Why does the air we breath float on Earth?
  • Context: High School
  • Thread starter Thread starter themadquark
    Air Earth Float
The discussion revolves around the question of why the air we breathe does not simply sink to the ground on Earth, exploring concepts related to gas density, gravity, and atmospheric composition. Participants engage in a mix of theoretical and conceptual reasoning regarding the behavior of gases in the atmosphere.
  • One participant suggests that gravity is too weak to hold gases like O2 completely to the ground, implying a belief in a relationship between gravity and gas behavior.
  • Another participant counters that air does indeed sink to the ground, using the analogy of water in a swimming pool to illustrate that gases exist at various heights rather than floating away.
  • A different perspective is offered regarding the separation of atmospheric gases, questioning why the atmosphere does not stratify into distinct layers of different gases like Oxygen and Nitrogen.
  • One participant mentions that gases mix due to turbulence and diffusion, referencing a NOAA study to support this claim.
  • Another participant argues that gravity is not strong enough to compact the atmosphere significantly, suggesting that if it were, Earth would be a star instead of a planet.
Participants express differing views on the behavior of air and gases in the atmosphere, with no consensus reached regarding the underlying reasons for these phenomena. The discussion remains unresolved with multiple competing perspectives.
Some assumptions regarding the nature of gravity and gas behavior are not fully explored, and the discussion includes references to external studies without detailed examination of their implications.
themadquark
Why does air on Earth float? Obviously, lighter gases such as Helium and even hot air will float due to having a lowed density than the air around it. Why is it though that the base higher density gases that we breath float rather than sink to the ground? My belief is that gravity is simply too weak to hold the O2 and the other gases completely to the ground.
Air does sink to the ground. Put your head near the ground and breathe in - it still works down there!
Think of a swimming pool. Down at the bottom there's some water, and at the top there's water too. The water at the top of the pool isn't "floating", there's just not enough room for it all to be at the bottom.
On Earth, we're swimming around in a bunch of gases. Some gas at ground level, some is up higher, all in one giant pile. There isn't enough room for it all to be exactly 0 cm from the ground, so it piles up.
Perhaps the question the OP is asking is...
Why doesn't the atmosphere separate out into layers of Oxygen, Nitrogen etc.
Let's let the OP explain what he means rather than start another long thread guessing.
Gasses mix due to turbulence below 100 km and diffusion at high altitudes. A NOAA study of composition of the atmosphere versus altitude can be found in http://ruc.noaa.gov/AMB_Publications_bj/2009%20Schlatter_Atmospheric%20Composition%20and%20Vertical%20Structure_eae319MS-1.pdf
Please, let's let the OP explain what he means rather than start another long thread guessing.
Air doesn't all sink to the ground for the same reason you don't. Gravity on Earth isn't strong enough to compact it that much. The layer of atmosphere we live in is made up of gasses that weigh more than those in higer layers. If Earth's gravity was that strong the Earth would be a star instead of a planet.
This thread is 9 months old and the OP never returned to it. Locked.
  • · Replies 16 ·
  • · Replies 16 ·
  • · Replies 42 ·
13K
  • · Replies 41 ·
  • · Replies 20 ·
