Why does removing a submanifold of codim 2 preserve connectivity?
  • Context: Graduate
  • Thread starter Thread starter HMY
The discussion revolves around the question of why removing a submanifold of codimension at least 2 from a connected manifold preserves its connectivity. Participants explore various approaches to prove this result, including local arguments, the Mayer-Vietoris sequence, and potential connections to Sard's theorem, particularly in the context of infinite-dimensional manifolds.
  • One participant suggests a local argument involving coordinate neighborhoods to show that paths can be constructed between points in the manifold that do not intersect the submanifold E.
  • Another participant mentions the Mayer-Vietoris theorem as a possible immediate proof, implying that the original poster may not be familiar with it.
  • A participant raises the question of connectivity preservation when removing a point from R², noting that it is path connected except in dimension 1.
  • There is a discussion about the implications of infinite-dimensional manifolds and the potential application of Sard's theorem, with references to transversality and generic paths avoiding E.
  • Some participants express uncertainty about how to apply Sard's theorem to the problem at hand, particularly in the context of infinite-dimensional spaces.
Participants do not reach a consensus on a single proof method. Multiple competing views and approaches are presented, and the discussion remains unresolved regarding the application of Sard's theorem and its implications for infinite-dimensional cases.
Some participants note limitations in their understanding of how to apply certain theorems, such as Sard's theorem, to the problem of connectivity preservation in infinite-dimensional settings. There is also a mention of the need for transversality in constructing paths that avoid the submanifold E.
HMY
Let M be a connected manifold. Let E be a submanifold of M of codimension at least 2.
Show M\E is connected.
I know examples of this result but how can one generally prove it?
Locally, it is true: Pick a point p in M. If p is not in E, take a coordinate nbhd U_p of p not intersecting E. Then U_p is path connected since M is. If p is in E, pick a coordinate nbhd U_p of p "adapted" to E, meaning U_p maps to R^n={(x_1,...,x_{n-2},y,z)} and E maps to R^{n-2}={(x_1,...,x_{n-2},0,0)}. So two points P,Q in U_p\E map to points whose last 2 coordinates are not both 0. Clearly we can find a path between P and Q that does not intersect E. For instance, if
P=(x_1,...,x_{n-2},2,-1), Q = (x'_1,...,x'_{n-2},0,3),
consider the "rectangular path" that first brings the z coordinate of P from -1 up to 3 while leaving all the other coordinates fixed, then brings the y coordinate of P from 2 down to 0 while leaving all the other coordinates fixed, and then brings the nonprimed coordinates to the primed coordinates in any way. (Note that we cannot do something like this if E has codimension 1, but if E has codim >2, then a similar argument works)
Ok, so now we're practically done: Pick any 2 points in M\E, and a path (in M) between them. Cover the path by coordinate charts of the form considered above and extract a finite subcover. Then forget the initial path and use the local argument above to construct a path between the two points which never crosses E and hence lies in M\E, thus proving M\E is path connected.
I think Mayer-Vietoris gives it immediately, but the poster may not know that theorem.
In a tubular neighborhood each point of the submanifold looks like a point at the center of a disk of dimension at least 2.
why does removing 0 from R^2 preserve connectivity?
I am not sure what the spirit of your question is. Euclidean space minus a point is path connected except in dimension 1. Given 2 points you can explicitly construct the path.
The spirit of my question was is in the sense that M could be infinite dimensional.
Could this be proven using Sard's theorem? I also spoke with some other math people
a while back and that is what they had suggested.
I did look up that there is an infinite dimensional version of Sards theorem (for infinite
dimensional Banach manifolds) but I don't see how to use this to prove M\E is connected.
The idea here would be to use transversality (which is basically the same as Sard's thm). Take two points in the complement of E. A generic path between them intersects E transversally (i.e. not at all). Thus your space is path connected.
  • · Replies 36 ·
