Why does Pr(t<X<t+dt)=f(t)dt for a probability density function?
  • Context: Graduate
  • Thread starter Thread starter rukawakaede
6 replies · 4K views
rukawakaede
Hi
Could anyone show to me that:
If dt is an infinitely small number, the probability that X is included within the interval (t, t + dt) is equal to f(t) dt ,i.e.
[itex]Pr(t<X<t+dt) = f(t)dt[/itex]
where f is the probability density function.
this sentence is from wikipedia but I could not prove this to myself.
Thanks if anyone can help.
What are the limits of your integral? You can't really make sense of f(t)dt without some kind of constraint on the upper and lower limits.
The probability density function, f, is defined by the fact that
[tex]P(a< x< b)= \int_a^b f(x)dx[/tex]
or, equivalently,
[tex]P(a< x< a+h)= \int_a^{a+h} f(x)dx[/tex]
What Wikipedia gives is a "differential" form of that.
or, equivalently,
Thanks HallsofIvy for your reply.
I was trying to work out why
[tex]\int_a^{a+h} f(x)dx= f(a)h[/tex]
when h infinitely small.
Could you tell me more about why this is true? or could you explain the differential form? I am still not fully understand yet.
First off, you almost surely do not mean much of what you said literally. You should spend some time thinking about what you actually meant
Anyways, if by "=" you meant "is approximately" and by "infinitely small" you meant "sufficiently small", it's true because of the mean value theorem and the definition of continuous function.
(P.S. if f is not assumed to be continuous, then the equation above is very false)
rukawakaede said:
Hi
It's just a (dodgy) method for turning sums into integrals. In the long run it's worthwhile to learn Stieltjes integration so you can write probabilities and expectations as
[tex]E[g(X)] = \int_R g(x)dF(x)[/tex]
which is valid whether or not the distribution F(x) has a density.
