Staff Emeritus
Education Advisor
Dearly Missed
- 35,014
- 21,729
jelanier said:. If the loop is not a function of i, it can't possibly run in parallel.
Close. If you have x = x * i, it is a function of i, but still can't run in parallel.
Probably the easiest way to imagine it is to think about giving half the loop to one thread and half to another. Would you get the same answer? No matter how you split it? I usually ask myself "if I had N CPUs, one for each of the N elements of the loop, would I get the right answer?"
jelanier said:The purpose of this code was to count time more reliably.
Well, you aren't doing that exactly. You're measuring something, that's for sure, but it may be totally unrelated to any real code. In particular, the lack of use of x at the end means the compiler might optimize away part or all of the code involving x. Including the code inside the PARALLEL clause. That said, using wall clock time is a good idea: that's what you really care about, after all.
