Why is My Homemade Cloud Chamber Not Working?
  • Context: High School
  • Thread starter Thread starter marshall-10488
    Cloud chamber
4 replies · 5K views
marshall-10488
TL;DR
I have a cloud chamber made of a metal plate above dry CE with a Fish tank and 99.9% isopropyl alcohol. Get droplets falling no trails
So I made a cloud chamber. I'm using 99.9% isopropyl alcohol, And a lot of it soaked into cotton wool at the top of a fish tank. That's on top of a metal plate painted black with socks filled with dry ice from fire extinguishers (can't buy dry ice easily in the UK).
I leave it for 10 mins or so I get droplets falling but no trails. I've even added uranium glass and a thorium gas lamp filament in there and still see no trails just droplets falling. Can move a torch round and see those drops easy but absolutely no position gives me any trails.
Any ideas what my issue is? Can you over saturate the alcohol? It soaks up a hell of a lot of it when I pour it in on dry cotton wool.
Yes that is an iron/nickel meteorite holding it down 😂
I had the same problem, until I put much more dry ice and the plate must directly touch the ice (really push on it) as much as possible. Also too much isopropyl alcohol can over saturate the chamber so be careful that the droplets are not too big (more like a really fine mist above the plate). Then shine a strong light from the side.
couple things. Make sure the chamber is sitting airtight on the plate. even a little air intrusion can ruin your visibility. Also, we used attached self-sticking felt to the top of the chamber. Be careful of overusing the alcohol - you don't want rain, just fog. One trick to create more of an evaporative environment is to use a heating pad on top (where your meteorite is). lastly, if you don't have much dry ice, you may need a smaller chamber. We built an aquarium sized one but saw much more defined tracks in a much smaller container.
marshall-10488 said:
TL;DR Summary: I have a cloud chamber made of a metal plate above dry CE with a Fish tank and 99.9% isopropyl alcohol. Get droplets falling no trails
I had a similar setup too, mine accidentally worked using 70% ethanol when I ran out of 99% isopropanol, just try to experiment with different alcohol types and do small changes to your setup to see if it works.
