Why doesn't the chain rule give f'(x) = x²?
  • Thread starter Thread starter endeavor
    Derivative
19 replies · 4K views
endeavor
Find f'(x) if it is known that
[tex]\frac{d}{dx}[f(2x)] = x^2[/tex]
I let u(x) = 2x, then
[tex]\frac{d}{dx}[f(u)] = \frac{dy}{du} \frac{du}{dx}[/tex]
[tex]\frac{d}{dx}[f(2x)] = 2 \frac{dy}{du}[/tex]
therefore
[tex]\frac{dy}{du} = \frac{1}{2}x^2[/tex]
then
[tex]f'(x) = \frac{dy}{dx} = \frac{dy}{du} \frac{du}{dx}[/tex]
[tex]= (\frac{1}{2}x^2) (2)[/tex]
[tex]= x^2[/tex]
why doesn't this work??
u have f'(2x) = x^2
first find f(2x) and try to write it as a function of (2x)
and then after u do that substitute x for 2x
you therefore find f(x) finally derive it and you obtain f'(x)
does it make any sense?
let me know what your answer is to see if you did it right
Well, i kinda cheated and looked at the solutions manual:-p
Using the chain rule:
[tex]\frac{d}{dx}[f(2x)] = 2 f'(2x) = x^2[/tex]
[tex]f'(2x) = \frac{1}{2}x^2[/tex]
then let u(x) = 2x
[tex]f'(u) = \frac{1}{2} (\frac{u}{2})^2[/tex]
[tex]f'(u) = \frac{1}{8} u^2[/tex]
then substitute x for u:
[tex]f'(x) = \frac{1}{8} x^2[/tex]
Is there an easy to understand explanation why my original method did not work?
hehe good
my method was simple: f'(2x) = x^2 --> f(2x) = x^3 / 3
we multiply the denominator and numerator by 8 --> f(2x) = 8x^3 / 24
---> f(2x) = (2x)^3 / 24 ---> f(x) = x^3 / 24 --> f'(x) = x^2 / 8
your mistake was taking partial derivatives
u write f'(x) = dy/dx = (dy/du)/(du/dx)
since y and u are both functions of x u can not apply the partial derivative (the chain rule formula)
Thanks A_I_, I like your method :-p
can you expand on what you said my mistake was? I'm not sure I understand.
the chain rule is used when u have:
f(x,y) and x=g(t) and y=r(t)
but since your f and your u are both functions of x,
thus you can not use the chain rule and you can not say:
f'(x) = (dy/du)*(du/dx)
ok?
Yeah, i think I understand.
Can you explain that function syntax? I've seen it before, but I've always learned the simple f(x) not f(x,y)
and for composite functions (using the chain rule), f(x) = g(r(x))
what do you exactly want to know?
do you want an example of the chain rule?
what you wrote: f(x)= g(r(x)) is (gor)(x) and is different from the chain rule.
do you have an im?
i know what the chain rule is.
i just want to know what f(x,y) means and what "f(x,y) and x=g(t) and y=r(t)" means.
here you go
What do you mean by partial derivative here? You only encounter partial derivative in multi-variable function, not 1 variable function like f(x)!
ok?
NOOO! What do you mean by this? I am TOTALLY lost!
Why can't you use the chain rule in that case? Am I misssing something? :confused:
Please look back at your cal textbook, see the part that covers the chain rule.
[tex]\frac{df}{dx} = \frac{df}{du} \times \frac{du}{dx}[/tex]
Example:
[tex]\frac{df(2x)}{dx} = \frac{df(2x)}{d(2x)} \times \frac{d(2x)}{dx} = 2 f'(2x)[/tex].
Now, let's do your problem in a slightly different way:
[tex]\frac{df(2x)}{dx} = 2 f'(2x) = x ^ 2[/tex]
[tex]\Rightarrow f'(2x) = \frac{x ^ 2}{2}[/tex]
Now, let y = 2x, we have:
[tex]f'(y) = \frac{(2x) ^ 2}{8} = \frac{y ^ 2}{8}[/tex]
Now, what's f'(x)?
Can you go from here? Is there anything unclear? :)
Whoops, looking back at some previous posts of this thread, I saw that you've looked through the manual.
The only error you made is that you were trying to find dy / dx, which means you were finding d(f(2x)) / dx, not d(f(x)) / dx (which means the same as f'(x)).
Is there anything unclear, endeavor? :)
Example:
Now, what's f'(x)?
for the first part, that's what i was trying to tell him,
that we only use the chain rule when we have a multivariable function, which is not the case.
As for the second part, i am not sure about it, because i know you can only use the chain rule with multivariable function.
Did u consider x and 2x to be two different variables, if yes, then it works.
What do you mean?
Chain rule can be used for both multivariable functions, and 1 variable function.
You must have studied [tex]\frac{df}{dx} = \frac{df}{du} \times \frac{du}{dx}[/tex] BEFORE studying multi-variable functions, no?
As I told you before, you should re-read your calculus textbook, just look up the chapter for Chain rule (or you can just click on the link) for one variable function. That won't do you any harm, I promise. :wink:
So when in my first post I wrote:
[tex]\frac{dy}{du}[/tex]
that really means
[tex]\frac{d f(2x)}{du}[/tex]
since y = f(2x) ?
and then later on, when I wrote:
[tex]\frac{dy}{dx} = \frac{dy}{du} \frac{du}{dx}[/tex]
I was actually finding f'(2x), which was already given??
that really means
since y = f(2x) ?
Yes, this is correct. :)
Nah, this is not correct, you are finding:
[tex]\frac{df(2x)}{dx}[/tex], not f'(2x).
[tex]\frac{df(2x)}{dx} \neq f'(2x)[/tex].
To find f'(2x), you must find: [tex]\frac{df(2x)}{d(2x)}[/tex].
Can you get this? :)
