Why does the Andromeda galaxy appear so tiny from our perspective?
81 replies · 19K views · last reply
glappkaeft said:
Passive optics cannot make anything brighter than the source.
So, as a child, when I burned ants with a magnifying glass, I was dreaming?
Or is your assertion true of the image only when it comes back into focus?
(I spent the last 30 minutes doing magnifying glass experiments in my kitchen. I suspect you may be correct.)
I understand that the ants probably weren't being roasted at 5800K.
Quick BoTE suggests that a telescope in the range you suggested would be about right but would require the human pupil to be around 7 m in diameter to accommodate the light.
I don't really know much about optics, but "7 meter pupils" makes it sound like I know even less than I did before. Thanks!
Btw, I spent about 2 hours, earlier this morning, trying to figure out where you came up with the "7 meter" figure. No luck.
Astronomy news on Phys.org
russ_watters said:
It's an eye-opener (so to speak). A great many of the nearer galaxies and nebulae are plenty big enough to see with the naked eye if our eyes were only sensitive enough to see such dim objects.
Indeed. I was astonished when I first realized that the Galilean moons subtended a perceptible angle to the naked eye.
If they were bright enough to see, collectively they would subtend as much as .175 degrees - that's equivalent to about 2mm wide, at arm's length - on the order of a character on the screen you're reading.
(Callisto's orbit is as much as 1.88 million km in dia. and as little as 588 million km away, for an angular dia. of .175 degrees).
That realization kind of brought the solar system right into my backyard.
yup, you were just taking a little bit of the Sun's light and concentrating it down to a small point (area)
Vanadium 50 said:
Maybe even way, way too high. :smile:
Dnj23, the purpose of a telecope is to make things brighter, not bigger. Magnification is almost an unfortunate side effect of this. A magnification of 200x means you have a field of view of maybe 0.3 degrees. That's smaller than the moon, and much, much smaller than M31. If it fills your whole field of view - and more - you can't tell that it's slightly brighter than the rest of the night sky.
M31 is many times larger than the moon. You don't need any magnification.
I said, even up to 200x, implying everything less.
Well then I must have the worst sky and optics, because I just don't see it. And it gets fairly dark, suburban .
And come on, not to make things bigger? Now that's just silly.
pinball1970 said:
That's amazing, I thought Andromeda was a barely visible point like blob because of the vast distance from us
lots of images on pf Our Beautiful Universe and I had no idea of its full size (if we could see it all)
It is a barely visible point like blob.
Andy Resnick said:
A picture is worth 1000 words: I 'added' pictures I took of the moon and Andromeda. Hope this clears things up.
Lol. That would be the most significant, well known celestial object known in the sky if that were even remotely close to such magnitude.
The editors of APOD must have been reading this thread. They chose today to feature photography of Andromeda. :cool:
https://apod.nasa.gov/apod/ap191014.html
Explanation: What does the Andromeda galaxy really look like? The featured image shows how our Milky Way Galaxy's closest major galactic neighbor really appears in a long exposure through Earth's busy skies and with a digital camera that introduces normal imperfections. The picture is a stack of 223 images, each a 300 second exposure, taken from a garden observatory in Portugal over the past year. Obvious image deficiencies include bright parallel airplane trails, long and continuous satellite trails, short cosmic ray streaks, and bad pixels. These imperfections were actually not removed with Photoshop specifically, but rather greatly reduced with a series of computer software packages that included Astro Pixel Processor, DeepSkyStacker, and PixInsight. All of this work was done not to deceive you with a digital fantasy that has little to do with the real likeness of the Andromeda galaxy (M31), but to minimize Earthly artifacts that have nothing to do with the distant galaxy and so better recreate what M31 really does look like.
No, that isn't correct. Not even Jupiter or Venus are large enough to see (close though), and the Galilean moons are bright enough if they weren't so near an overpoweringly bright object. I calculate a diameter of about 1.4 arcsec for Ganymede. Jupiter is about 40.
Galaxies are tough even at low magnification.
That's a self contradiction. is it a point - like a star - or a blob?
I agree it was overstated, and would say this: it is a lot easier to make objects bigger than brighter, and/so brighter is more important.
If it's suburban, it's probably just not dark enough. Try going out in the country where it gets really dark.
Under no circumstances would I describe the Andromeda galaxy as "point-like". I still think you're looking at the wrong thing. Why don't you try posting a sketch of what you see, with nearby stars, so we can see if you're looking in the right place.
I understand that the ants probably weren't being roasted at 5800K.I don't really know much about optics, but "7 meter pupils" makes it sound like I know even less than I did before. Thanks!
