Why is 0 divided by 0 undefined rather than 0?
  • Level: High School
  • Thread starter Nano-Passion
65 replies · 22K views · last reply
When you take a divided by b, a must be something divided by something, example, 10 apples divided by 2 persons = 5 each!
If 0 apples divided by 2 persons, then 0 each!
If 10 apples divided by 0 person, it doesn't make any sense because no one's there to share.
Combining the both, should it be 0, 1 (since X amount of apples divided by X person) or undefined??
None of the above.
1/0 is undefined using the standard definition of the real numbers. 0/0, on the other hand, is indeterminate.
Division is the inverse of multiplication. a/b=c means c is the unique number such that a=b*c. In the case of 1/0, there is no such number c∈ℝ such that 1=0*c. So 1/0 is "undefined".
In the case of 0/0, every number c∈ℝ satisfies 0=0*c. This makes it appear that one could assign any number whatsoever as the value of 0/0. This has two problems, both of them killer. One obvious problem is the lack of uniqueness. An even bigger problem is that assigning anyone specific value opens the door to all kinds of contradictions. Mathematical systems must be contradiction-free.
Give it this way, it's like solving a system of equations using matrices. It can be:
a) insufficient data, i.e. lack of equations;
b) more than enough data, which makes some equations redundant;
c) sufficient data with more than one answer, i.e. line of solution, plane of solution, infinite solution etc.
I don't think it's insufficient data. When performing division, you need 2 data, a divide by b. Now, a is zero, b is also zero. Both data are available, it's just not possible to perform. Just an opinion anyway.
D H said:
None of the above.
very simple.
All theorem built from axioms, and mathematics axiom is what we often say "difficult' to prove, because its
the pillar of math, we have to start with something.
the Reals are defined that way,
hence one of the axiom define it so, if A is an element of R, B is an element of R,
A/B is an element of R, where B=/= 0.
which implies 0/x exist in the real, except when x=0. - (Z)
to prove statement Z, would require you to use the axiom, which obviously the axiom can't be proven
with examples, because it is the truthfulness of the axiom that makes the example valid.
You don't prove axioms, unless you are to bring in some philosophical argument, which
is not so relevant in the rigorous context.
wilsonb said:
very simple.
I think you completely missed the point of my post, which was that the correct term for 0/0 is that it is indeterminate rather than undefined. 1/0 is undefined, but 0/0 is indeterminate.
0/0 cannot be given meaning, period. 1/0 can be given a meaning in various contexts. a/0 is ∞ on the projective real number line for all non-zero a. In complex analysis, a/0 (with a≠0) is sometimes treated as complex infinity, a number whose magnitude is greater than any real number but whose argument is indeterminate.
In layman terms, in any value at all, there can be an infinite amount of 0s. Hence there can also be infinite 0s in a single 0. hence indeterminate.
:confused:
That's not what "indeterminate" means. It's a technical term. It has a definition and is used only for that definition. You seem to be trying to rationalize the word choice. Definitions don't work like that.
PS: If we take your logic as is, then you are arguing all questions whose answer is "zero" is indeterminate. Or (worse) all finite answers are indeterminate. Neither is correct.
Can't help but wonder if Godel would agree with this statement as opposed, for instance, to the following statement:
"Sufficiently complex mathematical systems cannot be contradiction-free."
via Wikipedia...
"Gödel's incompleteness theorems are two theorems of mathematical logic that establish inherent limitations of all but the most trivial axiomatic systems capable of doing arithmetic."
http://en.wikipedia.org/wiki/Gödel's_incompleteness_theorems
wilsonb said:
very simple.
An utter misconception.
How do you "prove" that a poker hand can have 5, and only 5 cards?
It is laid out as a rule of the game, and in like manner, maths is a game where we pick whichever rules we want to play with. Those rules are called "axioms"
Obviously, we may construct as many maths games we want. Just like we can invent new card games, by laying down some new set of rules.
Nonsense. If you are going to bring up the incompleteness theorems, at least learn them. The first theorem says you can't be contradiction free and be complete at the same time (at least for anything which includes PA). It says nothing about just being consistent. We prioritize consistency over completeness.
via Wikipedia...
Godel would certainly agree with DH. Godels incompleteness theorems state (more or less):
1) Our current mathematical system can never be shown to be contradiction-free.
2) A mathematical system can never be AND complete AND contradiction-free.
(1) is certainly problematic, but it does not mean that there are actually contradictions in current math. We just can't prove it. So we more or less accept it on faith.
And, to add to micromass:
Jus because there MIGHT be some contradiction deeply embedded,as yet unrecognized bu us, in our preferred mathematical system, we need not worry too much about it, since if we DO notice it, it might well be easily remedied, by, for example, adding some pedantic little detail in an axiom formulation that doesn't do anything else than preventing just that contradiction from happening.
All previous results that (1) did NOT depend upon the flawed axiom to begin with, and (2) won't depend upon the new axiom would remain unaffected, and perhaps practically all the results which DID use the flawed axiom to begin with.
The contradiction might be more lethal than that, of course, but that it should be so is no implication that follows from the fact that we do not know if our current system is free of contradictions.
As others have noted, that is not what Godel's theorems say. What they do say is that in in any sufficiently complex mathematical system, (a) there will exist statements written using the constructs of the system that can neither be proved nor disproved using the constructs of that system, and (b) that the system is mathematically consistent is one of those statements that cannot be proved or disproved.
In other words, mathematical systems of sufficient complexity cannot be both consistent and complete. Consistency is essential, but completeness is not; it's just a nice thing to have. Mathematicians have given up on completeness (Hilbert's second problem) and assume consistency.
