quote of Cosmophile .
SammyS said:
Ray,
AFAIK, I always do that and have never before had the problem!
  • · Replies 21 ·
  • · Replies 19 ·
  • · Replies 23 ·
