Why is special relativity preferred over Lorentz ether theory?
179 replies · 27K views
jimmysnyder said:
I'm sorry for completely mischaracterizing the nature of the discussion in this thread. Is the issue that the following two arguments are on equal footing?
1. No one has detected a dependence of the speed of light on the motion of the emiter relative to the observer, therefore the dependence does not exist.
2. No one has detected the luminiferous aether, nonetheless the aether does exist.
Well, sort of.
There is a difference between the "one-way speed of light" measured from A-to-B, and the "two-way average speed of light" measured on a round trip A-to-B-to-A again. The constancy of the 2-way speed (relative to any inertial observer A) is something that can be confirmed by experiment. The constancy of the 1-way speed depends on your convention for synchronizing the clocks at A and B. If you adopt Einstein's postulates, you must synchronize in such a way that the speed of light is constant by definition.
But you could synchronize in a different way such that all observers agree on what is simultaneous. The second way is just a change of time coordinates tether = teinstein + v0 . x / c2, so still valid. (v0 is the velocity of the observer relative to whatever you arbitrarily choose to be your ether.) But it's an awful choice because you've destroyed all the isotropy of Einstein's co-ordinates. The one thing in favour of "Ether" coordinates is that those people who fail to grasp the concept of relative simultaneity (or those who do grasp it, but philosophically reject it) might be able to accept them.
Of course the constancy of the speed of light has been proven by experiment. The one-way vs. two-way argument is a diversion to attempt to salvage the ether, and nothing more. We could play this game with every piece of knowledge there is.
So... according to Aether: if you can't measure it according to his standards, then c has any value he wants it to have. Is that science? Please note that he does not tell us what the speed of light is in the direction of the ether, nor across the ether, or against the ether. He has no experiments to back up the values he doesn't give us. And he dismisses all experiments that yield values consistent with c. So by his logic:
a) The gravitational constant is different in Andromeda than it is in the Milky Way.
b) The electron's charge is different on Tuesdays in the year 2044.
c) Experimental exidence in favor of a constant c is flawed because of the "fair sampling" loophole (yes, please note that the beauty of this "loophole" applies to every experiment, not just Bell tests - and I am sure we could commission Caroline Thompson to write a "chaotic ball" position paper to support the concept).
Theory is a useful tool. Aether doesn't offer one, simply says all others are wrong. Meanwhile, back at the ranch, everyone else uses c and it works perfectly - one way or two ways LOL. Aether, we all acknowledge that if every previous experiment on every previous subject is subsequently proven wrong, then they are wrong. But that hasn't happened in this particular area *yet*. So when there is some actual scientific evidence to back up your assertion, Aether, please write again. The rest is speculation and belongs in Theory Development.
-DrC
Aether said:
How is it counterproductive? I have clearly demonstrated that many people have an irrational belief that a circumstance (e.g., the constancy of the speed of light) not logically related to a course of events (e.g., an experiment) influences its outcome. This reads on the definition of "superstition" that I quoted. Now I am faced with a choice: 1) keep this to myself, and risk either: a) going through the rest on my own life with the wrong impression, or b) allowing my brothers and sisters to go through life believing in a superstition; or 2) ask this question so that we all may reason together.
Can you show me another "superstition" that can actually come with the correction to the band structure calculation of the semiconductor you are using in your computer?
Zz.
Zz.
Yes, if SR can do that with a constant speed of light, then LET can do it with a variable speed of light. The "speed of light" per se is simply not an active ingredient of Lorentz symmetry. Others have commented that these two theories are actually the same theory using different coordinate systems.
Your argument would be much more convincing if you actually used the "speed" you defined for light to measure the speed of material bodies.
Apparently, you don't actually do that - you use radar methods to determine a conceptually different sort of speed for material bodies, a notion of speed that is in accord with the standard definition and not the notion of speed that you propose using to measure the "speed" of light with.
The argument hinges around a semantic issue, one of what the definition of "speed is". One can (and you do) define oddball sorts of "speed" by playing with the clock synchronization, but such "speeds" lack many assumed physical properties (such as isotropy, the property that bodies with the same mass and the same speed moving in different directions have the same momentum), and are really not very useful.
