Why does this Lagrangian seem "asymmetric"?
  • Context: Graduate
  • Thread starter Thread starter Alexandre
    Lagrangian
The discussion centers around the Lagrangian given for a particle in a magnetic field, specifically examining its apparent asymmetry in terms of the variables x and y. Participants explore the implications of the Lagrangian's structure, its relation to the Lorentz force, and the derivation of the Lagrangian itself, touching on concepts such as potential energy and magnetic vector potential.
  • One participant notes the Lagrangian appears asymmetric due to the presence of ẋ in the term eBẋy and questions why there is no corresponding term involving ẏ and x.
  • Another participant suggests that the term eBẋy can be considered a form of potential energy, but clarifies it does not depend solely on positions, thus not qualifying as a true potential.
  • Some participants propose that alternative terms, such as -ẏx or a combination of ẋy and -ẏx, could also be used, but emphasize that xy would not yield the correct solution.
  • A later reply discusses the derivation of the Lagrangian in the context of the magnetic vector potential, explaining how it relates to the Lorentz force and the equations of motion.
  • One participant mentions that adding a total derivative to the Lagrangian does not affect the equations of motion, which is relevant to the discussion of symmetry.
  • Another participant points out the symmetry in the derived equations of motion, suggesting a need to consider this aspect in the context of the Lagrangian's structure.
Participants express various viewpoints regarding the interpretation of the Lagrangian and its terms, indicating that multiple competing views remain. The discussion does not reach a consensus on the nature of the asymmetry or the best way to derive the Lagrangian.
Participants highlight that the magnetic vector potential is not uniquely defined, as it can be altered by the gradient of a scalar field without changing the resulting magnetic field. This introduces additional complexity in the discussion of the Lagrangian's formulation.
Alexandre
I got this Lagrangian on the exam and it just seems weird to me:
L = \frac{m}{2}(ẋ²+ẏ²) – eBẋy
What I mean by "asymmetric" is that it doesn't seem to behave in a same way on x as on y, because there is ẋ in the last term and y but there is no ẏ and x.
Deriving Euler-Lagrange equations I get:
ẍ = ωẏ
ÿ = –ωẋ
(Where ω=\frac{eB}{m})
Solution to the equations as I calculated must be:
x(t) = \frac{c_{2}}{ω}sin(ωt) – \frac{c_{1}}{ω}cos(ωt) + x0
y(t) = \frac{c_{2}}{ω}cos(ωt) + \frac{c_{1}}{ω}sin(ωt) + y0
(c1 and c2 depend on initial velocities along x and y, x0 and y0 are initial positions)
This must be the Lorentz force acting on a particle with elementary charge moving with velocity v perpendicular to magnetic field B.
Here's the animation
https://www.desmos.com/calculator/r3mzstju9x
So to clarify my question and extend it a little bit, how is the Lagrantian derived (the last term obviously)? Why is there ẋy and not ẏx or yx for instance? Can eBẋy be a potential energy?
This is not a homework, I'm posting this for my curiosity. And also it doesn't seem to match the strict guidelines provided in homework subforum.
It is some sort of potential energy - it does not depend on positions alone, so it is not a true potential. The magnetic vector potential is a related concept.
You could use -ẏx as well, or even some sum of ẋy and -ẏx. xy would be a regular potential, that does not give the right solution.
Thanks for the reply! As I understand using -ẏx instead of ẋy wouldn't change the direction of the particle since there is a minus sign there on ẏx, right? And concerning the magnetic vector potential, how exactly do I derive the Lagrangian for the two dimensional case?
A fact about Lagrangians is that adding a total derivative makes no difference.
So adding a term like \dfrac{d}{dt} (- x y) = - x \dot{y} - y \dot{x} makes no difference.
The point is that the magnetic part of the Lorentz force (reluctantly using SI units) is
\vec{F}=q \vec{v} \times \vec{B}.
It is velocity dependent and thus has not a potential. Nevertheless, one can derive a Lagrangian which leads to this force.
The trick is that from Maxwell's equations we know that there exists a vector potential for the magnetic field:
\vec{B}=\vec{\nabla} \times \vec{A}.
