Why is math proof so important in scientific research?
  • Level: High School
  • Thread starter shamrock5585
    Proof
60 replies · 11K views · last reply
shamrock5585
so first off i will state that math is a human language... whenever an article is published or a paper written and it is said to be true it must be sited for where the info came from and often times the source has to be checked as well because, who says they are right anyway. when a scientist finds mathematical proof that something is correct and others look over the work and see there are no mistakes it becomes accepted as proof and no sources are required... why does math always prove something correct? anybody got some good answers?
You mean: why do people accept a theorem from a reference once it is generally agreed upon that the proof of that theorem there is correct?
well yeah... i mean if someone comes up with a theorem... others check for errors and if the math is correct... it is generally accepted... with most arguments you have to argue sources and language terminology... but if you prove something mathematically it is pretty much correct by default.
Math proofs are derived from a very very small set of fundamental axioms. Fundamental, like 1+1=2 and two straight line segments in Cartesian space intersect at, at most, one point. There's not a lot ofpoint in taking up any science unless you grant these first few axoims.
From those first few, all others can be directly created. A new, published math proof consists of showing that your new formula can be derived directly from existing axioms. No math proof is ever accepted until many colleagues have pored over it and concluded that there is no flaw.
In a nutshell, if one accepts the initial underlying axioms, and the rest of the math is done correctly, one has no choice but to accept the new formula.
You seem to know the answer to your own question. Are you just having fun?
basically just looking for a good explanation of WHY... thanks
So to summarize, I guess the answer to "why do we accept a theorem once it is proven?" would be: "by definition of a proof".
What? No. The symbols used in math could, in some sense, be considered a language, but they are not math itself.
If I make up my own symbols but solve the same problem, I would not be doing "different math", I would just be writing it a different way.
I believe his point is more like 'math does not exist without humans'.
yes but if i make up my own symbols for english and speak them when i see the symbols I am still speaking english just not writing english...
well i guess... but what i was getting at is that if you are arguing a point you need to site your sources and prove their credibility but in math you just need to prove that YOU didnt make any mistakes.
I think you're under a slight misapprehension. In mathematics it is very important to cite (not 'site') any sources you use - you're never going to prove everything from first principles. Of course many things are sufficiently self evident, or well known, as to require no citation - you wouldn't bother citing Fermat if you invoke Fermat's Little Theorem, for example, nor would you even name Lagrange if you said "since ord(x) divides |G|" these days.
Yes, in math you are trying to prove that YOU didn't make any mistakes. If you did use work from someone else (which you have to cite, of course!) you already assume that they are correct (because the steps in them were already checked or assumed correct from cited works, etc., all the way back to first principles.)
Why is there a bar through the name?[/size]
That means he's been banned, at least temporarily.
you know the funny thing is, the very principle axiomatic foundations of maths is based upon "self-evedent truths" i.e. we can't prove it is, we just accept that it is, i.e. there is no rationality or logic to rationality or logic itself;
Is logic and rationality ultimately purposeless?
even that is even more twisted, imagine if you will, that you are asked to make a purposeless machine, can you make it?
(a) Well if you make the machine, even if it does nothing, it was made with a purpose (i.e. to be purposeless) but that then makes it null, because in creating purposeless requires a purpose in the first instance
(b) you don't create any machine at all, but then you contradict the initial point, i.e. you can't make it, but at the same time you "can't; can't make it"
eek! :D
Well now, I don't know if it follows that it's not rational.
Some of these axioms we actually define to be so.
eg. 1+1=2 (and only 2). While we can't "prove" it, we have defined this to be so.
Same with others.
Thats what's funny about it!
Yes, we build math from axioms.
You can take that as an axiom, if you want. I also don't know whether statements like "there is no rationality or logic to rationality or logic itself" are really relevant in this thread. I could argue about making assumptions and using intuition as a basis for science, but I won't :)
why? because the definition: We assume something, and we start from that assumption(like 1+1=2), and than we make this: if 1+1=2 than 2+1=1+1+1 so, 1+1+1=2+1==3.(and I've defined the 3 number with the premiss 1+1=2). I've just made a definition that, assuming 1+1=2, than 1+1+1=3. Can you disproof my proof? No, because is just a definition.
