Why Doesn't My Win32 Pendulum Simulation Oscillate?
1 reply · 11K views · last reply
stringa
Simple Pendulum using Forces (Computer Simulation)
Max theata = PI / 6
Force Of Gravity is { 0, 10 }
Force_Tension.x = - 10 * sin(balls.theata);
Force_Tension.y = - 10 * cos(balls.theata);
accelleration = Force_Tension - Force_Gravity / mass
Written in Win32 APi
All Physics is done in WM_CREATE and updatePhysics...the program does not oscillate !
/* animation_shell.c
** -- Bare bones windows animation program.
** cs230 2/07
#include <stdlib.h>
#include <time.h>
#include <windows.h>
#include <math.h>
#define PI 3.14159f
struct _2Dfloat {
float x;
float y;
struct ball {
_2Dfloat current_position;
_2Dfloat current_velocity;
_2Dfloat current_accelleration;
int length_of_rope;
POINT rope_origin;
float theata;
float sqrt_g_over_r;
ball balls;
_2Dfloat Force_Gravity = {0, 10};
_2Dfloat Force_Tension;
void draw(HWND win);
void updatePhysics(void);
LRESULT CALLBACK WinProc(HWND win, UINT msg, WPARAM wp, LPARAM lp) {
switch (msg) {
case WM_CREATE:
balls.length_of_rope = 300;
sqrt_g_over_r = sqrt(10.0 / balls.length_of_rope);
balls.rope_origin.x = 300;
balls.rope_origin.y = 0;
balls.theata = - PI / 6;
balls.current_accelleration.x = 0;
balls.current_accelleration.y = 0;
balls.current_velocity.x = 0;
balls.current_velocity.y = 0;
balls.current_position.x = balls.rope_origin.x + balls.length_of_rope * sin(balls.theata);
balls.current_position.y = balls.length_of_rope * cos(balls.theata);
break;
case WM_CHAR:
if (wp == 0x1b)
DestroyWindow(win);
break;
case WM_DESTROY:
PostQuitMessage(0);
break;
default:
return DefWindowProc(win,msg,wp,lp);
return 0;
int WINAPI WinMain(HINSTANCE instance, HINSTANCE ignore,
LPSTR command_line, int show) {
char *window_title = "Put title here",
*class_name = "Give class name";
WNDCLASS wc;
HWND win;
MSG msg;
wc.style = 0;
wc.lpfnWndProc = WinProc;
wc.cbClsExtra = 0;
wc.cbWndExtra = 0;
wc.hInstance = instance;
wc.hIcon = LoadIcon(NULL,IDI_APPLICATION);
wc.hCursor = LoadCursor(NULL,IDC_ARROW);
wc.hbrBackground = NULL;
wc.lpszMenuName = NULL;
wc.lpszClassName = class_name;
RegisterClass(&wc);
win = CreateWindow(class_name,window_title,
WS_POPUP,CW_USEDEFAULT,CW_USEDEFAULT,
GetSystemMetrics(SM_CXSCREEN),GetSystemMetrics(SM_CYSCREEN),NULL,NULL,instance,NULL);
ShowWindow(win,show);
// Animation Styple "greedy" event loop
while (IsWindow(win)) {
if (PeekMessage(&msg,win,0,0,PM_REMOVE)) {
TranslateMessage(&msg);
DispatchMessage(&msg); }
else
updatePhysics();
draw(win);
// give some cycles back to the CPU
Sleep(50);
UnregisterClass(class_name,instance);
return msg.wParam;
void draw(HWND win) {
static COLORREF color = RGB(255,128,128);
HDC dc;
HBRUSH brush;
RECT rect;
dc = GetDC(win);
GetClientRect(win,&rect);
FillRect(dc,&rect,(HBRUSH) GetStockObject(WHITE_BRUSH));
const int scale = 50;
// Draw the Rope
MoveToEx(dc, balls.rope_origin.x, balls.rope_origin.y, NULL);
LineTo(dc, balls.current_position.x, balls.current_position.y);
// Draw the force of Tension
LineTo(dc, balls.current_position.x + scale * Force_Tension.x, balls.current_position.y + scale * Force_Tension.y);
MoveToEx(dc, balls.current_position.x, balls.current_position.y, NULL);
LineTo(dc, balls.current_position.x, balls.current_position.y + Force_Gravity.y);
ReleaseDC(win,dc);
static float time = 0;
const float change_of_time = .9f;
// Update Theata
// Calculate Accelleration by old theata
// The mass has already been divided out of the system...thus subtracting the forces
// gives me the accelleration
balls.current_accelleration.x = Force_Gravity.x - Force_Tension.x;
balls.current_accelleration.y = Force_Gravity.y - Force_Tension.y;
if (balls.theata < 0)
balls.current_velocity.x = - balls.current_accelleration.x * (change_of_time);
else
balls.current_velocity.x = balls.current_accelleration.x * (change_of_time);
balls.current_velocity.y = balls.current_accelleration.y * (change_of_time);
// Update Ball Position
// I thin this is ****ing everything up
balls.current_position.x += balls.current_velocity.x * (change_of_time);
balls.current_position.y += balls.current_velocity.y * (change_of_time);
// Calculate my new theata with the dot product
// I will try and dot the current rope with the force of gravity
//balls.theata = I keep trying the dotProduct of gravity and current ball position
// and it never seems to work
// what am I doing wrong
printf (or count) is your friend...see if the values are what you expect them to be.
u might want to clean up the code so its readable
also printout gravity
and it might help to explain what is the ball doing that's erroneous (besides sayign its not oscillating)...is it going to infinity.
from first look it might be sin/cos values...where your using floats.
