Why Does Wolfram Alpha Show a Different Exponential Integration Result?
5 replies · 2K views
izen
exponential integration formula [itex]∫a^{u} du = \frac {a^{u}}{ln(a)} +c[/itex]
∫ [itex]\left(\frac{2}{3}\right)^{x} dx[/itex]
[itex]\frac{}{}[/itex]
= [itex]\frac{\left(2/3 \right)^{x}}{ln(2)/ln(3)}[/itex] <<< this is my answer ?= - [itex]\frac{\left(2/3 \right)^{x}}{ln(3)/ln(2)}[/itex] << this answer from wolframalpha why ln(3)/ln(2) not ln(2)/ln(3) and where the minus comes from
please advisethank you
It's just logarithm rules:
[itex]\log{a^{b}}=b\log{a}[/itex]
Btw, you can compare if two expressions are equivalent in Wolfram with " -(2/3)^x/(ln(3/2))==(2/3)^x/(ln(2/3)) ". As you can see, the output is "True".
EDIT: I'm assuming you meant ln(3/2) and ln(2/3) instead of ln(3)/ln(2) and ln(2)/ln(3), as the former is 1) correct and 2) what Wolfram actually gives as an answer.
None of the answers you have mentioned is correct. You have done the same mistake again as you did in your previous threads.
[tex]\ln \frac{a}{b}≠\frac{\ln a}{\ln b}[/tex]
Both of the following answers are incorrect.
please advise
thank you
Actually, WolframAlpha gives:
[itex]\displaystyle \int \left(\frac{2}{3}\right)^{x} dx=-\frac{\left(2/3 \right)^{x}}{\ln(3/2)}+\text{constant}\ .[/itex]
As for the minus sign: [itex]\displaystyle \ \ \ln\left(\frac{2}{3}\right)=\ln\left(\frac{3}{2} \right)^{-1}\!\!=(-1)\ln\left(\frac{3}{2}\right)\ .[/itex]
I see Pranav-Arora beat me to it!   (Way to go, P-A !)
Added in Edit:
By the way:
[itex]\displaystyle \ln\left(\frac{2}{3}\right)=\ln(2)-\ln(3)[/itex]
On the other hand: [itex]\displaystyle \ \ \frac{\ln(2)}{\ln(3)}=\log_{\,3}(2) \ .[/itex]
ohhh I have to be more careful about this
Thank you Pranav-Arora
Thank you Sammy for the clarification
