Why does my code produce incorrect output?
  • Context: Python
  • Thread starter Thread starter doktorwho
    Code Output Python
5 replies · 2K views
doktorwho
Python:
# Use Dave's suggestions to finish your daysBetweenDates
# procedure. It will need to take into account leap years
# in addition to the correct number of days in each month.
def nextDay(year, month, day):
    n=month
    if (n==1 or n==3 or n==5 or n==7 or n==8 or n==10 or n==12) and day < 31:
        return year, month, day + 1
    if (n==4 or n==6 or n==9 or n==11) and day <30 :
    if month==2 and day < 29 and (year%4)==0:
    if month==2 and day < 28 and (year%4)!=0:
    else:
        if month == 12:
            return year + 1, 1, 1
        else:
            return year, month + 1, 1
def dateIsBefore(year1, month1, day1, year2, month2, day2):
    """Returns True if year1-month1-day1 is before year2-month2-day2. Otherwise, returns False."""
    if year1 < year2:
        return True
    if year1 == year2:
        if month1 < month2:
            return True
        if month1 == month2:
            return day1 < day2
    return False
def daysBetweenDates(year1, month1, day1, year2, month2, day2):
    """Returns the number of days between year1/month1/day1
       and year2/month2/day2. Assumes inputs are valid dates
       in Gregorian calendar."""
    # program defensively! Add an assertion if the input is not valid!
    assert not dateIsBefore(year2, month2, day2, year1, month1, day1)
    days = 0
    while dateIsBefore(year1, month1, day1, year2, month2, day2):
        year1, month1, day1 = nextDay(year1, month1, day1)
        days += 1
    return days
def test():
    test_cases = [((2012,1,1,2012,2,28), 58),
                  ((2012,1,1,2012,3,1), 60),
                  ((2011,6,30,2012,6,30), 366),
                  ((2011,1,1,2012,8,8), 585 ),
                  ((1900,1,1,1999,12,31), 36523)]
    for (args, answer) in test_cases:
        result = daysBetweenDates(*args)
        if result != answer:
            print ("Test with data:"), args, "failed"
        else:
            print ("Test case passed!")
test()
I am suppose to write a code that calculates the number of days between two dates and i get everything from the test correctly except the last one, 1900,1,1,199,12,31. I get +1 day, why is that?
Do you know that there are no leap years on the 100's that are not divisible by 400?
I did not know that, thanks :-)
jedishrfu said:
Also historically there was a calendar change in 1582 by Pope Gregory to fix the time of the vernal equinox which was 10 days too late:
http://www.findingdulcinea.com/news...this-Day--In-1582--Oct--5-Did-Not-Exist-.html
The change from the Julian calendar to the Gregorian calendar didn't happen uniformly in all countries. In Great Britain and the colonies (including what is now the U.S.), this change didn't occur until almost two centuries later, in September of 1752. Here's an image of a calendar from that year. Notice the jump from Sep 2 to Sep 14, with no dates shown for the intervening 11 days.
