Why is bdry E empty iff E is both open and closed?
2 replies · 3K views
Math Amateur
MHB
I am reading Andrew Browder's book: "Mathematical Analysis: An Introduction" ... ...
I am reading Chapter 6: Topology ... ... and am currently focused on Section 6.1 Topological Spaces ...
I need some help in order to fully understand a statement by Browder in Section 6.1 ... ...
The relevant statements by Browder follow Definition 6.10 and read as follows:
View attachment 9157In the above text we read the following:
" ... ... The set $$\overline{E}$$ \ $$E^{ \circ }$$ is referred to as the boundary of $$E$$, and is denoted by $$\text{bdry } E$$; it is easy to see that $$\text{bdry } E = \emptyset$$ if and only if $$E$$ is both open and closed ... ... "My question is as follows:
Can someone explain and demonstrate rigorously how/why $$\text{bdry } E = \emptyset$$ if and only if $$E$$ is both open and closed ... ... ?
Note: I was surprised at Browder's remark above because I was always under the impression (delusion?) that an open set had an empty set as its boundary ...
Help will be appreciated ... ...
Peter======================================================================================The closure of a subset of a topological space is an important notion in the above post so I am providing Browder's definition of closure as well as a basic proposition involving closure ... as follows ...
It may help readers of the above post to have access to Browder's fundamental topological definitions ... so I am providing the same as follows ... ...
View attachment 9161Hope that helps ...
Peter
  • Browder - 1 - Defn of Interior 6.10 and Relevant Remarks ... PART 1 ... ....png
  • Browder - 2 - Defn of Interior 6.10 and Relevant Remarks ... PART 2 ... .png
Note: I was surprised at Browder's remark above because I was always under the impression (delusion?) that an open set had an empty set as its boundary …​
I can't say whether you are deluded or not but you are certainly wrong! Consider the "open interval" (0, 1) in R. Its closure is the closed set [0, 1]. Its boundary is {0, 1}.
What is true of an open set is that "an open set contains none of its boundary points", not that has no boundary points.
A closed set, conversely contains all of its boundary points. A set is both "open" and "closed" if and only if "none" is the same as "all". That is, if the set has no boundary points.
[/LEFT]
Oh yes ... of course ... you're right ...
Thanks for the clarification... it was most helpful...
Peter
