Why does multiplying current by cos equal sin in circuit analysis?
39 replies · 6K views · last reply
jaydnul
In circuit analysis, everything seems to work out when you set i*cos = sin. But thats not a legitimate equation, so why does that work? Is there a proof that this is a real equation?
jaydnul said:
why does that work?
First, where does it work? I don’t remember ever seeing that work in circuits
sin(wt) across a cap gives I = c*w*cos(wt). So V/I becomes 1/jwc. It works everywhere else too
So where is ##i \cos = \sin ## in that?
should be i*sin = cos, sorry. V/I = sin/(cwcos). replace cos with jsin and it simplifies to 1/jwc
another example:
i have a transfer function given by the complex number (A+jB). I multiply my input sin(wt) and i get Asin(wt)+jBsin(wt). Using the equality above, it becomes Asin(wt) + Bcos(wt), which is just standard form of any sinusoid with a magnitude of sqrt(A^2 + B^2). No need to convert into an exponential with eulers formula, then take the "real" part of that exponential.
I think you are misinterpreting the fact that $$\frac d {dt}~e^{i\omega t}=i\omega e^{i\omega t}$$ as a new "magic rule" for circuit analysis. This is just a property of a circular function.
Does that complex exponential equation show that i*sin = cos
I am just wondering why it seems to always work, i cant find an example where it doesnt. But then also, i cant prove i*sin = cos.
Without every invoking complex exponentials, eulers formula, etc. Why can i simply replace all cos terms with isin, do the algebra, then replace all the isin terms back with cos and somehow magically always get the correct answer.
because the problem is linear and all the i does is identify the imaginary part. So switching and then switching back works OK. If your problem scrambled them (by squaring for instance) the result would not work out. Try it
Ahh maybe thats it. But in circuits all the of the components are linearized. Whats an example of what you are talking about, maybe im confused?
Ok, so you seem to be mixing phasor concepts with time domain notation. So in phasor notation ##A \cos(\omega t+\phi)## is written as ##A\angle \phi## which is further interpreted as the complex number ##A e^{j\phi}##. So the phasor of ##\cos(\omega t)## would be ##1 e^{j0}=1## and the phasor of ##\sin (\omega t)=\cos (\omega t - \pi/2)## would be ##1 e^{-j\pi/2}=-j##. So ##phasor(\cos)=j \ phasor(\sin)## which does not mean ##\cos = j \ \sin##
Handwritten notes deriving component impedances for a sinusoidal source: resistor current I = sin(wt)/R giving V/I = R, capacitor V/I = 1/(jwc), and an RC circuit Vout = sin(wt)(1/(jwc) divided by R + 1/(jwc)) simplified to real and imaginary parts, ending with Vout = A sin(wt) + B cos(wt) and magnitude and argument expressions.
jaydnul said:
another example:
If you are using complex numbers in circuit analysis (like a complex impedance, or your transfer function), then you are using Euler's formula* to express quantities that have both an amplitude and phase. It won't do you much good in the long run to pretend that you aren't. It's not any easier your way, assuming correct answers are your goal.
Because that's just not true. EEs use math the way it's taught in math classes. Inventing something new without any rigorous basis will not work for you. The mathematical approaches to circuit analysis are not tricks that someone stumbled across or found through trial and error. There is a firm logically consistent reason for the analytical tools used.
I think it's time to take a big step back and look not just at how these problems are solved, but also why those tools are used; why they work.
* Alternately you can think of everything as a 2-D vector instead of complex numbers, it's really the same thing.
I get it, I understand phasors, i am an MSEE working in industry as an analog designer. Just asking for an example where that substitution doesnt work thats it. Phasors are already abstract, and its mysterious to me as to why that substitution seems to always work.
jaydnul said:
Of course this example works, the way you did it anyway. All you did was change the symbols while still treating it as a 2-d vector (the original complex number). A & B terms didn't change and those were all you used to find the magnitude and phase. You could have substituted apples and monkeys in place of sin and cos, as long as apples and monkeys make an orthogonal basis. I don't really follow how this improves anything.
That substitution doesn't work in the example that you gave in post 5.
If the voltage across a capacitor is ##v= \sin(\omega t)## then the current through it is ##i = C \dot v = C \omega \cos(\omega t)## so $$\frac{v}{i} = \frac{\sin(\omega t)}{C \omega \cos(\omega t)} \ne \frac{1}{j\omega C}$$ What does work, as I said, is to use phasor notation.