It's OK to explore non-standard semantics and approaches to see if they do anything useful, but to use non-standards semantics and then call other people "superstitious" because they don't use your non-standard semantics but instead use standard semantics is simultaneously both argumentative and very weak.
You either did not answer my question to show me another superstition that can explain the corrections to the band structure of a semiconductor you are using in your electronics, or you have IMPLICATED that LET is also a superstition.
Which one do you prefer?
Zz.
Zz.
Again, others have commented that these two theories are actually the same theory using different coordinate systems. Either coordinate system (SR or LET) taken by itself is prone to give a similar false impression about what measurements of the speed of light represent. Taken together, either coordinate system in contrast to the other, they describe Lorentz symmetry in a less coordinate-dependent way. This may be implicit in Mansouri-Sexl and most of the papers on local Lorentz invariance that reference their work. I would prefer a completely coordinate independent approach, as I said in post #11.
Excellent! You have refused to answer my direct question to you once again.
Your blindness in trying to defend this "LET" is clouding your understanding of my question to you. I am NOT comparing SR with LET. I am asking about your equating SR with "superstitions". You have equated those two as being the same. I asked you to name a supersition that can explain the corrections to the band structure calculation to a whole zoo of semiconductors that you are using. You blatantly refused to do so.
I strongly suggest that you retract such accusation, which in itself in very insulting to those of us in this field, especially considering that you cannot even put your money where you mouth is in justifying such accusation.
Zz.
Zz.
I retract any implied accusation equating either SR or LET with "superstitions", and apologise to those in the field. I answered your question both times: LET, in the context that I have previously explained.
Aether said:
I retract any implied accusation equating either SR or LET with "superstitions", and apologise to those in the field. I answered you question both times: LET, in the context that I have previously explained.
No you did not answer my question!
I asked for you to show ANOTHER superstition that we use to do corrections to the band structure of semiconductors. All you did was babbled about LET and SR producing the IDENTICAL results. How did THIS answer my question? Is this how you approach all problems given to you, through some filtered glasses that allows you to modify it into what you WISH to see?
And until you care to explain why you think SR is "pseudoscience" while LET isn't (funny, since they produce the "identical" results), I also will ask you to refrain from using that again unless you want me to again ask you to show another pseudoscience that you place your LIFE on every time you fly in an airplane, thankyouverymuch!
Zz.
I'm sorry that I haven't read very many of the posts in this thread. Was the issue of binary stars discussed? If not ...
In a binary star system, one star is approaching us as the other recedes. If the light from these two stars were traveling at different speeds, then because of the great distance travelled, we should see the light emitted at the same time from these two stars arriving at very different times. The perceived orbits of such binaries would be grossly abnormal. Even if we were situated in such a way as to cancel out those effects for one system, it seems unlikely that we were so situated for all of them and in all seasons (we are orbiting too).
Does this constitute a one-way test of the constancy of the speed of light? This test was proposed by De Sitter in 1913.
No.
I believe you are talking about whether the speed of light depends on the speed of the emitter, whether one photon could overtake another photon traveling in the same direction. We haven't discussed that here.
The "one-way" test is the question: does light traveling from Earth to Saturn travel at the same speed as light traveling from Saturn to Earth?
Einstein postulates that the answer is yes. We can't prove or disprove it except by adopting a convention for synchronising the clocks on the Cassini probe with Earth clocks. (The motion of the the Cassini probe relative to Earth means that time dilation has put its clocks out of sync, if only by a fraction of a second.)
In his paper "On the electrodynamics of moving bodies", he postulates the following:
Any ray of light moves in the "stationary'' system of co-ordinates with the determined velocity c, whether the ray be emitted by a stationary or by a moving body.
http://www.fourmilab.ch/etexts/einstein/specrel/www/
I could not find the postulate you mention.
It seems the symmetry you seek to test could be easily acheived with some half-wave glass.
jimmysnyder said:
Einstein postulates that the answer is yes..
