Why is my DVD-R Drive Failing to Burn Discs?
  • Thread starter Thread starter Palindrom
    Drive Failing
The discussion revolves around a user experiencing issues with their DVD-R drive failing to burn discs. The scope includes troubleshooting hardware and software problems related to DVD burning, including driver and firmware considerations, as well as media compatibility.
  • The user reports that their DVD-R drive initially worked well but began rejecting new CD-R discs and later encountered an "Illegal disc" error with new DVD-R discs.
  • Some participants suggest that the issue may be related to the compatibility of the discs being used, as the user switched brands.
  • Others propose that the problem might stem from the drive's firmware or driver, although the user believes they have the latest versions installed.
  • The user provides detailed logs from their burning attempts, which include information about the drive, media type, and settings used during the burning process.
  • There is mention of the drive operating in Ultra DMA mode, which some participants might consider relevant to performance issues.
  • Some participants question whether the drive itself may be failing, given the age of the computer and the nature of the errors encountered.
Participants do not reach a consensus on the cause of the issue, with multiple competing views regarding whether the problem lies with the media, the drive's firmware, or potential hardware failure.
The discussion lacks clarity on specific compatibility issues with the media types used and does not resolve whether the drive's firmware is indeed the latest or if there are other underlying hardware concerns.
Palindrom
I am having trouble with my DVD-R drive.
The computer is one year old. In the beginning all was well - and then I bought new CD-R discs which the burner rejected continuously. Assuming it might be that it just didn't like the discs, I didn't let it bother me and ignored it.
Today I bought a new pack of DVD-R discs (different from the ones I usually use). Yesterday it burned a DVD disc beautifully, but today it gives me an error ("Illegal disc") and shoots the disc out.
I would like to fix this problem, I have about 100 discs that will become useless if I don't (at least - who knows which discs I can buy?).
I have tried uploading the driver - I have the best driver in the whole wide world. Thinking it might need a firmware flash, I checked came to the conclusion that I have the latest firmware.
Here's some basic information:
1. Toshiba Sattelite A200-1MY.
2. Running Windows Vista 32bit.
3. TSSTcorp CD/DVDW TS-L632D ATA Device.
4. Firmware version: TO04.
5. Running mode: Ultra DMA 2.
And here's the log file from the newly failed DVD burning trials (the second part will come in a second message - it's too long):
TOSHIBA
Windows XP 6.0
IA32
WinAspi: -
NT-SPTI used
Nero Version: 8.2.8.0
Internal Version: 8, 2, 8, 0
(Nero Express)
Recorder: <TSSTcorp CD/DVDW TS-L632D>Version: TO04 - HA 1 TA 0 - 8.2.8.0
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default
CD-ROM: <TSSTcorp CD/DVDW TS-L632D>Version: TO04 - HA 1 TA 0 - 8.2.8.0
=== Scsi-Device-Map ===
DiskPeripheral : TOSHIBA MK1637GSX iaStor Port 0 ID 0 DMA: On
=== CDRom-Device-Map ===
TSSTcorp CD/DVDW TS-L632D F: CdRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 2047MB (2097151kB)
Free physical memory: 1042MB (1067884kB)
Memory in use : 65 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
4.3.2009
ISO compilation
18:41:31 #1 Text 0 File SCSIPTICommands.cpp, Line 450
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
18:41:31 #2 Text 0 File Isodoc.cpp, Line 6655
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
18:41:31 #3 ISO9660GEN -11 File Geniso.cpp, Line 3349
First writeable address = 0 (0x00000000)
18:41:31 #4 Text 0 File Burncd.cpp, Line 3502
Turn on Disc-At-Once, using DVD media
18:41:31 #5 Text 0 File FilesystemSettingsValidator.cpp, Line 142
FS Settings: using validator 'CUDFSettingsValidatorDVD'
ParamMode = 'automatic', changing UDF partition type from 'physical' to 'physical'
Changing UDF revision from '1.02' to '1.02'
18:41:32 #6 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 538735 (119:43.10, 1052MB)
18:41:32 #7 Text 0 File DlgWaitCD.cpp, Line 319
Write in overburning mode: NO (enabled: CD)
18:41:32 #8 Text 0 File DlgWaitCD.cpp, Line 2957
Recorder: TSSTcorp CD/DVDW TS-L632D, Media type: DVD+R
Disc Manufacturer ID: <CMC MAG>, Media Type ID: <M01>, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 7
18:41:32 #9 Text 0 File DlgWaitCD.cpp, Line 493
>>> Protocol of DlgWaitCD activities: <<<
18:41:32 #10 Text 0 File ThreadedTransferInterface.cpp, Line 762
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 538736 (538736) = #538736/119:43.11
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 538736 blocks [F: TSSTcorp CD/DVDW TS-L632D]
18:41:32 #11 Text 0 File ThreadedTransferInterface.cpp, Line 964
Prepare [F: TSSTcorp CD/DVDW TS-L632D] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 1103331328, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 538736 | 0 | 0x00
538736 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
18:41:32 #12 Text 0 File SCSIPTICommands.cpp, Line 240
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
18:41:32 #13 Text 0 File Burncd.cpp, Line 4288
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
18:41:32 #14 Phase 24 File dlgbrnst.cpp, Line 1767
Caching of files started
18:41:32 #15 Text 0 File Burncd.cpp, Line 4407
Cache writing successful.
