Why Is My FORTRAN If/Else Statement Not Working Correctly?
  • Topic: Fortran
  • Thread starter Thread starter rk2ray
    Code Error Fortran
6 replies · 3K views
rk2ray
I am not able to get what's wrong in below.
IF ( temp < 97.5 ) THEN
WRITE (*, *) NTemperature below normalN
ELSE IF ( temp > 97.5) THEN
WRITE (*, *) NTemperature normalN
ELSE IF ( temp > 99.5) THEN
WRITE (*, *) NTemperature slightly highN
ELSE IF ( temp > 103.0) THEN
WRITE (*, *) NTemperature dangerously highN
END IF
Thanks.
Code:
END IF
Thanks.
The first two cases cover everything except when the temperature is exactly 97.5 so it can never reach the other cases where the temp is something else. Put the 103 case first followed by the 99.5 case.
So it should be...the following code..am i right?
IF ( temp > 103 ) THEN
ELSE IF ( temp < 97.5) THEN
WRITE (*, *) NTemperature belwo highN
END IF
What do you think? Is it possible to reach every case with the right starting numbers? Try numbers that are equal to, just above, and just below each of your cases and see if it's possible to reach every case. The way that it's written, nothing will ever print if the temp is exactly 97.5. Can you think of how to fix that? The code is correct (except for the 97.5 problem) but you should always test like this.
BTW, please use code blocks and indentation when posting code. This one is small enough but larger programs can be difficult to read otherwise. And, welcome to Physics Forums. :smile:
thank you borg. I am learning about Fortran. I'm a rookie here.
But your tip really helps.
Glad to help. I'm not a Fortran programmer but If/Else is universal in coding.
Note: I'm only addressing the If/Else problem. Since I don't know Fortran, I have no idea if the WRITE statements are correct. They look odd to me but I guess that's how they're written?
They need quotes around the text that is to be printed.
For example, instead of this:
Code:
do this:
Code:
WRITE (*, *) "Temperature dangerously high"
