Why is it important to classify circuits as series or parallel?
The discussion revolves around the classification of circuits as series or parallel, particularly in the context of resistor configurations and their implications for calculations involving equivalent resistance and power delivery.
  • Participants explore the definition of series circuits and question the assumptions made in the problem regarding resistor arrangements. There are inquiries about the implications of current flow in determining circuit classification and the correctness of calculations related to power delivery.
The discussion is active, with participants providing insights into the definitions of series and parallel circuits. Some participants express confusion over the application of these definitions to the problem at hand, while others attempt to clarify the concepts and address potential misunderstandings.
There are indications of a mistake in the original question regarding the power delivered to specific components, and some participants note that not all circuits fit neatly into the series or parallel classification.
Sunwoo Bae
The performance of the starter circuit in an automobile can be significantly degraded by a small amount of corrosion on a battery terminal. Figure 26-38a depicts a properly functioning circuit with a battery (12.5-V emf, 0,02 ohms internal resistance) attached via corrosion-free cables to a starter motor of resistance Rs = 0.15 ohms. Suppose that later, corrosion between a battery terminal and a starter cable introduces an extra series resistance of just Rc = 0.10 ohms into the circuit as suggested in figure. Let P_0 be the power delivered to the starter in the circuit free of corrosion, and let P be the power delivered to the circuit with corrosion. Determine P/P0.
Resistors in parallel/ Resistors in series
The answer sheet assumes that the resistors in both circuits are in series and that we need to use the equation Req = R1+R2+R3.. to find the Req in both cases. How come the resistors are in series, when there are multiple resistors in a single row?
Also, why does the following work yield the wrong answer? The answer should be 0.4, but I keep getting 0.63..
Thank you in advance!
Because the current flowing through all of them is the same.
You need to calculate the power delivered to "the starter". Is it the same as what you have calculated?
I'd like to add to what @cnh1995 has said.
Components are in series when connected one after the other, in a simple 'chain'. All the current leaving a component enters the next component in the chain. So the current is never split.
There is a mistake in the question.
Sunwoo Bae said:
... and let P be the power delivered to the circuit with corrosion.
It should say:
"... and let P be the power delivered to the starter in the circuit with corrosion."
Uh ... 'cause that's the DEFINITION of series?
Hi Sunwoo Bae,
If the current flows through your components in a single loop or a single path then it is a series circuit.
If the current flows through your components in two or more loops or paths then it is a parallel circuit.
Think of it as if you are walking through a forest, if :
1- There's only one path = series (for all components along that path)
2- There are multiple paths = parallel (for the components on that are on different paths)
GJ
Guy Joel R said:
Hi Sunwoo Bae,
Hi @Guy Joel R. Welcome to PF!
In case you hadn't noticed, this is an old thread, dating back to February!
It may also be worth noting that not all circuits can be claasified as series or parallel or some combination of these - the classic example being a bridge circuit.
  • · Replies 60 ·
11K
