Why is the helicity of a neutrino unchanged by the weak interaction?
The helicity of a neutrino remains unchanged by the weak interaction due to the specific structure of the interaction Lagrangian, which includes terms like \(W_{\mu}^+\) and \(Z_{\mu}\) that couple left-handed neutrinos with left-handed charged leptons. In the case of a Dirac mass neutrino, the interaction does not introduce terms that would mix left-handed and right-handed states, preserving helicity. The relevant amplitude for the process can be expressed as \({\cal{M}}_{fi} \approx \bar{u}' \gamma^{\mu}(1-\gamma_5)u \epsilon_{\mu}\), indicating that helicity eigenstates remain distinct throughout the interaction.
  • Understanding of weak interaction and its Lagrangian formulation
  • Familiarity with Dirac mass and helicity concepts
  • Knowledge of chirality and its relation to particle physics
  • Basic proficiency in quantum field theory notation and calculations
  • Study the implications of Dirac mass in neutrino physics
  • Explore the role of chirality in weak interactions
  • Investigate the properties of helicity eigenstates in particle interactions
  • Learn about the Standard Model's treatment of neutrinos and their interactions
Particle physicists, students of quantum field theory, and researchers interested in neutrino behavior and weak interactions will benefit from this discussion.
Final
Hi...
Consider a neutrino with a Dirac mass m_\nu and the weak interaction
{\cal{L}}=\frac{g}{2 \sqrt{2}} \sum_l[{W_{\mu}^+ \cdot \bar{\psi}_{\nu_l} \gamma^{\mu}(1-\gamma_5)\psi_l + W_{\mu}^- \cdot \bar{\psi}_{l} \gamma^{\mu}(1-\gamma_5)\psi_{\nu_l} }\right{]} + \frac{g}{4 \cos(\theta_w)} <br /> \sum_l Z_{\mu}[ \bar{\psi}_{\nu_l} \gamma^{\mu}(1-\gamma_5)\psi_{\nu_l} +\bar{\psi}_{l} \gamma^{\mu}(a+b\gamma_5)\psi_{l} ]
Why this interaction doesn't change the helicity of the neutrino? It is true?
Do you have any elements in that interaction that have a left-handed neutrino on one side of the operator and a right-handed one on the other?
For massless particle ok, because the elicity is the chirality projector \frac{1 \pm \gamma^5}{2}... But for a massive neutrino? It's the same?
I don't see any 1+\gamma^5 there, do you? Which leads me back to my original point: do you see anything in the Lagrangian which has a left-handed neutrino on one side of the operator and a right-handed one on the other?
Yes... For example Z_{\mu} \bar{\psi}_{\nu_l} \gamma^{\mu}(1-\gamma_5)\psi_{\nu_l}. You may take \nu \rightarrow \nu +Z with the first neutrino left-handed and the second right-handed.
The amplitude is {\cal{M}}_{fi} \approx \bar{u}&#039; \gamma^{\mu}(1-\gamma_5)u \epsilon_{\mu}
with u^t=\sqrt{\epsilon+m}(\omega_+,\frac{\vec{p}\cdot\vec{\sigma}}{\epsilon+m}\omega_+ ) and u&#039;^t=\sqrt{\epsilon&#039;+m}(\omega_-,\frac{\vec{p&#039;}\cdot\vec{\sigma}}{\epsilon+m}\omega_- ) where \omega_{\pm} are the eigenstates of the elicity...
  • · Replies 0 ·
  • · Replies 24 ·