OK, to be precise I should have said "The answer 'yes' is implied by Einstein's postulate" (as you quoted it). The postulate says that light moves at c, implicitly regardless of direction.
jimmysnyder said:
It seems the symmetry you seek to test could be easily acheived with some half-wave glass..
I don't understand what a "half-wave glass" is.
If your question supposes that there could be a person "A" who comes away from the study of SR harboring "an irrational belief that a circumstance (e.g., the constancy of the speed of light) not logically related to a course of events (e.g., an experiment) influences its outcome", but that he is nevertheless able to do corrections to the band structure of semiconductors; then my answer to your question is that there could also be a person "B" who comes away from the study of LET harboring "an irrational belief that a circumstance (e.g., the variability of the speed of light) not logically related to a course of events (e.g., an experiment) influences its outcome", but that he is nevertheless able to do corrections to the band structure of semiconductors.
I never said that I think any such thing, and in post #11 I explicitly stated that "I think that both theories involve such an assumption: SR assumes that the one-way speed of light is isotropic, but this can not be proven by experiment; LET assumes absolute simultaneity, but this hasn't been proven either (yet)".
If this amounts to nothing more than semantics, then I would appreciate either an explanation, or a link to an explanation, of why this is so.
Then why wouldn't the binary star experiment be a suitable test for your purposes?
More commonly known as a two-way mirror. Take two Michelson-Morley interferometers and shunt half of the light of one beam from each apparatus over to the other. If the interference fringes are the same in both interferometers, then the speed of the shunted beams was the same in both directions.
So then I was right! You have just implicated LET as ANOTHER SUPERSTITION. I asked you for another superstition that can explain the band theory corrections, and you came up with LET. Congratulations! You have just convinced yourself that it is nothing better than a black cat, or walking under ladders, or breaking a mirror.
Zz.
jimmysnyder said:
Then why wouldn't the binary star experiment be a suitable test for your purposes?.
Why would it? I am asking if the speed of light from the binary star to Earth is the same as the speed of light from Earth to the binary star. I can't see the relevance.
In the MM experiment you have an observer A, two mirrors B and C. You send light from A to B to A, and also from A to C to A. You conclude that the A-B-A average speed is the same as the A-C-A average speed, wherever B and C are.
But how can I tell if the A-B speed is the same as the B-A speed? It is possible that one could be greater than the other, and the differences cancel each other out to give a constant A-B-A average.
I don't precisely understand the modification you propose and how it would help.
Before Einstein gives his postulates in Section I.2, he devotes a whole section I.1 to the Definition of Simultaneity. In the middle of this section he says
We have not defined a common ''time'' for A and B, for the latter cannot be defined at all unless we establish by definition that the ''time'' required by light to travel from A to B equals the ''time'' it requires to travel from B to A.​
This is exactly the point I am making: you must decide on a convention for synchronizing clocks simply to be able to define what the "one-way" speed is. If your convention is based on the assumption that the speed of light is isotropic (an excellent convention, by the way) then no experiment can prove or disprove that the speed of light is isotropic -- it is by definition.
You might also like to read this post from me.
When you said "The answer 'yes' is implied by Einstein's postulate", I took you to mean that the one (invariance) implied the other (speed from A to B equals speed from B to A). If that is not what you meant, then my comment is wrong. But if it is what you meant, then the binary star experiment would verify the one, and implication would take care of the other.
As for the double interferometer experiment, once the two interferometers are calibrated so that there are no interference fringes, shunt one of the beams from one of the interferometers (A) over to the other interferometer (B) and use it as one of the beams there, keeping the other beam as it was. You should get an interference pattern dependent on the speed of light from A to B. (Put some glass in the A-B path and watch the pattern change in order to satisfy yourself that the pattern depends upon the speed). Now do the same from B to A. Compare the two patterns. Now rotate the experiment 180 degrees and look again at the patterns. The point here is that you would not be measuring the speed (no clock), but rather the difference between the speed from A to B and that from B to A.
All this now seems irrelevant to me in view of the definition you quoted. But I'm not sure why. Are you saying that if I defined the sun to be the moon, then every experiment would verify it?