You can switch em using calculus.
and 0/0 is just a product statement, it might have came from some complicated f(x) = h(x)/g(x)
where one simply got 0/0, when computing the limit.
undefined is a statement, where you get R/0, where R is any real number.
0/0 or anyother form of 0^n/0^n, when u compute limits of f(x) as a whole,
which give rise to the method of L'Hopital, when computing limit of f(x), when h(x)/g(x) gives you 0/0.
its 2 different things, one is the axiom & another is taking limits and tend to 0/0.
Additional Reference: Steward J' Calculus 7th ed.
No. You are totally missing the point of limits. In limits, we never get the operation 0/0.
If we have numbers 0 and 0, then its division 0/0 is not defined. This has nothing to do with limits or with functions.
If you have functions, then you can perhaps deal with [itex]\lim_{x\rightarrow 0}\frac{\sin(x)}{x}[/itex]. But, you do NOT divide by 0 here. The limit means that if you get close to 0, then the expression sin(x)/x gets close to 1. You NEVER evaluate the function sin(x)/x in 0. So you NEVER deal with 0/0.
Mathematics are not just about the calculations. The calculations are to solve a particular situation, a problem statement, in which this mere question does not have.
This question lacks the problem statement we need to determine how we can solve it mathematically.
To put it in a sense where 0 = nothing, so 0 / 0 is definitely 0. There is nothing to divide it from and with, but the statement of 0 = nothing made it possible as nothing is required to divide nothing.
In short, UNDEFINED means it is undetermined UNLESS a problem statement is issued. Therefore, undefined can be anything as long as you fulfill the requisite and criteria of the conditions.
No.
No. Not in this case at least.
No problem statement is needed, other than the main idea of this thread, which is what does 0/0 mean?
There is really nothing more complicated here than the arithmetic involved in the division of two numbers. It has been mentioned before in this thread that the division operation requires two input numbers, but an important point has been omitted: from division we require exactly one result. We require a single answer from all of the other arithmetic operations - why should division be any different?
The argument that 0/0 = 0 arises incorrectly from the fact that division and multiplication are inverse operations. If a/b = c, then a = b * c. This is true as long as b ≠ 0.
If we insist that 0/0 = 0 makes sense because 0 (the denominator) * 0 (the quotient) = 0 (the numerator), then we should also accept 0/0 = 2, because 0 * 2 = 0. Since we have gotten two different answers (and infinitely more are possible), this is a violation of the commonsense requirement that division produce a single result.
The upshot is that dividing by 0 is never defined, period.
wilsonb said:
[STRIKE]In short, UNDEFINED means it is undetermined UNLESS a problem statement is issued. Therefore, undefined can be anything as long as you fulfill the requisite and criteria of the conditions.[/STRIKE]
I just got an idea for my dissertation: I'm going to study the patterns and cycles by which threads like this get started on these forums. I can't wait until the next .999999... thread comes along. Then perhaps a thread from an arrogant ignoramus who is convinced that there is something fundamentally wrong about the real line.
:smile::smile:
Mind sammich.
The example I've given is merely the example for which a statement, 0 = nothing, is introduced into the calculation, which would provide a rectification on what the calculation is for. If the that statement is absent from this calculation, then your means would be true.
As I am typing this, I realized I have made an error, though I refuse to erase the top. :-p
I was trying to implement algebraic argument to the 0 / 0 context, which in the end I believe, would be a mathematical fallacy. Forgive me on that.
I was initially planning to introduce a statement as to treat 0 as an unknown in which one could substitute for another for the cause of the current calculation, but after exercising the calculation from different aspects, I realized I was led to a spurious proof. :redface:
I am sorry, but your posts show a very blatant misunderstanding of basic mathematics. I suggest you pick up a good math book and work through it.
I'll explain it once and for all:
0/0 is not defined because we choose it to be undefined. We could define it if we wanted to, but we choose not to. We have very good reasons for this.
First, let's define what division actually means: we say that n/m=p if and only if p is the unique number satisfying mp=n. The reason we choose not to define 0/0 is because there is no unique number p such that 0p=0. All number satisfy! We want / to be a function: that is, every input must give a unique output. This is not satisfied, so we rather choose not to define 0/0.
There is no way to prove that 0/0=0, because this would just be a definition. You can't prove definitions.
There is no context what-so-ever in which 0/0=0. Math works perfectly fine with not defining 0/0. So does computer science by the way: no plane ever fell from the sky because 0/0 has not been defined.
Arguing about 0/0 is pointless, since you're just arguing a definition. You can agree or disagree with a definition, sure. But the fact remains that 99.999999...% of the mathematicians choose to let 0/0 be undefined.
According to micromass, there must either A) exist at least 100 million professional mathematicians in the world, or B) EVERY one of them choose to let 0/0 be undefined.
Somehow, I doubt that..
Where do you get 100 million from? (Just curious).
He wrote about, at the very least 99.999999%.
Now, how big must the population of mathematicians be in order for that percentage of the mathematicians to come from the division between two integers?
(I absolutely refuse to accept the existence of any non-integral mathematicians..)
He wrote about 99.999999...%, which is another way of saying 100%.
That is the B) option I mentioned originally. I doubt the validity of that assertion, as well.
Assume there exists a mathematician that defines 0/0 to be something and he begins an article by writing something like "In this paper, we define 0/0 to be 0." Assume farther that the paper was actually published and (this next one is far more likely than the last one) every mathematician picked it up to read it at the exact same time. There would be a measurable event on the Richter Scale as the article was simultaneously thrown into the trash can by nearly every mathematician reading it.
Now, this is, of course, a mere theory of mine. And I am not a mathematician (yet), but I would imagine this would happen.
