Why Does WolframAlpha Give Different Results for Differentiating (cos(x))^x?
  • Context: Undergrad
  • Thread starter Thread starter PeterPumpkin
8 replies · 4K views
PeterPumpkin
I wanted to differentiate (cos(x))^x
Applying the chain rule I got -x(sinx)(cosx)^(x-1)
But when I go to WolframAlpha, they show
d/dx(cos^x(x)) = cos^x(x) (log(cos(x))-x tan(x))
Why the extra term? Why doesn't the simple chain rule apply?
I have got strange results from WolframAlpha before
eg try typing (-1)^(1/3)
You don't get -1 as a root.
As for the derivative: power rule [tex](x^n)'=nx^{n-1}[/tex] applies for constant exponents only.
As for the root: there are 3 different complex numbers satisfying [tex]x^3=-1[/tex]:
[tex]-1[/tex], [tex](1/2)(1\pm i\sqrt{3})[/tex].
Because you have differentiated wrongly.
Rewrite as follows:
[tex]\cos(x)^{x}=e^{x\ln(\cos(x))}[/tex]
and differentiate properly.
Thanks.
a) So, the chain rule eg putting u=cosx and y=u^x doesn't work in this case? Is that because the power is not a constant? Or is there some other reason?
b) Yes, appreciate the cube root of -1 has complex roots. What puzzled me is that -1 didn't show as a valid root. I wondered why it didn't show. www.wolframalpha.com/input/?i=cube+root+of+-1
You didn't ask "what are all of the cube roots of -1". You asked "what is the value of applying the cube root function to the number -1".
It's essentially the same idea as [itex]\sqrt{4} = 2[/itex].
Try "solve x^3 = -1" or "roots of x^3 + 1" or things like that.
That faces the same problem as differentiating x^x without modifying the expression.
Here is a simple method for dealing with such things.
[tex] y=\cos^{x}x[/tex]
Take logs to get:
[tex] \log y=x\log\cos x[/tex]
Now differentiate to arrive at:
[tex] \frac{1}{y}\frac{dy}{dx}=\log\cos x-\frac{x\sin x}{\cos x}[/tex]
Multiple and re-arrange to get the solution, that I will leave to you.
Mat
PeterPumpkin said:
Thanks.
It is not that the "chain rule doesn't work", it is that you have differentiated [itex]u^x[/itex] in correctly. If [itex]y= u^x[/itex] then [itex]ln(y)= x ln(u)[/itex] and then [itex](1/y) dy/dx= ln(u)+ (x/u) du/dx[/itex] so that [itex]du^x/dx= u^xln(u)+ u^{x-1}xdu/dx[/itex].
PeterPumpkin said:
Thanks.
What Wolframalpha is showing is the "principal root".
