Why does the wave equation change between sine and cosine forms?
5 replies · 7K views
quietrain
a wave equation is given as A = A cos (kx - ωt)
so why if someone describes the wave equation to be A = A sin (ωt - kx) , the argument of the sin function changes by a minus sign?
and is there a meaning to it?
also i still don't really understand why the minus sign in the first equation signifies wave moving forward whereas a + sign signifies wave moving backwards ...
thanks a lot for the help!
kx - ωt = kx' - ωt' if both x' > x and t' > t. => The same wave value A cos(kx - ωt) propagates with time in positive x direction.
You don't have a wave equation there, you have solutions to a wave equation.
As well, since cos(-z) = cos(z), i.e. cos is an even function you can write the cos solution as A cos (ωt - kx) if you wish.
The general solution to the wave equation is
Acos(wt - kx) + Bsin(wt -kx)
where A and B are determined by the initial or boundary conditions
If you wrote the general solution in terms of (kx - wt) then the sign of the factor multiplying the sin function would change to accoomdate this.
oh...
so cos (kx - ωt) = cos (ωt- kx ) because it is an even function.
so what's the difference if we choose to write it in sin instead?
quietrain said:
...so what's the difference if we choose to write it in sin instead?
You can write in either way. The initial/boundary conditions will determine the signs and values of coefficients A and B in the general solution Acos(wt - kx) + Bsin(wt -kx).
