Why is dz set to zero in constrained differentials?
  • Level: Undergrad
  • Thread starter Thread starter cwill53
    Differentials
15 replies · 2K views · last reply
cwill53
https://ocw.mit.edu/courses/mathematics/18-02sc-multivariable-calculus-fall-2010/2.-partial-derivatives/part-c-lagrange-multipliers-and-constrained-differentials/session-42-constrained-differentials/MIT18_02SC_pb_42_comb.pdf
In part 3 of this example, after dy was expressed in terms of dx, can someone explain to me why z in the total differential equation dw was set to zero? It doesn't make sense to me at the moment.
@BvU Did they make a mistake here?
Also, shouldn’t dy be negative?
I don't see anything set to zero. I see ##ze^y\,dx = c\,dx = 0##. ##ze^y## is a constant ##c## from the point of view of the differential operator ##dx## since it does not depend on ##x##.
I can't make much sense of that either. Perhaps they forgot to say that they wanted ##\frac{\partial w}{\partial x} \big{|}_{z = 0}##. That's what they seem to have calculated anyway.
The way z is set to zero here doesn’t make sense to me. Also the fact that dy isn’t negative.
That looks plain wrong.
PeroK said:
I can't make much sense of that either. Perhaps they forgot to say that they wanted ∂w∂x|z=0. That's what they seem to have calculated anyway.
Why would they even want that though lol? Is it true that if I didn’t set ##\frac{\partial w}{\partial x}## and ##\frac{\partial w}{\partial y}##equal to zero, that I would get the correct answer? I also don't even see the point in this as
$$dw=\frac{\partial w}{\partial x}dx+\frac{\partial w}{\partial y}dy+\frac{\partial w}{\partial z}dz$$
##\frac{\partial w}{\partial x}## is already a term here.
Didn't see that one. Yes, t´his looks wrong as written. I agree with @PeroK that it probably should have been ##\left. \dfrac{d}{dx}\right|_{z=0}## instead.
I’m still a bit confused by that. Why would they need to do this at all?
How is ##z## defined in (1)? It is not defined in (3), and in (2) not independent. So what is it?
And I have trouble to read these tiny formulas. Type it out please.
So, (1) says
1. Find the total differential for ##w=zxe^{y}+xe^{z}+ye^{z}##.
$$dw=(ze^{y} + e^{z})dx + (zxe^{y} + e^{z})dy + (xe^{y} + xe^{z} + ye^{z})dz$$
(2) asks us to write dw in terms of dt. That part is unrelated to the confusion.
3. Now suppose ##w## is as above and ##x^{2}y+y^{2}x=1.## Assuming x is the independent variable, find ##\frac{\partial w}{\partial x}##.
They proceed to say the following (after mistakenly writing ##
dy=\frac{2xy+y^{2}}{x^{2}+2xy}dx## instead of ##dy=-\frac{2xy+y^{2}}{x^{2}+2xy}dx##):
@fresh_42 They end up arriving at
$$\frac{\partial w}{\partial x}=\frac{x^{2}+4xy+y^{2}}{x^{2}+2xy}$$
I think the given solution is incorrect. Nowhere is given that ##z=0##.
cwill53 said:
What I wrote is all the problem says, z is not specifically defined to be anything.
I would make the assumption that that page is unreliable. It specifically sets ##z = 0## that is clear.
I have had another look on the original pdf, and meanwhile I think that the error comes in with the constraint. Maybe they implicitly meant by ##x^2y+y^2x=1## that ##z=0##. That's the only way this all makes sense to me.
I suspect whoever wrote that page confused ##dz = 0## to get the partial derivative wrt ##x## and ##z = 0##. In any case, I can't see much value in trying to make sense of poor material.