However, from this definition, one can proof that exists infinite natural numbers, by a logical method called induction. Now, if you imagine that induction is like defining that pi=perimeter/diameter than you can't deny my proof of infinite natural numbers, because that would tell you that: pi≠perimeter/diameter or 1+1≠2. And that is contradicting your definitions. So, It must be true that exists infinite natural numbers.
Now, the whole math is based in this kind of logical concept. Even the most complex idea like derivative, integral, limit, is based on basic axioms like that one, so, it is true because the assumptions you used were all derived from axioms(definitions), if the theorem isn't true, than some definition is contradicting other or itself.
However, that mean that your definitions aren't always good. Exists basically 2 crisis in mathematical understanding. One was the definition that if you have 2 lines, you can always express the larger one as fraction parts of the other(made by the greeks that lead to the Zeno's Paradox and an re-formulation of great deal of mathematical definitions about real numbers) and the other that lead to the mathematical crisis of 19 century with the Russell's paradox or Burali-Forti paradox. that made some reformulation of great deal of maths definitions with Cauchy among others. Why, because definitions can't be made to contradict then-selfs.
eek! :D
I would be careful in stating that axioms are self-evident truths. This is only viable when there exists fairly simple physical representations of the deductive system at hand. For example, the axioms of incidence are intuitively self-evident when we represent lines as, say, rays of light (and points as photon small regions of these rays). However, attributing the terms of Euclidean geometry to other physical objects, the relationships described by the axioms could still hold without them being intuitively obvious.
I think it is neither true to say 'axioms are self evident truths' nor helpful to sloganeer that 'logic is irrational'.
We do not take axioms to be self evidently true. The canonical example of why this is the wrong way to think of it is the parallel postulate in geometry. If I accept it I get Euclidean geometry. I can use its negation and get other (more?) interesting geometries too. A similar thing occurs with the axiom of choice.
It is more accurate to say we start with some set of axioms, and see what theorems follow. Whether this produces something useful or interesting will be seen with time.
Notice by the way that every mathematical theorem starts "IF ...". That is, it is a conditional statement. Mathematics only says what follows from specified hypotheses and is not concerned with whether those hypotheses are true of false.
The reason mathematics is so generally applicable is because mathematical statements are "TEMPLATES". Any mathematical theory starts with "undefined terms" and axioms that are "accepted without proof" (more technically "postulated"). Other definitions and theorems are given in terms of those. In order to apply a mathematical theory to a given situation, you must assign meaning to those "undefined terms" in a way that makes the postulates true. Of course, since applications always involve some kind of measurement, which is never perfectly correct, the best we can hope for is that a particular theory will "reasonably accurately" fit the application.
I don't see what the issue here is, here is a simpe related question:
"Prove rationally, that rationality is rational";
Go through it carefully..
Anhar,
Hmm, you seem to have mistaken this for a philosophy forum.
The issue was your unhelpful, and unmathematical, characterisation of axioms as 'self evidently true'. (Something I'm sure did myself, once, before I learned better.)
Well many apologies if that’s how it has come across, so now that you have learned better how would you put it? :D lighten up people!
See above posts by HallsOfIvy and me. In particular note those axioms which are negated in different theories such as geometry: is the parallel postulate 'self evidently true'?
The argument from pragmatics.
p1. Technology makes people happy.
p2. Technology is born from rational thought.
p3. It is rational to like that which leads to us being happy.
Therefore,
c1. Rational thought leads to us being happy.
c2. Rational thought is rational.
ὅπερ ἔδει δειξαι.
Therefore,
ὅπερ ἔδει δειξαι.
Well that's a fair argument, but I feel it falls a bit short:
This assumes all technology makes all people happy, what about technologies that does not make people happy, such as missile technology or any weapons tech, these cause great unhappiness, thus p1. has to be limited in scope, to some technology makes some people some of the time (because it is also time dependent, yesterday your dial-up made you happy, nowadays your DSL makes you happy)
You asked for a proof of nonsense. Did you expect anything other than nonsense in return?
Well I was not expecting sense or nonsense, I can not accurately predict what another individual or individuals reply will be in terms of sense of nonsense, hence the best choice is to opt for is one that is neutral.
