Why does tension decrease along a rotating rod pivoted at one end?
siddharth23
I read that if a bar is pivoted at one end and is rotating in a horizontal plane, the tension at a specific point decreases as you go away from the pivoted end.
Only inference I could draw from this is that the centrifugal force, which is the cause of tension, increses as you go towards the free end. But as the rod is a rigid body, tension at a certain point also acts on all points preceding it and the point closest to the pivot has the highest tension.
Is that correct?
hi siddharth23! :smile:
yes, the tension is greatest near the centre …
the tension at r has to supply the force to keep the whole rod from r to R,
so it's bound to be greater as r gets smaller
(alternatively , if you look at just the bit between r and r + dr, the tension at r has to supply the centripetal acceleration, ω2r, after you've subtracted the tension at r + dr !)