One last question. Isn't this definition forced on us by the first postulate? If the speed of light from A to B were different from the speed from B to A, then experiments involving massive particles moving less than the speed of light in one direction would be possible that were impossible in the other direction because they involve particles moving at that direction's speed of light.
The average speed of light for the round trip from A to B and back to A is c, but the one-way trip from A to B is c' > c. I at A give an electron enough energy to travel .99 c and send it to you at B along with some photons telling you to expect the electron to arrive one hour after the photons do. But the photons travel at c', so the electron arrives late. The particle accelerator was built and calibrated at B and shipped to A some time ago.
Yes, ZapperZ has pointed out previously that particle accelerators do not show any signs of anisotropic behavior. As massive particles approach c in the hypothetical direction that the speed of light is somewhat greater than c, the behavior should be different than in the hypothetical direction that the speed of light is somewhat less than c.
But that doesn't happen. Why not? The logical deduction would be there are no such hypothetical directions (and thus no ether drift). At a minimum, the value of the hypothetical drift must be smaller than a certain value which is very small.
Here's a question: I have an electron moving VERY close to c, let's say v=0.999c, in the +x direction. It decides to oscillate up and down while maintaining this velocity. We know that when a charged particle oscillates like this (even when it has no average lateral velocity), it will radiate, where in classical physics, it is your standard dipole radiation. So in the scenario where the particle is oscillating up and down while moving in the +x direction, you expect, if you solve the EM dynamics, a radiation being emitted, but not quite the standard dipole radiation.
Now, since it is already moving in the +x direction at such a high speed, do you expect to see the speed of light emitted in the +x direction to be MORE than the speed of light emitted in the -x direction? Isn't this somewhat a "one-way" measurement of the speed of light?
Zz.
I don't understand the issues in this thread deeply enough. I think I have given ample evidence of this. As I now understand it, the issue is not whether the measurement would support or falsify SR, the issue is whether a one-way measurement of the speed of light can be carried out at all. In my previous message I proposed a measurement, namely, the time lag between the arrival of the photons and the electron. To answer your question, my expectations don't add up to a measurement. Can you reword your suggestion so that it specifies what to measure?
Humm.. I thought it was rather simple.
It is really a light source that is moving in one direction, relative to you. All I'm asking if expect a difference in the speed of light that source is radiating if you're looking at the source head on versus looking at the source from the opposite direction. This is the same as a binary star system with one star moving towards you while the other is moving away from you.
You can measure the speed of the light that you receive however you wish.
Zz.
Yes, I am (except, of course, there is good experimental evidence that the sun is not the moon). If you define (co-ordinate) "time" (and hence "speed") by assuming c is isotropic then then every experiment would verify that c is isotropic.
If you redefine synchronization of clocks in a way that breaks the 2nd postulate, you also redefine the speed of massive particles, so the restriction on not being able to exceed the speed of light would only apply to light traveling in the same direction as the particle.
In all of this I should emphasize that non-Einsteinian synchronization is an option that you could choose to use if you wanted to (and "Aether" does want to), but it's a poor choice because almost all the time-dependent equations of physics would need to rewritten to account for the change of co-ordinates. Breaking the 2nd postulate in this way would force you to break the 1st postulate, too (but without necessarily contradicting any experimental evidence that doesn't depend on synchronization assumptions).
Correct, if you add the words "... without assuming Einstein's postulates (or some other equivalent postulates, or some other incompatible postulates)".
Alright, I define the sun to be the moon. What evidence do you have that the sun is not the moon?
No, sorry, you are right. If you redefine "the sun" to mean the moon then there can be no experimental evidence that the sun is not the moon. :smile:
Third base!
I have to admit, I'm in over my head here.
Lewis Carroll said:
"When I use a word," Humpty Dumpty said in rather a scornful tone, "it means just what I choose it to mean—neither more nor less."
"The question is," said Alice, "whether you can make words mean so many different things."
"The question is," said Humpty Dumpty, "which is to be master—that's all."
:biggrin:
(hmmm... I have to add at least ten characters to make this post go...)
