Why is L'(v²) defined as ∂L/∂(v²) and not ∂L/∂(v'²)?
42 replies · 5K views
Hak
While studying the calculation of the Lagrangian for a relativistic free particle, I came across this equation below
$$L((v')^2) = L(v^2) + \frac{\partial L(v^2)}{\partial (v^2)}\big ((v'^2) - v^2) \big)$$, with [tex]L'(v^2) = \frac{\partial L(v^2)}{\partial (v^2)}[/tex],
obtained by using the Taylor expansion for ##L## at the point ##(v')^2##.
My doubt arises over the definition of [tex]L'(v^2)[/tex]. If we are using ##x= v'^2##, shouldn't the derivative be made with respect to that very term? In essence, shouldn't it be: [tex]L'(v^2) = \frac{\partial L(v^2)}{\partial (v'^2)}[/tex]? In the article I read, [tex]L'(v^2) = \frac{\partial L(v^2)}{\partial (v^2)}[/tex] is assumed. Could you explain to me why the latter definition is right and mine is wrong? Thank you very much.
anuttarasammyak said:
The quantity you assumed is zero because v^2 and v’^2 are independent variables.
Thank you for your answer, but I did not understand. Could you explain it to me in more detail? Thank you very much.
L(v^2) is not function of v’^2 thus its derivative with v’^2 is zero.
OK, thanks, maybe I got it. You said, though, that ##v'^2## and ##v^2## are independent variables. Actually, ##v'## is a function of ##v##. How do you explain it, then? Thanks again.
This is a subtle point and is covered in full in my Insight on the chain rule:
https://www.physicsforums.com/insights/demystifying-chain-rule-calculus/
The specific answer in this case is that ##L'## is a well-defined function. But, if you want to use the ##\frac{dL}d## or ##\frac{\partial L}{\partial}## notation, then you must specifiy a variable in the denominator. It's a sort of dummy variable and is there only because you can't omit it. You need to put something in the denominator.
In this case $$\frac{\partial L}{\partial (v^2)} \equiv \frac{\partial L}{\partial (v'^2)} \equiv L'$$They all just mean "the derivative of the function ##L##".
OK, thank you very much for the detailed answer. I am unclear, however, about one point: does your digression mean to imply that it makes no difference whether I put, in this specific case, $$\frac{\partial L}{\partial (v^2)}$$ or $$\frac{\partial L}{\partial (v'^2)}$$? If, on the other hand, I have misunderstood, why is $$\frac{\partial L}{\partial (v^2)}$$ correct and $$\frac{\partial L}{\partial (v'^2)}$$ not? Thank you very much.
PeroK said:
I suspected you might be!
You suspected right! Could you, however, dispel this doubt of mine, if you can? Thank you very much.
I can't read your equations.
Neither is more correct than the other. That's why mathematicians prefer the derivative notation ##f', f''## etc. for Taylor series, whenever possible.
Read my Insight if you would like to underatand this issue fully. That's why I wrote it.
Thank you very much. I will read your article, it sounds very interesting!
Hak said:
Actually, v′ is a function of v. How do you explain it, then? Thanks again.
Usually Taylor-Mclauring expansion form is free from how much deviation ##\triangle x## from x is. Maybe I am misunderstanding your setting. What is v'(v), v' as a function of v, in your problem ?
[EDIT] When we know it we may expect to calculate your qunatity by
[tex]\frac{\partial L(v^2)}{\partial v'^2}=\frac{\partial L(v^2)}{\partial v^2}\frac{\partial v^2}{\partial v'^2}[/tex]
Yes.
What does it mean? Does this answer disagree with that of @PeroK?
That's not what's meant in this context.
As explained above, that's not what's meant in this context.
I already understood that. Thank you.
Just to emphasis the point. We have a function ##L## with a Taylor series expansion:
$$L(x) = L(a) + L'(a)(x-a) + \frac 1 2 L''(a)(x - a)^2 + \dots$$Now, if you want to replace the derivative ##L'## with the differential form, what do you use: ##a## or ##x##? I think that it looks better with ##x##, as derivative with respect to ##a## looks odd.
$$L(x) = L(a) + \frac{dL}{dx}(a)(x-a) + \frac 1 2 \frac{d^2L}{dx^2}(a)(x - a)^2 + \dots$$
We can let ##a = v^2## and ##x = v'^2##:
$$L(v'^2) = L(v^2) + L'(v^2)(v'^2-v^2) + \frac 1 2 L''(v^2)(v'^2 - v^2)^2 + \dots$$And we have the same issue: do we want to write ##L' \equiv \frac{dL}{d(v^2)}## or ##L' \equiv \frac{dL}{d(v'^2)}##? In this context, the chain rule isn't relevant, as the question is purely notational.
I think there is an abuse of notation here. The partial derivative should be denoted ##L_{v^2}##, not ##L' (v^2)##, don't you think? I was the one who first posed the question in this way, so it is my fault for falling into error.
It's not really a partial derivative, as ##L## is really a function of one variable in this case. The problem is that for partial derivatives, there is no argument-free notation for the derivative. See my Insight.
There isn't a totally satisfactory solution, as we are stuck with the notation. The notation is standard. It's not an error, but a deficiency in the differential notation.
I read the Insight, but I could not understand this point. I have some difficulty understanding the type of notation, perhaps because there are different schools of thought? Could you clarify this for me? Thank you very much.
I can't say any more than in is the Insight. It's all in there.
Re-reading this statement of yours, I have my doubts. I understand that you state that the notation is uncertain, but you say that it is better to express the derivative with ##x## and not with ##a##, because the latter case is odd. Since in this particular case ##x = v'^2## and ##a = v^2##, you are saying that it is better to put ##v'^2## in the denominator, right? Doesn't this contradict the article you referred me to, where it is considered less strange to enter ##v^2## in the denominator, not ##v'^2##? I don't understand, I'm confused. I would be grateful if you would clarify this point. Thank you very much for everything.
I am afraid I am cofusing the notation. Let me say ##v^2=x## for simlicity in writing
Way 1
[tex]\frac{\partial L(x)}{\partial x}=\frac{\partial L(x)}{\partial x}(x)[/tex]
is a function of variable x and replacing x wih x'
[tex]\frac{\partial L(x')}{\partial x'}=\frac{\partial L(x')}{\partial x'}(x')[/tex]
is a function of variable x'.  Say variable x and variable x' are independent
[tex]\frac{\partial L(x')}{\partial x}=\frac{\partial L(x)}{\partial x'}=0[/tex]
Say variable x is a function of x' and vice versa
[tex]\frac{\partial L(x)}{\partial x'}=\frac{\partial L(x)}{\partial x}\frac{\partial x}{\partial x'}[/tex]
[tex]\frac{\partial L(x')}{\partial x}=\frac{\partial L(x')}{\partial x'}\frac{\partial x'}{\partial x}[/tex]
Way 2
[tex]\frac{\partial L(x)}{\partial x}|_{x=x_0}=\frac{\partial L(x)}{\partial x}(x_0)[/tex]
is a vaule of the partial differential at ##x=x_0## where I wrote x_0 instead of x' in ordet to mention cleary that it is a value not a variable.
Which way ( or another one ) do you use dashed one in your OP ?
I said it doesn't matter. You could use ##a## or ##x## or ##v^2## or ##v'^2##. Or, something else. It's only notation.
OK, thanks.
