Why Does Rho_b Blow Up (Griffiths Pg. 176)
  • Thread starter Thread starter ehrenfest
    Griffiths
6 replies · 3K views
ehrenfest
[SOLVED] Griffiths page 176
Below example 4.4, Griffiths says "We cannot apply Gauss's law precisely at the surface of a dielectric, for rho_b blows up..."
Why does rho_b blow up?
That sentence is a bit convoluted, but G is probably referring to bound surface charge density, which corresponds to infinite volume charge density.
If a discussion in GIII confuses you, go back to GI, which has less of that confusing help.
Hello ehrenfest,it is an interesting question and I wonder if I myself understood this point while I read this section a year or two ago.
The problem is with the definition of [tex]\rho_b=\ - \ div \ P[/tex] and [tex]\sigma_b=\ P.n[/tex].UNDERSTAND that P is determined by [tex]\sigma_b[/tex] and [tex]\rho_b[/tex]
Note that when we say there is a quantity [tex]\rho_b[/tex] and another quantity [tex]\sigma_b[/tex],we generally do not care if there is any sharp boundary between the charge distributions.I mean we do not say upto 0.005 cm below the surface we would call [tex]\sigma_b[/tex] and below that we would call as [tex]\rho_b[/tex]
As Griffiths gives hint the charge density is expected to be gradually fade out toward the boundary.This makes [tex]\rho_b[/tex] a continuous function and hence P is also continuous.POLARIZATION GRADUALLY TAPERS OFF TO ZERO.This exculdes the existence of [tex]\sigma_b[/tex]
But if there were a sharp boundary like I mentioned, polarization P would be discontinuos across that boundary near (on) the surface and by taking the divergence you will get [tex]\rho_b=\infty[/tex].
I hope the problem is now clear to you.
I see. So you are saying that a uniformly polarized object of finite size is unphysical.
Not quite. What he's referring to is that any surface charge distribution can be written as a volume charge distribution by means of delta functions. For example, the surface charge density of a uniformly charged sphere can be written
[tex]\rho(r, \theta, \phi) = \frac{Q}{4\pi a^2}\delta(r - a)[/tex]
Naturally, this function blows up on the surface itself, just as the charge density (and divergence of E) blows up at a point charge.
I meant not exactly this,but like this.Refer to Griffiths problem 1.45 (b).The derivative of a step function is a delta function.Likewise If there is a distinguishable sharp boundary like between core and cover (jacket) of a body,rho_b must blow up.
In reality you might have a uniform polarized object.But do not be too obsessed with the distinction of rho_b and sigma_b---they are the different faces of the SAME distribution and is not different like core and cover (jacket).
