Why does metal feel colder than wood when both are the same temperature?
  • Level: High School
  • Thread starter bygonedaily
7 replies · 620 views · last reply
bygonedaily
Here's one I worked through properly recently, because the everyday version of it is wrong in an interesting way: a metal spoon and a wooden table sitting in the same room are at exactly the same temperature — yet the metal feels colder. The metal isn't colder. It's faster.
The mechanism, in three steps:
1. The touch. Your hand is warmer than both objects (around 37 °C against a room-temperature ~20 °C), so the moment you touch either one, heat starts flowing out of your skin into the object.
2. The race. Metal conducts that heat away fast, spreading it deep inside itself — copper conducts at about 397 W/m·K. Wood barely conducts at all (pine is about 0.12 W/m·K, roughly three thousand times less), so the warmth stays right where it landed. The free electrons in the metal do the carrying.
3. The signal. Your skin can't actually sense an object's temperature — it senses how fast its own heat is leaving. Fast escape feels freezing; slow escape feels mild. Same temperature, different speed. That's the whole illusion.
The twist that confirms it: leave both in a hot car and the trick flips — now the metal feels hotter than the wood, because it shoves heat into your skin just as fast as it pulled it out. Conduction works in both directions (P = kA(Th − Tc)/L).
Sources:
- Michigan State University, An Introduction to Physics for Curious Minds, "Misconception Alert: 'Colder' Materials" (openbooks.lib.msu.edu)
- Encyclopaedia Britannica, "Thermal conductivity"
- Physics LibreTexts, "Heat Transfer Mechanisms", Table 37.4
[Moderator's note: Invalid reference deleted.]
I'm no expert, but I think I would disagree with this.
Human sensory nerves sense temperature through specialized free nerve endings called thermoreceptors that convert thermal energy into electrical signals.
https://en.wikipedia.org/wiki/Thermoreceptor
TRP Ion Channels: Different channels open at distinct temperature thresholds. For example, TRPM8 responds to cooling and menthol, while TRPV1 responds to higher heat and capsaicin (the compound in chili peppers). Other TRP channels (such as TRPV3, TRPV4, TRPV2, and TRPA1) and additional ion channels help cover wider warm, hot, and cold ranges.
https://pmc.ncbi.nlm.nih.gov/articles/PMC4594430/
Nerve Fiber Types: Warmth signals generally travel along slow, unmyelinated C-fibers, whereas cold signals travel along both C-fibers and faster, thin myelinated A-delta fibers. Cell bodies for peripheral temperature nerves sit in the dorsal root and trigeminal ganglia.
https://www.sciencedirect.com/topics/immunology-and-microbiology/thermoreceptor
I've always noticed this in my own kitchen in winter — the metal tap and the worktop feel icy, while the wooden chopping board sitting next to them feels almost normal, even though they've all been in the same room overnight. I think the difference is how quickly each one pulls heat out of your hand, rather than the temperature itself. Metal passes that heat away fast, so your skin cools down quickly and reads it as cold. Wood is a poor conductor, so it barely draws any heat away and your hand stays near its own temperature. It's a good reminder that what we feel is really the rate of heat flow, not a thermometer reading.
Yes, one is an excellent conductor the other isn't.
Thanks for the catch on the link — noted, I won't re-add it; the post stands on its own text and sources. Fair point on the wording, Williamson — you're right that thermoreceptors measure the skin's own temperature, not the object's directly. That's actually the mechanism here: on metal the skin itself cools much faster, so those receptors report 'cold' even though the spoon and table started at the same temperature. The textbook line I was leaning on puts it as 'your skin senses the rate of heat loss, not the floor's temperature' — shorthand for that same drop in skin temperature. On heat capacity: it matters to how much heat an object can take up, but the rate here is set by conductivity — copper ~397 vs pine ~0.12 W/m·K — and the precise quantity behind the touch is thermal effusivity, which tracks conductivity closely for these two. Thanks both — pinball1970's tap-and-worktop example is exactly the everyday version.
Too many em dashes.