I have trouble with this one as well, but a little googling tells me the human eye has a focal ratio of about 2.1 at night when the pupil is fully open. That's a really "fast" optical system and pretty much unachievable with a telescope. So any focal ratio above that will produce a dimmer image than with the naked eye.
Not unachievable at all. The LSST, an 8.3 meter optical telescope currently under construction at Cerro Pachon in Chile, will run at f1.2.
https://www.lsst.org/
OmCheeto said:
So, what would a telescope look like, to be able to allow a human to look into its eyepiece, and see the Andromeda galaxy like that{your image}, in real time?
ps. Fun thread. Thank you, @Dnj23 .
I compared the ratio of luminous flux from a full moon (mag. -13) and Andromeda (mag 3.5), which then gives the (proposed) ratio of entrance pupil areas. From this, the ratio of diameters is 1900, giving a telescope diameter of (about) 15 m, using a 8mm eyeball pupil diameter.
I was going to ask the same question.
I can see Venus just fine, thank you. :wink:
Seriously, while I don't see a disk, I can see Venus' phases in that sometimes it looks symmetric and sometimes it looks elongated.
It's point like to the unaided eye, blob like through my telescope.
This is a sky dark enough to see all of Ursa Minor, but none of the Milky Way haze.
For comparison, the Ring Nebula in Lyra is barely a shade lighter than dark. You have to stare at it for moments with adjusted eyesight, knowing that it's there to see it.
I have 20/15 vision and have never been able to convince myself of that. If nothing else, it's too bright.
I'll try sunglasses...
[Googles/maths]
Venus's maximum size is 65 arc sec (not corrected for phasing). "normal" 20/20 vision is defined to be 60 arc sec (to discern 300 arcsec letters), so 20/15 should be 45. That's tough.
I wonder, though, if there is an optical blooming effect that makes it possible to see the phases without actually resolving the disk.
Not large enough to see as discs? I don't know what you are really saying here but any of the planets, when they are visible by eye, look very different from stars. I tell myself that it's because they look like discs but I suppose it could just be the lack of twinkle. My eyesight is pretty rubbishy but I can 'nearly always' tell them apart from stars and that's when I don't know the direction I'm looking in (i.e. in a place where N is not obvs - not blind drunk.)
Sorry, I may not have expressed myself adequately. I was talking about their orbits. i.e. if they were bright enough, you could distinguish the Moons as distinctly separated from Jupiter with the naked eye - at their farthest, collectively they would subtend a perceptible angle of the sky.
I assume you mean see "as a disc".
Venus can be seen when in crescent phase by the naked eye.
there you go ... If you can't see the glow of the Milky Way, you are not going to see ( naked eye)
the fuzz of Andromeda
Suburbia is not the place for faint object observations. I have to travel an hour from home to get
far enough out of the city lights to see the elongated fuzz of AndromedaDave
russ_watters said:
Sorry, I meant not large enough to resolve disks with the naked eye.
Rayleigh criterion can be a bit pessimistic for some aspect of an object. The 3dB point is a bit arbitrary but easy to apply - that's in its favour.
Ok, thanks. This and other replies make sense. I never realized just how star photography can be so deceiving.
Also, you guys have amazing eyesight...Seeing Venus in phases?
Chinese historian of astronomy, Xi Zezong, has claimed that a "small reddish star" observed near Jupiter in 362 BCE by Chinese astronomer Gan De may have been Ganymede, predating Galileo's discovery by around two millennia.
https://en.wikipedia.org/wiki/Galilean_moons
Also interesting
So, here's another picture which shows the Andromeda galaxy as it would appear to the naked eye in a not very dark sky - it's the fuzzy blob at the center of the red ellipse. The full extent of the outer regions of Andromeda are outlined in red, and Andromeda's dwarf satellite galaxies M110 and M32 are pointed out. The moon is also shown in the correct size on the sky as comparison to the extent of Andromeda:
Hope this helps in visualizing the sizes and appearances on the sky.
No way dude.
Dnj23 said:
No way dude.
Ummm, in what way "no way", dude?
OK, so here's another image, this time from NASA's Astronomy Picture Of The Day site, which overlays an image of the Moon on an image of the Andromeda Galaxy as recorded by a decent telescope, so the galaxy appears much brighter and wider than when seen with the naked eye.:
https://apod.nasa.gov/apod/image/0612/m31abtpmoon_c720.jpg
Note the positions of the two dwarf satellite galaxies M110 and M32...
Ok. Where does your picture fall in this top 10?
Ask a question that illuminates or adds to the discussion, and you'll get a sensible answer.
