Why doesn't x^2+1 has no zeroes
  • Context: High School
  • Thread starter Thread starter manogyana25
16 replies · 3K views
manogyana25
Why doesn't x^2+1 has no zeroes i.e, zero of the polynomial??
Mathematics news on Phys.org
##x^2+1## is always positive. For a negative number -k, you get
##f(-k)=(-k)^2+1=k^2+1##
For positive numbers also, it will always return a positive number.
Since ##x^2>=0##
##x^2+1>=1##
Hence it can never be zero.
{This part is optional:
If you know calculus,
##\frac{dy}{dx}=2x##
For critical points,##2x=0## so x=0 is a point of inflection
##d^2y/dx^2=2## which is positive. So at x=0, you have a minimum value.
##f(0)=1##
So the least possible value attained by the polynomial is 1. }
Hence, the curve never goes below the y=1.So the polynomial can never be zero.
Take this as a question for practice:
Prove that ##x^2-1## has two distinct zeroes
Technically, f(x) = x2+1 has no real zeroes. :-p
Since ##x^2>=0##
##x^2+1>=1##
##f(0)=1##
X^2-1=0
X^2=1
X=√1
X=1
Hey, I have another thought regarding this..
X^2+1=0
X^2=-1
X=√-1 which is an imaginary number..
So it can never be zero..
X^2+1=0
X^2=-1
Correct.
The method with which you tried to show that x^2-1 has two real distinct zeroes is wrong.
x^2 can also be zero. But it does not have distinct roots.
For distinct roots, the curve has to come below the x-axis. That is, the parabola should have a negative minimum.
Or you can use this: b^2 - 4ac>0
AdityaDev said:
Correct.
Sorry.. Whatever the curve, parabola and everything you said, I didn't understand. I haven't took those classes yet. Can you please name that chapter for me??
Ok.
Do you know this formula:
$$D=b^2-4ac$$
It is called discriminant.
When D<0, you have no real roots.
When D>0, you have 2 distinct roots.
When D=0, you have 1 root.
manogyana25 said:
What is D
Discriminant.
Do you know how to find roots of a quadratic equation using this formula:
$$x=\frac{-b^+_-\sqrt{b^2-4ac}}{2a}$$
Noooo... I've not taken classes regarding that topic yet.. If you really want to say that to me.. Then probably you must spend all your time here... ;)
K
manogyana25 said:
X^2-1=0
X^2=1
X=√1
X=1
This is not correct (or at least, not complete).
If x2 = 1,
then x2 - 1 = 0
so (x - 1)(x + 1) = 0
so x = 1 or x = -1
The point is, there are two solutions.
X^2+1=0
X^2=-1
Similar to the above, if x2 + 1 = 0, then x = i or x = -i. Again, there are two solutions, neither of which is real.
Oh yes, I totally missed this point... I got it now.. Thank you Mark44.. :)
If x2 = 1,
then x2 - 1 = 0
so x = 1 or x = -1
Hey but its not (x^2-1)^2 ... Its x^2 -1 right?? Then how can it be (x+1)(x-1)
x2 - 1 factors into (x + 1)(x - 1). To verify this for yourself, carry out the multiplication of (x + 1)(x - 1).
Yes yes I got it thanks!
When D is zero, it doesn't mean there's only one root
It means there are two roots but both of them are equal!UchihaClan13
