Why is Physics Forums running slowly?
- Thread starter rcgldr
- Start date
39 replies · 7K views
Discussion
neutrino
- 2,093
- 2
And it is also quite slow now.
- 327
It just got over it's slow bit now
Evo
Staff Emeritus
- 24,114
- 3,277
It's been causing a lot of double posting.
Staff Emeritus
- 26
It's been causing a lot of my walking away from PF to get some real work done.Evo said:It's been causing a lot of double posting.
Homework Helper
- 1,778
https://www.physicsforums.com/showthread.php?t=125667
Someone want to merge these? This is at least the third thread on the subject.
- 327
Bystander said:https://www.physicsforums.com/showthread.php?t=125667
naw, just call a tech, get it fixed, don't waste your time on aesthetics!
- 11
I knew this would happen when we lost the old skin.
- 20,002
- 11,122
FredGarvin said:I knew this would happen when we lost the old skin.
It's got nothing to do with the skin.
Staff Emeritus
- 9
Do we know what the problem is?Greg Bernhardt said:It's got nothing to do with the skin.
- 11
I had to take one, last parting shot for the old ways.Greg Bernhardt said:It's got nothing to do with the skin.
- 327
Hootenanny said:Do we know what the problem is?
the database is getting bigger evey day?
Staff Emeritus
- 9
Perhaps time for a clean out? Or even a hardware upgrade? - But this would mean down time for PF, which would bring back my withdrawal symptoms...Pythagorean said:the database is getting bigger evey day?
- 20,002
- 11,122
yes I know what the problem is, it's pretty serious, once I can resolve it I'll let it be known
Mickey
- 163
- 0
True 'dat.Gokul43201 said:It's been causing a lot of my walking away from PF to get some real work done.
I thought it might have something to do with the fact that my hard drive is failing.* Lots of operations are slow for me now and my browser quits often. I hope your hard drive is alright, since it must get constant activity.
*No jokes, please. :shy:
Staff Emeritus
- 26
I know Greg's trying to fix some problems, so this may just be related to what he's doing, but in case it isn't, or it's endemic to me...
I've been having all kinds of weird connectivity problems over the last day or two. Sometimes it says "database error" and some other times (like until a couple minutes ago) I see a different kind of error.
Just letting you know, Greg, in case it's not something you're aware of.
Homework Helper
- 1,778
Gokul43201 said:I know Greg's trying to fix some problems, so this may just be related to what he's doing, but in case it isn't, or it's endemic to me...
You mentioned that you thought you'd had a post or two disappear in the "Warbird" thread; didn't witness any of that, however, couple days ago you posted to "Chemistry" on the 12C mass defect/binding energy question --- it ain't there no mo'. Did you delete it? Or did it pull a "trick" on you?
Staff Emeritus
- 26
That one, I deleted. I had had that thread open and intended to respond to it, but had to run away. I came back and replied an hour later without first refreshing. After I posted, I saw it was redundant and first edited then deleted it.Bystander said:You mentioned that you thought you'd had a post or two disappear in the "Warbird" thread; didn't witness any of that, however, couple days ago you posted to "Chemistry" on the 12C mass defect/binding energy question --- it ain't there no mo'. Did you delete it? Or did it pull a "trick" on you?
Rach3
Greg Bernhardt said:yes I know what the problem is, it's pretty serious, once I can resolve it I'll let it be known
Is it dormice nesting in the GD server? I hear they're attracted to cheese.
star.torturer
- 71
- 0
Is it dormice nesting in the GD server? I hear they're attracted to cheese.[/quote
who wouldn't be
i used to live in a server
it took me ten whole minutes to arive at this thread
Lisa!
- 96
Dear me! I'm too impatient and PF is really slow sometimes that I just want to shout...
Homework Helper
- 1,778
Dunno how much help user descriptions of "unusual behaviors" is going to be, but --- just posted to "Gen. Eng." on "Car A/C," and after hitting "Submit Reply," everything "hung up" at about 40-50% "completion of task." Save the reply, close the window, and log back on, and the post had gone through correctly. Gonna check after this "reply" to see if it's still there.
Edit: had to play the same game here --- same result --- now, will it take the "edit" without hanging?
Edit(2): yes.
Edit(2): yes.
JamesU
- 3
Am I the only one without these problems? PF seems fine...
- 327
yomamma said:Am I the only one without these problems? PF seems fine...
time of day thing, maybe?
Gelsamel Epsilon
- 315
- 0
I've always found PF to be very slow when I'm on. Maybe my time zone. But even though there is a lot of people on, or like 50 people viewing the very same forum I posted in, I still get very slow response times. Not that it matters though, because I usually post a few things then don't check till the next day. But it is nice to have fast responses.
- phinds
- · Replies 33 ·
- Feedback and Announcements
- Replies
- 33
- Stavros Kiri
- · Replies 7 ·
- Replies
- 7
- ZapperZ
- · Replies 4 ·
- Replies
- 4
- Cyrus
- · Replies 71 ·
- Replies
- 71
- Replies
- 2
- Chris Hillman
- · Replies 13 ·
- Special and General Relativity
- Replies
- 13
- Cyrus
- · Replies 4 ·
- General Engineering
- Replies
- 4