18:41:32 #16 Phase 25 File dlgbrnst.cpp, Line 1767
Caching of files completed
18:41:32 #17 Phase 36 File dlgbrnst.cpp, Line 1767
Burn process started at 8x (11,080 KB/s)
18:41:32 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2681
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
18:41:32 #19 Text 0 File Cdrdrv.cpp, Line 10140
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Transfer Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 7 h
Disc Manufacturer ID: CMC.MAG.
Media type ID: M01
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16..783]:
00 00 07 43 4D 43 20 4D - 41 47 00 4D 30 31 00 38 ...CMC.MAG.M01.8
23 54 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 #T.....
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ...
Computer science news on Phys.org
18:41:32 #20 Text 0 File Cdrdrv.cpp, Line 10140
Media type ID: M01
18:41:32 #21 Text 0 File Cdrdrv.cpp, Line 10140
Media type ID: M01
18:41:32 #22 Text 0 File Cdrdrv.cpp, Line 10140
Media type ID: M01
18:41:32 #23 Text 0 File DVDR.cpp, Line 8379
Drive: TSSTcorp CD/DVDW TS-L632D
Book Type request [TSST]: DVD-ROM
Changing the Book Type was finished successfully, return code 0
18:41:32 #24 CDR -1207 File DVDR.cpp, Line 6557
Book Type automatically set to: DVD-ROM
18:41:32 #25 Text 0 File DVDPlusRW.cpp, Line 675
Start write address at LBA 0
DVD high compatibility mode: Yes
18:41:32 #26 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
18:41:50 #27 SPTI -1106 File SCSIPassThrough.cpp, Line 197
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1106)
CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x73
Sense Qual: 0x03
Sense Area: 0x71 00 03 00 00 00 00 0A 00 00 00 00 73 03
Buffer x190b0040: Len x10000
0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
18:41:50 #28 CDR -1106 File Writer.cpp, Line 306
Power calibration error
18:41:50 #29 SPTI -1046 File SCSIPassThrough.cpp, Line 197
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1046)
CDB Data: 0x5B 01 05 00 00 00 00 00 00 00 00 00
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x30
Sense Qual: 0x06
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 30 06
18:41:50 #30 Phase 127 File dlgbrnst.cpp, Line 1767
Generating DVD high compatibility borders
18:41:50 #31 Text 0 File DVDPlusRW.cpp, Line 935
EndDAO: Last written address 0
18:41:50 #32 Text 0 File Cdrdrv.cpp, Line 10140
Media type ID: M01
18:41:50 #33 Text 0 File Cdrdrv.cpp, Line 10140
Media type ID: M01
18:41:50 #34 Text 0 File DVDR.cpp, Line 8379
Book Type request [TSST]: DVD+R
18:41:50 #35 CDR -1046 File WriterStatus.cpp, Line 287
Illegal disc
18:41:50 #36 TRANSFER -24 File WriterStatus.cpp, Line 287
Could not perform end of Disc-at-once
18:41:50 #37 Phase 38 File dlgbrnst.cpp, Line 1767
Burn process failed at 8x (11,080 KB/s)
18:41:50 #38 Text 0 File SCSIPTICommands.cpp, Line 287
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
18:41:53 #39 Text 0 File Cdrdrv.cpp, Line 11391
DriveLocker: UnLockVolume completed
18:41:53 #40 Text 0 File SCSIPTICommands.cpp, Line 450
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon
Sorry for posting all the log... if I knew what was relevant from it I would have left only that, but I'm not clever enough...
Hopefully someone here is more clever than me (well, more clever is easy, but they need to be extremely more clever than me, because I don't know SQUAT! :) ).
illegal disc, ah, try checking the area specification of your DVD-RW drive or the discs that you are writing data to. Discs and the DVD drive is specified to read/write discs of a certain area code and if that fails to match it would pop up an error, at least u can try doing this, this is similar to discs which have video content that is distributed around the globe, the same disc may run in your country but not mine. The drivers and and about the log, that much detail about writing sectors etc is not required here, afaik.
  • · Replies 58 ·
