Why have two inverters in series?
  • Thread starter Thread starter KillaKem
    Series
The discussion centers on the use of two inverters in series within the 74HCT139 logic chip, highlighting their role in buffering and managing timing delays. While two logical inversions might seem redundant, the series configuration enhances output drive capability, addressing the limitations of small geometry transistors that cannot effectively drive external circuit capacitance. This buffering is crucial in CMOS technology, where input capacitance can slow down circuit performance if not properly managed. The need for multiple driver stages allows for a gradual increase in drive strength, facilitating high-speed operation without compromising performance. Ultimately, this design approach helps maintain the high speeds of internal circuits while accommodating the demands of external loads.
KillaKem
I was looking at the datasheet for the 74HCT139 and noticed that it's logic diagram consists of inverters in series, why is this? Aren't two logical inversions equivalent to no logical inversion at all?
Datasheet(pg 4) : http://lbk.fe.uni-lj.si/pdfs/PV-IC-datasheet/74HC139.pdf
Not sure. One possible explanation I could give is that they provide buffering of some sort, or possibly additional timing delays.
Buffering the output. Inside the logic, you use small geometry transistors to increase the speed and shorten the prop delay. But those small transistors cannot drive the capacitance of the external circuits of the pcb traces and the loads. So they need one more buffer to drive out. Just like people put an emitter follower to beef up the drive. Usually the simplest buffer is inverting, nothing more than that.
In fact, for CMOS, they need multiple drivers one bigger than the other to build up the drive. In CMOS, the killer is the input capacitance of the gate. If you go from the high speed internal small transistors to drive a big output buffer, it will slow the circuit down so much. So the small transistor first drive a little bigger transistor which provide a better drive. Then the little bigger transistor then drive the next bigger one...so on...until the last one that can really drive. CMOS inherent is very very fast as you can see the CPU processor running in over 2GHz inside ( as you see the Intel claimed of 2.8GHz etc.) But there is no way the it can drive the external bus. The CMOS logics you see seems slow because of the buffering. That is the reason the external bus speed of those Intel processors is much much slower than the claimed internal speed.
FYI, that's the reason processors put L1 casche ( spelling) and L2 inside and can run really really fast. They don't have to drive load inside and can skip all the buffers...AND smaller too!
I am trying to understand how transferring electric from the powerplant to my house is more effective using high voltage. The suggested explanation that the current is equal to the power supply divided by the voltage, and hence higher voltage leads to lower current and as a result to a lower power loss on the conductives is very confusing me. I know that the current is determined by the voltage and the resistance, and not by a power capability - which defines a limit to the allowable...
  • · Replies 21 ·
  • · Replies 21 ·