Since you claim to understand phasors, why don’t you use them the same way as all other EEs I have ever worked with and gone to school with? Were you taught this method?
Of course, if ##\omega t## is real then ##\cos(\omega t)## is real and ##i \, \sin(\omega t)## is imaginary, so they are never equal. Writing ##i \, \sin(\omega t)=\cos(\omega t)## makes as much sense as writing ##1=2##. They are both false.
But you need the derivative of apples to be monkeys, as well as orthogonal. So i dont see the point you are making.
Dale said:
That substitution doesn't work in the example that you gave in post 5. If the voltage across a capacitor is ##v= \sin(\omega t)## then the current through it is ##i = C \dot v = C \omega \cos(\omega t)## so $$\frac{v}{i} = \frac{\sin(\omega t)}{C \omega \cos(\omega t)} \ne \frac{1}{j\omega C}$$ What does work, as I said, is to use phasor notation.
Yes it does? Substitute cos(wt) with j*sin(wt) and thats exactly what you get, and kinda my entire point here.
If you make the substitution then you do get the right hand side of the inequality, but it doesn’t equal the left hand side of the inequality. In other words, once you make the substitution, the remaining quantity is no longer equal to ##v/i## where ##v## and ##i## are functions of time, not phasors.
I really appreciate all the posts but this is the only one that is attempting to answer my question. Is this expandable?
It is interesting to think about and i enjoy it. Why do people post things like this lol. The only reasonable responses should be:
i dont know
it is unknowable
this is why that happens to work but here is the context where it doesn't work/falls apart
the units for 1/jwc is the same as V/I. I mean it is a function of t, the two sin(wt) just cancel eachothers impacts…
jaydnul said:
Im wondering why IT WORKS when you substitute jsin. Thats it
And I am telling you that the substitution doesn’t work.
What does work is to transform to phasors.
Using phasors to derive the magnitude of the transfer function of a circuit gives THE EXACT SAME results as substituting jsin=cos. Thats what i mean by work. Input output. If you want to argue what word to use for that instead of WORKS thats fine
Hutchphd had what seemed to be the only helpful post so far. Can anyone expand on that
It might be easier if you give an explicit (excruciatingly detailed) example of what you mean. I think you will see it is not very interestng when looked at in detail. Phasors and complex notation give the same results when applied appropriately. So please give one concrete example of your substition (in gory detail)
Because of the trig identity ##A sin(\omega t) + B cos(\omega t) = \sqrt{A^2+B^2}~ sin(\omega t + atan(\frac{B}{A}))##
And
##|(A+jB) sin(\omega t)| = |(A+jB)| ⋅ |sin(\omega t)| = \sqrt{A^2+B^2} ~|sin(\omega t)|##
##arg((A+jB) sin(\omega t)) = arg(A+jB) + arg(sin(\omega t)) = atan(\frac{B}{A}) + arg(sin(\omega t))##
Then when you jump to phasor notation and drop the ##sin(\omega t)## terms they are the same. It's the same solution algorithm, that is all. Nothing Euler didn't know 300 years ago. If you aren't working with phasors, it's just wrong.
Maybe I missed it (sorry if I did), but why don't you write sin(x) and cos(x) in terms of complex exponentials and check it explicitly?
So the analytic representation of ##A \cos(\omega t+\phi)## is ##A e^{j\phi}e^{j\omega t}## and the phasor representation is the non-time-dependent part ##A e^{j\phi}##. So the phasor representation of ##\cos(\omega t)## is ##e^{j0}=1##.
Since ##\sin(\theta)=\cos(\theta-\pi/2)## the phasor representation of ##\sin(\omega t)## is ##e^{-j\pi/2}=-j##.
So $$phasor(\cos(\omega t))=j \ phasor(\sin(\omega t))$$ This is where the relationship you are seeing comes in. But this in no way implies that $$\cos(\omega t)=j \ \sin(\omega t)$$ That substitution does not work for the reasons I showed above.
You are just being sloppy. You need to clearly identify when you are working with functions of time and when you are working with their phasor representations. A function is not the same as the representation of that function in another domain.
Similarly, when you are working with Fourier transforms you need to be clear about when a function is in the time domain and when it is in the frequency domain. If ##X(\omega)=\mathcal F [x(t)]## then $$\mathcal F[ \dot x]=j\omega X$$ is correct whereas $$\dot x=j\omega x$$ is simply wrong. This is what you are doing and claiming that it works. Sloppy mixing of domains doesn't work.
