Why Does the Acceleration Formula Work?
  • Thread starter Thread starter staetualex
    Acceleration
The discussion centers on understanding the acceleration formula and its components, emphasizing the importance of grasping the underlying math rather than just memorizing equations. Acceleration is defined as the rate of change of velocity, which is itself the rate of change of position, leading to the formulation a = d²x/dt². Participants highlight that a solid understanding of these concepts allows for easier derivation of related equations, reducing reliance on rote memorization. The conversation also touches on the value of translating mathematical expressions into more intuitive language for better comprehension. Overall, a deeper grasp of the principles behind the formulas enhances learning and application in physics.
staetualex
Hy folks! I am new in here.Anyone can give a basic intuition about why the acceleration formula actually works? I mean, my brain is not capable to "nerd-ize" formulas, i either forgot them , i either on a test write the coulomb formula something like (q1 q2 r^2)/2pi eps0. I am shure if i remember now the (d^2 x)/(dt^2) in a couple of months it will be something like dx^2/dv or whatsoever . Is anyone who can describe this formula, how it holds in a real example, some associations with other processes, etc. what every number/letter in that formula represent? I mean change in time square, what :confused:? thanks and have a good day!
It's a matter of learning to translate from math to English (and back).
x is position, t is time.
v={{dx}\over{dt}} or "velocity is the rate of change of the position"
a={{dv}\over{dt}} or "acceleration is the rate of change of the velocity"
Now that we're done defining terms, let's look at what that means:
Since v is the first derivative of x, and a is the first derivative of v, then a can be written as a second derivative of x.
Since both first derivatives are taken with respect to t,
a={{dv}\over{dt}}={{d^{2}x}\over{dt^{2}}}
I don't think I can stress enough just how much it helps to understand the math--I took a course once where I had to memorize 37 equations for the first test alone. Needless to say, it didn't go well. But on a second attempt at the course, with a better understanding of the math involved, I only had to memorize four or five equations and could derive all of the others in about a minute total.
hi, staetualex, take a little time on chain rules.
It's not dx^2/dv; it's vdv/dx.
I can't help you, but I thank you for adding a cool new word to my vocabulary. :smile:
First, look at the simplest possible case (constant acceleration).
If a is constant, then the solution for velocity looks like v=at+k.
When t=0, we know that at=0. This is pretty obvious so far, but it does tell us that k is the velocity at that time. Since it's the initial velocity of the object, I'll change the name of that variable to something that let's me remember what it represents.
v=at+v_{i}
Now if we go back to the definition of velocity, we have {{dx}\over{dt}}=at+v_{i}. We integrate again to solve for position, and get the following:
x={{{at^{2}}\over{2}}+v_{i}t+k
Again we note the first two terms are zero, when t=0, so this time k must be equal to the initial position. So once again, we rename that variable to something easier to remember.
x={{{at^{2}}\over{2}}+v_{i}t+x_{i}
well, i know, i was just predicting my future, in case i mechanically learn the formulas, not knowing the principle it works. I may forgot them, or scramble the terms involved. Others who gave a reply on post, thank you, you helped me to understand better the schrodinger equation proof.
Phase shifter, you are great, now I'm not dependent of the formula anymore, i can derive it by myself.
to danger, i am glad i can help , sometimes i can invent new words .
  • · Replies 24 ·
  • · Replies 16 ·
  • · Replies 27 ·
9K
