Homework Helper
- 7,832
- 532
I am not saying that gravity accounts for nuclear stability. Obviously the force of gravity is not sufficient to account for the binding energy of a proton and neutron (ie. the energy required to unbind them). I am suggesting that the explanation for this energy barrier might not require the existence of a mysterious nuclear force at all. If that is the case, then gravity might be the only force in the nucleus.Tom Mattson said:OK, then what is it that prompts you to ask whether gravity can be responsible for nuclear binding? Clearly, nuclear stability cannot be accounted for by gravity as we know it. So you must be thinking of gravity as we don't know it.
Where does this idea come from?
An analogy would be to very dense and heavy ball bearings (pretend they are made from neutron star matter) sitting on a level frictionless surface at the bottom of a deep Earth well. Their own gravity would attract them to each other and keep them together but is not the force that keeps them in the well. I am suggesting that there may be some energy barrier that keeps the nucleons from leaving the region of the nucleus, but that it is not a force x distance energy barrier (that is where the analogy ends, of course, because the energy barrier that keeps the ball bearings in the well is Earth gravity x height of the well).
It isn't necessitated. The question is whether observational evidence can have an alternate explanation. In case you haven't noticed, I don't like the strong nuclear force.How is it necessitated by any observational evidence?
I knew that. I was being facetious. I also play hockey.My remark was directed at the blue[/color] part.
Because the "particles" are on ice skates, they continue their motion, even if the ball is dropped after the exchange.
But if the ball drops, it is not moving toward the skater (the grabber). That means the skater has stopped the ball. Since the momentum of the ball in the direction of the skater has to equal to the momentum of the skater in the direction of the ball in the original frame of reference (ie. before the grab), the skater stops moving. The forward momentum of the skater has to equal the backward momentum of the ball. When the ball stops, the skater stops.
Do you not agree that in the original rest frame, the position of the center of mass of the skater and the ball cannot change? So either the ball keeps moving past the skater's back (ie he throws it behind him) and the skater keeps moving forward toward the other skater, or the ball and the skater stop.But they are on ice skates[/color], so the momentum that was imparted by the exchange does not change, even if no subsequent exchanges take place.
That is what I originally said because, as I explained, I didn't think you were relying on transfer of momentum because unless the ball was very heavy the skater would not move very far toward the other skater.And I didn't say anything about throwing the ball after the exchange, I said that even if the ball was dropped, the two would still be attracted. Of course, the exchange cannot be repeated as you note, but that is beside the point. You said that the two skaters would not move towards each other unless one skater was holding the ball, and that is incorrect.
In my subsequent post I said that the skater would move toward the other skater a little bit and then stop. I said: "I can see how repeated back and forth motion of the same ball via alternating grabs by each skater would move them gradually closer together." And I went on to take issue with your suggestion (perhaps I misunderstood) that once the skater began moving as he pulled the ball towards himself, he would continue moving toward the other. I said that he would only continue until the ball reached him and stopped. I still stand by that. I said "But that momentum lasts only until the ball stops with the grabber"
I guess I don't know what you mean by 'attraction'. You cannot mean 'motion' because once the ball has stopped, the skater has to stop. (Or are you suggesting that the skaters are skating as well? {that was a joke})No. The exchange only has to happen once, and the attraction would persist.
Whatever happens on that frictionless ice surface, the center of mass of the 2 skater and ball system cannot move. I think we have to agree on that.Once again, with emphasis: That's why I put them on ice skates.
The two skaters do not stop dead in their tracks once the ball is no longer being exchanged.
If one skater grabs the ball and brings it toward him and the ball stops, that skater must stop. If the other skater then grabs that ball and brings it to a stop against his chest, that skater moves a small distance toward the other and then stops.
If the skater who pulls the ball towards him never stops the ball (because the other skater grabs it back before it reaches his chest) and this is kept repeating, the two skaters will continue to move together. But I didn't think that was what you were saying because I thought you said the motion of the first skater to grab the ball would continue even if the ball was dropped (ie. after the first grab).
However, you need to seek out some education in physics at the basic level first. You said that your next stop is Intro to QFT. That's an admirable sentiment, but you are just not ready for it. That much is apparent from the way you are struggling with the momentum issue with the ice skaters.
I am not struggling with momentum at all. I am struggling with your example. I assure you I have no problem with basic physics. I studied physics from 1972-1976. That was a long time ago. I have't heard that the principle of conservation of momentum had changed since then.
I don't need to revisit classical mechanics. I am rereading my 4th year quantum mechanics text and my 2nd year EM text. I appreciate that you are trying to be helpful, but I think that we are just misunderstanding each other's posts here.You should revisit classical mechanics first, and then classical EM theory, then quantum mechanics.
And then try QFT on for size.
Andrew Mason
Indeed, the extent to which astronomy provides tests of a great deal of physics can sometimes be difficult to accept … I mean, a faint smudge of light in an image that’s full of other smudges is a gravitational lens, just as Uncle Al predicted?