Since the force is linear in \vec{v}, the part of the Lagrangian, L_I, describing the interaction with the magnetic field should be linear in \vec{v} too, because setting
L=\frac{m}{2} \dot{\vec{x}}^2+L_I
via the Euler-Lagrange equations yields the EoMs
m \ddot{\vec{x}}=\frac{\partial L_I}{\partial \vec{x}}-\frac{\mathrm{d}}{\mathrm{d} t} \frac{\partial L_I}{\partial \dot{\vec{x}}} \stackrel{!}{=} q \dot{\vec{x}} \times \vec{B}.
Thus we make the ansatz, linear in the velocity
L_I=\dot{\vec{x}} \cdot \vec{\alpha}(\vec{x}).
To evaluate the derivatives above, it's more convenient to switch to the Ricci calculus with indices, giving
\frac{\partial L_I}{\partial x_j}=\dot{x}_k \partial_j \alpha_k
and
\frac{\mathrm{d}}{\mathrm{d} t}\frac{\partial L}{\partial \dot{x}_j} = \frac{\mathrm{d}}{\mathrm{d} t} \alpha_j)=\dot{x}_k \partial_k \alpha_j
This gives
\frac{\partial L}{\partial x_j}-\frac{\mathrm{d}}{\mathrm{d} t}\frac{\partial L}{\partial \dot{x}_j} = \dot{x}_k (\partial_j \alpha_k - \partial_k \alpha_j)=\dot{x}_k \epsilon_{jkl} (\vec{\nabla} \times \vec{\alpha})_l=[\dot{\vec{x}} \times (\vec{\nabla} \times \vec{\alpha})]_j \stackrel{!}{=} q \vec{v} \times (\vec{\nabla} \times \vec{A})
Comparison of both sides of the equation leads finally to
\vec{\alpha}=\frac{q}{c} \vec{A}.
Thus the non-relativistically approximated Lagrangian for the motion of a particle in a magnetic field is
L=\frac{m}{2} \dot{\vec{x}}^2 + q \dot{\vec{x}} \cdot \vec{A}.
Now your Lagrangian is precisely of this form with
\vec{A}=-B y \vec{e}_x.
The curl is
\vec{\nabla} \times \vec{A}=B \vec{e}_z.
Thus, you have indeed described a particle of charge e in a magnetic field in z direction.
The vector potential is, however, only determined up to the gradient of a scalar field, i.e., for any scalar field \chi also
\vec{A}'=\vec{A}+\vec{\nabla} \chi
leads to the same magnetic field. The interaction Lagrangian changes to
L_I'=q \dot{\vec{x}} \cdot \vec{A}'=q \dot{\vec{x}} \cdot (\vec{A}+\vec{\nabla} \chi)=q \dot{\vec{x}} + q \frac{\mathrm{d}}{\mathrm{d} t} \chi,
i.e., the new Lagrangian deviates from the old one only in a total time derivative of a function that depends only on the generalized coordinates and not the generalized velocities, which yields the same equations of motion according to the Hamilton principle, as you can derive immediately, using the Euler-Lagrange equations.
This is an example for gauge invariance in the Lagrangian formulation. The full glory of this scheme, of course, becomes apparent only in the relativistic formulation, which is the adequate description of electromagnetic phenomena.
Though I find it difficult to follow at some places, I thank you all for replying!
Please note the symmetry of the equations of motion you have derived.
and
This gives
The curl is
What I think he is trying to say is that the vector potential (which appears explicitly in the lagrangian) is unphysical and thus can exhibit unphysical asymmetry. If you wish you could probably add a gradient of some function to the vector potential to make it symmetriic.
The question then is, what you mean by "symmetric"? The point is that the equation of motion (variation of the action or even the action itself as in this) is gauge independent. By changing the gauge, sometimes you can make a variable cyclic which wasn't before. That's why it's clever in the present case of a constant magnetic field to use a vector potential that contains only on one variable (here y), because then the other two coordinates are cyclic, which makes the solution of the equations of motion easier.
This has actually made me think, if one defines a positive charge and an upwards direction, doesn't a unique sense of left and right emerge from the magnetic interaction?
Additionally, since there is an imbalance between matter and antimatter in the universe, hasn't a natural positive charge already been picked out for us?
No, it does not. The "right hand rule" is arbitrary you could just as well use the "left hand rule" and everything would work the same (with reversed direction for the magnetic field since its direction depends on the arbitrary choice of right hand rule. That's why the Magnetic field is a Pseudo-vector. A pseudo vector really is a anti-symmetric second rank tensor represented as a vector just for convenience.
