Why is My Fortran Code Not Working?
  • Context: Fortran
  • Thread starter Thread starter Petar Mali
    Code Fortran
The discussion centers around a Fortran code that a participant is having trouble with. The scope includes programming issues, potential errors in code syntax, and debugging practices.
  • Technical explanation, Debate/contested
  • One participant shares a Fortran code snippet and expresses confusion about why it is not functioning as intended.
  • Another participant requests clarification on what "this don't work" means, asking for details about the expected functionality and any error messages encountered during compilation or execution.
  • A third participant points out a potential issue with the use of "2.do" instead of "2.d0" for defining constants, suggesting that this could be a source of error.
  • The original poster acknowledges the mistake regarding the constant format.
Participants have not reached a consensus on the overall issue, as the original problem remains partially undefined and further clarification is needed.
The discussion highlights potential syntax errors in the Fortran code but does not resolve the underlying issue of the program's functionality or the specific errors encountered.
Individuals interested in Fortran programming, debugging practices, and syntax issues may find this discussion relevant.
Petar Mali
I'm new in programing. Does enybody knows why this don't work.
implicit none
integer i,N,Ntot,istag
real*8 t,U,tpin,k,eg,mstag
real*8 rho,Umstag,Urho
real*8 eaf,eaftot,lambdaminus
write(6,*) 'N,Ntot,t,U'
read (5,*) N,Ntot,t,U
write(36,*) Ntot/2+1
tpin=8.d0*datan(1.do)/dfloat(N)
rho=dfloat(Ntot)/dfloat(N)
Urho=U*rho/2.do
do 1000 istag,Ntot,2
mstag=dfloat(istag)/dfloat(N)
Umstag=U*mstag/2.do
eaftot=0.do
do 200,i=-Ntot/4+1,Ntot/4
k=tpin*dfloat(i)
ek=-2.do*t*dcos(k)
lambdaminus=-dsqrt(ek*ek+Umstag*Umstag)
lambdaminus=lambdaminus+Urho
eaftot=eaftot+lambdaminus
200 continue
eaftot=2.do*eaftot/dfloat(N)-U*(rho*rho-mstag*mstag)/4.do
write(36,990)
990 format(i6,f16.6)
1000 continue
end
Technology news on Phys.org
Please define "this don't work". What is it supposed to do and what does it actually do? What error messages do you get, if any, and when? (when you try to compile the program, or when you try to run it?)
Your constants like 2.do should be 2.d0 (with a zero, not a letter o).
If that doesn't fix your problem ... what [STRIKE]Christo[/STRIKE] JT Bell said.
Tnx. That was mistake.
  • · Replies 37 ·
  • · Replies 16 ·
