Why Is Every Point of P a Limit Point of P?
  • Context: Graduate
  • Thread starter Thread starter jecharla
    Condensation Points
The discussion centers on proving that every point of the set P, which consists of condensation points of an uncountable set E in a metric space X, is a limit point of P itself. A set S is defined as perfect if it is closed and every point in S is a limit point of S. The participants clarify that if a point x belongs to P, then any neighborhood of x contains uncountably many points of E, leading to the conclusion that there must be a sequence of points in P converging to x. This establishes that P is indeed perfect.
  • Understanding of metric spaces and their properties.
  • Familiarity with concepts of limit points and closure in topology.
  • Knowledge of uncountable sets and their implications in analysis.
  • Basic principles of induction and sequences in mathematical proofs.
  • Study the properties of perfect sets in topology.
  • Learn about condensation points and their significance in metric spaces.
  • Explore the relationship between uncountable sets and limit points.
  • Investigate the role of compactness in metric spaces and its implications for covering sets.
Mathematicians, students of topology, and anyone interested in advanced concepts of metric spaces and set theory.
jecharla
1st part of Exercise #27 is:
Define a point p in a metric space X to be a condensation point of a set E in X if every neighborhood of p contains uncountably many points of E. Suppose E is in R^k, E is uncountable and let P be the set of all condensation points of E. Prove P is perfect.
Obviously, P is closed. But I cannot figure out why every point of P is a limit point of P. There are several supposed solutions to this in the internet, but each of them only shows that if x is in P, x is a limit point of E(which is obvious since x is a condensation point of E). But the exercise asks us to prove that P is perfect, so if x is in P, x must be a limit point of P right? Could anyone offer any guidance to what such a proof would look like?
Could you define perfect please?
A set S is perfect if S is closed and if every point of S is a limit point of S.
Suppose a point x in P is isolated. Then there's an \epsilon > 0 so that B(x; \epsilon) contains no other point of P. Since x is in P, this ball contains uncountably many points of E. Note that we may write B(x; \epsilon) = \bigcup_{j \in J} B(x_j; r_j) for each r_j < \epsilon and x_j with rational coordinates where J is countable. Thus for at least some j we must have that B(x_j; r_j) contains uncountably many points of E (countable unions of countable sets are countable).
Fix this j. Since B(x_j ; r_j) = \bigcup_{q < r_j, q \in \mathbb{Q}} B(x_j; q) and this is once again a countable union, we must have again that there is some q_1 < r_j so that B(x_j; q_1) contains uncountably many points of E. Proceeding by induction, we may construct a decreasing sequence of rational numbers so that the ball centered at x_j of each of these radii contains uncountably many points of E. This shows that x_j is in P, contrary to our assumption.
Edit: thinking about it, I don't think you can easily show that \{q_n\}_{n=1}^{\infty} tends to 0 the way this is set up, which is required for the contradiction.
Take \,p\in P\, and let \,U:=B_\epsilon(p)\, be any open ball of positive radius around \,p\, and
let \overline{U} be its closure.
By definition, \,\overline{U}\, contains uncountable many points of \,E\, , and since it is a compact
set then for any \,\epsilon>0\, there exist only a finite number of balls of radius \,\epsilon\, covering it. This means that there can be only
at most a countable number of points in \,U\, which are not elements of \,P\, (why? Something must be argued here!)
Thus, as in U we have uncountable points of E and only countably many of them are
not in P there are left enough points from which we can form a sequence in P that converges to p.
DonAntonio
Thanks guys!
  • · Replies 0 ·
